This is a discussion on Heater blower resistor within the INTRODUCE YOURSELF! First time visitors, say hello here. forums, part of the Announcements, News, Introductions and Rules category; Hi all, my fabias air blower is only working on posistion 4, reading the threads it sounds like the heater ...
| Briskodian Join Date: Nov 2007 Location: bridgend
Members Car: fabia 19tdi 2002 Thanks: 6
| Heater blower resistor Hi all, my fabias air blower is only working on posistion 4, reading the threads it sounds like the heater blower resistor, would an independant garage fit this for me, or would I have to spend a fortune in a main dealer. |
Members Car: Audi S3 Thanks: 145
| Re: Heater blower resistor I'm sure a decent independant garage will fit it for you. Not neccesarily going to be cheaper as they may not be entirely sure of how to do the job and over quote for the time taken to cover their backs.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| The Following User Says Thank You to VRStu For This Useful Post: | blastersump (19-11-2007) |
| Briskodian | Re: Heater blower resistor It's a common problem - setting 4 just has the full voltage applied, and 1-3 are retarded by the resistors. As I remember with my VW Polo, VW insisted that the job could not be done by anyone else as they had to be VAG-approved resistors. I cannot quite see how this could be the case though.
__________________ Simon |
| The Following User Says Thank You to wac For This Useful Post: | blastersump (19-11-2007) |
| Briskodian | Re: Heater blower resistor welcome to briskoda
__________________ Gary www.dogboxmedia.co.uk |
| The Following User Says Thank You to oilburninnut For This Useful Post: | blastersump (19-11-2007) |
| Briskodian Join Date: Oct 2007 Location: Preston
Members Car: Fabia VRS Thanks: 15
| Re: Heater blower resistor Welcome ![]() |
| The Following User Says Thank You to Vix For This Useful Post: | blastersump (19-11-2007) |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: Heater blower resistor I had the identical problem on a GM car - after a forum search I bought the resistor pack from the stealer and it was a really simple matter of unscrewing a cover, unplugging the obviously burnt-out resistor pack and plugging the new one in.....
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| The Following User Says Thank You to Basil For This Useful Post: | blastersump (19-11-2007) |
| Proud new Dad Join Date: Feb 2007 Location: Carlisle, Cumbria
Members Car: Octavia vRS TDi Thanks: 165
| Re: Heater blower resistor Hello and welcome. |
| The Following User Says Thank You to Captain Scarlet For This Useful Post: | blastersump (19-11-2007) |
| Briskodian Join Date: Nov 2007 Location: Strathaven
Members Car: Fabia 19 SDI Classic / Felica 1.3 LXi Thanks: 0
| Re: Heater blower resistor new poster here , real stupid question time, so please feel free to slate me after. So I take it from the about post, you can only buy the resistor pack from a dealer. Cheers John May the slating begin ![]() Last edited by jetwoobie; 26-11-2007 at 19:12. Reason: spelling error |
| Re: Heater blower resistor I wouldn't say you deserve to be 'slated' for the question, it's perfectly reasonable. If I were looking to buy one then I would go to a main dealer as it is perhaps one of the less likely parts you'd find third party.
| | #10 |
| Briskodian Join Date: Oct 2007 Location: Ilford, Essex.
Members Car: Roomster 3 1.9 TDI Anthracite Grey Thanks: 9
| Re: Heater blower resistor I had this happen on a Nissian Micra about 4 years ago. As said the top speed (Position 4) is just the full power applied to the motor. The other speeds are knocked down by going through different resistors. It also had a little PCB with burnt out reistors on it. I just measured their values from a working mates car with a multimeter,remembering to subtract any test lead resistance and I just replaced them with 5 watt resistors of around the same value. The resistor values on the Micra were 0.8 R, 0.9 R and 2.2 R. But the switch used some resistors in series for different speeds, so the total resistance worked out as :- Position 1 (2.2 + 0.9 + 0.8) = 3.9 R Position 2 (0.9 + 0.8) = 1.7 R Position 3 0.9 R Total cost of repair was about a pound. I'm not too sure what makes a VAG approved resistor but I bet the real part is loads more than £1. |
| Heater blower resistor | national | Fabia I | 27 | 21-09-2008 11:29 |
| Heater blower resistor | max24 | Fabia I | 14 | 22-01-2008 12:12 |
| vRS heater blower | hebrew | Fabia I | 4 | 30-06-2007 12:05 |
| Heater Resistor | MARTYNG | Fabia I | 4 | 08-11-2006 10:06 |
| heater/blower lights | wd40 | Octavia I | 3 | 04-11-2004 10:24 |
