39,459 Members 1,489,963 Posts
Air box mods!
This is a discussion on Air box mods! within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi guys, Has anyone "modded" their air box. There are two things that can be done... Drilling holes in the ...
Old 23-11-2007, 20:16   #1
ethos's Avatar
Members Car:
Air box mods!
Hi guys,
Drilling holes in the bottom and/or definning it.
Has anyone done either with good results? I want a bit more induction noise but don't have the cash to buy an expensive induction kit
ethos is offline
Old 23-11-2007, 20:34   #2
Gizmo68's Avatar
Re: Air box mods!
Take the cold air feed off the airbox, this will give more induction noise and have the same result as drilling holes in the box - that is they will both reduce power as you will now be introducing warm air (engine bay) into the engine rather than the lovely cold air its designed to have.
A few 1mm holes in the exhaust back box will also compliment this mod and give you a more 'sportier' exhaust note.
Gizmo68 is offline
Old 23-11-2007, 20:49   #3
ethos's Avatar
Members Car:
Re: Air box mods!
I don't want to do either of those, and less performance... no chance!!!
ethos is offline
Old 23-11-2007, 20:55   #4
Crossdresser
Quinten's Avatar
Re: Air box mods!
I did that on my previous octy. The increase in noise was audible, but I can not comment on performance loss/gain.
Awooga!!!
Quinten is offline
Old 23-11-2007, 22:00   #5
Dan Walton's Avatar
Members Car:
Re: Air box mods!
I think de-finning the airbox (not sure if this is best done clean side or dirty side) is supposed to be worth doing, seeing as it's a free mod! And I'm sure I've read some people had modified the air feed to the standard airbox by running a larger diameter pipe down to the wheel arch area.
It is an Octy vRS you have isn't it and not a 1.2 Corsa? In which case please do not drill your airbox!
J'ai douze ans!!
Dan Walton is offline
Old 23-11-2007, 22:03   #6
ethos's Avatar
Members Car:
Re: Air box mods!
Ha, yea it's a vRS
The fins on the air box are so small tho, like 10mm high or so...
I think i'm going to take the filter out this weekend and give it a smack or two so might do it whilst im there.
Just got to find something suitable to cut them... bit of a tight angle. Maybe a sharp knife and then bend them till they snap off!
ethos is offline
Old 23-11-2007, 22:12   #7
Dan Walton's Avatar
Members Car:
Re: Air box mods!
Yeah, they're only small but it will make a slight difference in the air flow. I think they are there to try and quieten down the induction noise on the car, but won't necessarily flow air as best as possible. If you imagine pouring water through your air box, those little 10mm high ridges would make a hell of a lot of difference, it'd be like a little water feature, rather than a nice smooth, meandering river... or something!
I think if you score along the join of the ridge to the box they will snap off like you've said. Or if you have a Dremel or similar you could whizz them off in no time. Just make sure there aren't any little bits of debris when your finished, youwouldn't want any nasties going through your turbo!
J'ai douze ans!!
Old 23-11-2007, 22:16   #8
ethos's Avatar
Members Car:
Re: Air box mods!
Nope!! Think I might do it around the back and hoover the box after just incase
Would be interesting to see the difference, no-ones actually covered it on here... well from what I can find on search.
The pipercross panel filter helped, want to see how it looks after 5k.
ethos is offline
Old 23-11-2007, 22:30   #9
Dan Walton's Avatar
Members Car:
Re: Air box mods!
I think if you do a search for 'pikey mods' it will covered there somewhere. That or 'de-finning'. I'm sure I remember seeing a few of the guys with quite big power recomended doing it with an 80mm air feed. Thinking about it, I might have read it when I was deciding whether to get a Carbonio, so it might have popped up in one of those searches. Anyway, I'm sure it's been done and calculated/proven by some of the big boys. I will do it to mine when I can be bothered! Too cold to do anything at the mo and I'm too busy...
J'ai douze ans!!
Old 24-11-2007, 11:40   #10
john_grant358's Avatar
Re: Air box mods!
Originally Posted by ethos View Post
Ha, yea it's a vRS
I definned my airbox in my fabia, very slight improvement in throttle response, but barely noticable, prob would make more difference with a higher performace airfilter which i should be getting soon!
I used a chissel and a hammer to get them off, got to be carfull you dont go through the whole box though! I then used some sandpaper to tiddy up the job. Cut the sh*t out of my hand tho!
john_grant358 is offline
Old 24-11-2007, 13:17   #11
2.0 FSI Sport.
smstext's Avatar
Members Car: Octavia Mk2 FSI Sport
Re: Air box mods!
why not just buy a new airbox thats smooth? surely someone sells such a thing?
smstext is offline
Old 24-11-2007, 13:48   #12
Dan Walton's Avatar
Members Car:
Re: Air box mods!
Why not just buy a Stanley knife and improve the standard one?
J'ai douze ans!!
Old 24-11-2007, 14:28   #13
Hardcore
Basil's Avatar
Members Car: Fabia vRS
Re: Air box mods!
Dremel tool (which would be a nice Xmas pressie) will do the job neatly.
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is online now
Similar Threads
smoothing air box funkymonkey Octavia I 5 03-03-2007 11:42
Air Box Mods........ Buggs Maintenance & Performance 8 23-11-2004 10:28
Furby air intake mods... andy ellis Maintenance & Performance 1 23-05-2004 08:56
x-box mods Stimps The Tech Shed 12 07-02-2004 12:42
Improving air flow to air box SkodiRS Maintenance & Performance 3 23-07-2003 14:10
