This is a discussion on Brake fluid change <> brake fluid flush! within the Maintenance & Performance forums, part of the General Motoring Discussions category; All, Quick question, just been into the local garage and asked for a full flush of brake fluid to brand ...
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
| All, Quick question, just been into the local garage and asked for a full flush of brake fluid to brand x, which is not compatible with present. Was told I only need a 1 litre bottle. I though as have others that the system is 1.75 litres. A change/top up I can see 1 litre being enough. I cannot see it if the whole system is to be flushed. Do I need to use a different term from flushed? Drained, emptied, changed, put all of this 2litre bottle in that car and wipe the excess off? Please shed light and earn a virtual reputation point. Thanks in advance from a slightly confused person.
__________________ ColinD - 97/100 Limited Edition Octavia vRS < For Sale www.BRISKODA.net :: Site Owner. E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. |
| Don't talk, drive! Join Date: Feb 2003 Location: The B roads of Britain
| Agree. If not compatible it needs to be completely flushed out. How exactly you do that without some mixing of the fluids in the process escapes me, other than draining the system which you DON'T want to do as getting the air out again will be a nightmare. I would go with your 2 litre idea and tell em to use it all. If it was a different colour that would help...
__________________ Nick |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| When replacing DOT4 fluid with DOT 5.1 I usually use around 2 litres which is the capacity of our pressure bleeder. I bleed out plenty (usually about 300mls at least) of fluid from each caliper to ensure all the old fluid has been bled though. Remember to mark the cap for future referance that 5.1 has been used.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| Briskodian Join Date: Sep 2003
| So can anyone give a definitive answer to this one? Although I'm only replacing with Super DOT4 (ie compatible with what’s already in there), I would be disappointed if 30-odd% percent of the fluid in the system was old fluid. What will a Skoda garage do? |
| BANNED Join Date: Oct 2003 Location: Southend
| They should flush the system with your new fluid. Usually the change over takes about 1.75 to 2 litres. If they use less than 1.5 litres they haven't doneit properly. (system capacity is 1.75l.) Also your brakes should not feel spongey if it's just a fluid change, if they do, get them to re-bleed them. Those of you putting Ferodos on - please read the instructions re bedding them in that come in the box. If you don't you will find they don't worlk as well and become prone to glazing. |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| With regards to glazing....will grooved discs/disks help?
__________________ Adrian. |
| Yes, they will, the grooves remove some of the sheen from the pad |
| | #8 | |
| Quote:
What do you think of that then, boys and girls?
__________________ Si | |
| Briskodian Join Date: Oct 2003 Location: Cumbria and Cheshire
| My dealer changed and flushed my system with AP Racing fluid and used almost 2L. There is probably enough left in one bottle to do a brake bleed. Another garage "changed" the fluid and used less than a litre thats why I took it back to the dealer!Steve
__________________ From Tavia vRS 230bhp to Impreza WRX STi Version V Type R to Clio 182 Cup |
| | #10 | |
| Quote:
OK, I'll take a couple of litres into my local dealer, and make a nuisance of myself until I get what I want! Which is, AFAIK, new fluid in as much of the system as possible, especially the calipers.
