39,459 Members 1,489,962 Posts
6 speed box gone all limp
This is a discussion on 6 speed box gone all limp within the Maintenance & Performance forums, part of the General Motoring Discussions category; When i was over at JBS for the rolling road the guy that tested my car said that the spring ...
Old 14-09-2004, 16:05   #1
helpmedisappear's Avatar
Members Car: Fabia vRS
When i was over at JBS for the rolling road the guy that tested my car said that the spring had gone on the gearbox making the gear stick kind of "limp" in neautral instead of springy. The stick just stays where you put it instead of springing back to the central position. My question is will this effect the box long term or have i got nothing to worry about? I do sometimes get a grind going from 1st to 2nd would this have anything to do with it?
This is for a fabia vrs by the way...and its booked in to be looked at next week
Thanks
Martin
Black Magic Fabia vRS
v
helpmedisappear is offline
Old 14-09-2004, 16:26   #2
DGW
BRISKODA Staff
DGW's Avatar
Presumably a problem with the selector mechanism rather than the gearbox? I hate gearboxes with sloppy 'gates' and would definitely get it fixed. Please let us know what the fault was in due course.
Denis
DGW is offline
Old 14-09-2004, 16:31   #3
robmawer's Avatar
Members Car: Octavia 1.6 Ambiente
IIRC, you can lift up the gaiter and the spring's clearly visible...might've just unhooked or something, in which case it would save you a trip to the dealer?
Rob.
robmawer is offline
Old 14-09-2004, 16:56   #4
Rob dont go all technical on me!!! Is this an easy thing to do or should i just take it into the dealer to get checked out fully?
Martin
v
Old 14-09-2004, 16:57   #5
redbaron's Avatar
Members Car:
rob your talking about your low tech 1.6 here..
i assume the spring will be partof the selector mech in the box.. might be a good time to put a short shifter on too?
________________________________________
Some times I just feel like smiling.
redbaron is offline
Old 14-09-2004, 17:01   #6
robmawer's Avatar
If it's like the Octy...you open up the ashtray, take out the insert, grip the bit of plastic at the front of the gearstick surround and pull it upwards...however, probably worth not being too enthusiastic with it in the Fabia if it doesn't work the same way...
And yes, mine's the low-tech 1.6, which has a little spring in there to pull the lever back into place...your may well be different...
Rob.
robmawer is offline
Old 14-09-2004, 19:11   #7
Om nom nom nom
Neo_VR's Avatar
Members Car: A White Car
Rob.
Im impressed Rob... i was expecting a slew of Fabia = comments... but i suppose youve no room at all to talk in a smart car
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 14-09-2004, 19:36   #8
I think i'll let the dealer sort it, i dont trust myself mechanically! I will let you know what the out-come is. The guy at JBS said it will either be a spring or a cable? I just hope its not done any damage!
I will also get the dealer to look at the MAF as the revs went all wierd on me this morning in 2nd when i was in traffic
Martin
v
Old 15-09-2004, 08:25   #9
Sounds like it is the neutral detent, the grind when going from 1st-2nd is from the selector mechanism not being aligned in 1-2 gate position. With the lack of reacting spring tension mis-alignment in a thro' gate gear shift by hand can cause the grind.
Mark
Mark Harrison is offline
Old 15-09-2004, 08:51   #10
Mark
Thanks for that Mark...i will ask the dealer to look at the gate position from 1st to 2nd as well as the spring
Martin
v
Old 19-09-2004, 11:27   #11
Well curiosity got the better of me and i decided to have a look at the spring myself taking pics as i go The problem still exsists but seeing as its going in the dealer on tuesday im sure they will sort it. This is for anyone thats nosey and fancies having a look at the spring in question
First i took out the ash tray and was presented with 3 screws. Undo the middle one thats all you need to do:
Give the trim a good tug and it just unclips:
Now for the spring. This is what it looks like when its gone astray:
And this is it back in place where its supposed to be:
I thought i had fixed the problem and was rejoicing over the fact that i didnt have to drive a 1.2 courtesy car around for a day when i took it for a test drive All was going well until i did a bit of reversing to park up...click...spring off again. I did fix it again thinking that it was a one off but the next time i came to reverse...click...same thing. Oh well off to the dealer
Martin
v
Old 22-09-2004, 09:45   #12
Update: Took it to the dealers yesterday who apprantly fixed it. I did tell them i had already done it twice and that the spring pings off when reversing. Obviously they didnt listen as i got in it to check it, didnt even turn it on, spring was off as they had reverse parked it up on the forecourt and left it
I think its either the spring itself or the plastic nylon thing the spring sits in, i told them this and they are going to look at it on saturday as i told them there was no way i was driving around in an awful 1.2 courtesy car ever again! Regarding the MAF, no fault codes recorded so god knows what it is
Could i have weakened the spring by always leaving my car parked in reverse? If you saw the hill that i live on you would understand why i do this. Surely it shouldnt make any difference?
Another update to come...
Martin
v
Old 22-09-2004, 10:32   #13
robmawer's Avatar
I'd worry if that was the case!
If you pop open the trim again, can you actually watch it pinging off when you put it in reverse? You might find there's a way of securing it or bending it so that it stays put?
Bit surprised at the dealer - it's not like it would be a long job to look at it, quite why it requires 2 visits in one week is a bit of a mystery!
Rob.
robmawer is offline
Old 25-09-2004, 11:54   #14
I didnt fancy bending the spring myself incase the dealer went all funny on me but i had thought about it. That is exactly what they have done anyway and all is well so far! Lets hope it holds. Ive gotta get used to the resistance going from 1st to 2nd now as i keep going into 4th instead Ahhhh its like new again!
Martin
v
Similar Threads
Introduction to the NEW Octavia ColinD Octavia II 2 22-02-2007 20:09
330d - to chip or not to chip? that is the question...... Huck Off Topic and Chit Chat 22 02-08-2005 00:58
New Octavia In Detail ColinD General Car Chat 0 22-04-2004 12:18
