This is a discussion on throttle problem within the INTRODUCE YOURSELF! First time visitors, say hello here. forums, part of the Announcements, News, Introductions and Rules category; Hello all I need some help with an ongoing problem with my 5 yr old Octavia 1.9TDI. The problem is ...
| Briskodian | Hello all I need some help with an ongoing problem with my 5 yr old Octavia 1.9TDI. The problem is that every couple of weeks when I turn on the engine the car idles ok but when I put it into 1st gear and attempt to take off there is no acceleration from the engine. I can put the pedal to the floor and there is still no change. The car will drive but only at approx 5mph. I brought the car to the garage and they said that a temp sensor and the throttle needed to be changed. This was done and the car seemed to be fine, after another 2 weeks the problem came back. The garage cannot find a fault on the computer but the problem still exists. Has anyone out there experienced the same problem. |
| Briskodian Join Date: Oct 2004 Location: Northern Ireland
Members Car: Octy Elegance 110 TDI (2003) Thanks: 0
| Only advice i can offer is to do a search on the Seatcupra.net site. They have a lot more members and someone will more than likely have had the same problem with a Leon or Toledo. If you can't find a similar thread, just register, and ask the same question there. They are a very helpful bunch. HTH JD
__________________ Octy Elegance TDI (110bhp) |
| 1.4 16V Throttle response / Problem | Nick_H | Fabia I | 6 | 24-06-2005 07:30 |
| SERVICE NOW indicator problem | Turbo_Boss | Maintenance & Performance | 9 | 09-08-2004 04:05 |
| ESP problem, throttle noises | kostas | Maintenance & Performance | 22 | 11-06-2004 09:18 |
| Throttle Body Alignment | KLB | Maintenance & Performance | 6 | 29-05-2003 12:56 |
| Serious cold start problem | Dutch4x4 | Maintenance & Performance | 6 | 28-04-2003 10:09 |
