This is a discussion on Clutch issue! within the Maintenance & Performance forums, part of the General Motoring Discussions category; I pulled out quickly from a junction on to a roundabout earlier and the clutch pedal seemed to stick half ...
| Legend!! Join Date: Oct 2006 Location: Portsmouth
Members Car: 53 reg Octavia Vrs & 57 reg Octavia Vrs 170pd TDi Thanks: 42
| Clutch issue! I pulled out quickly from a junction on to a roundabout earlier and the clutch pedal seemed to stick half way up! The result was much revving and a lot of smelly burning clutch!!! Is my clutch on the way out, or was I jsut giving it too much right foot?? The clutch is not slipping and the problem seems to have gone now, except the burning smell!!! Any thoughts?? |
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: Clutch issue! maybe the slave cylinder is leaking a little! check the brake/clutch fluid level |
| Re: Clutch issue! BLIMEY!!! Never even thought about that sort of thing! Is this a major issue?? Where can I check the levels?? Thanks for your help by the way. SC ![]() |
| | #4 | |
| mello in yello Join Date: Jan 2005 Location: Living in Gods own......
Members Car: fabia vRS/ octavia vRS Thanks: 201
| Re: Clutch issue! Have you any carpet/mats in the foot well that may have ridden up under the clutch pedal? I once sat at lights lifted clutch foot up andstarted to rev but clutch pedal stayed where it was, turned out mat was jamming pedal shaft into recess.
__________________ Quote:
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys | |
| | #5 | |
| rider of sharks Join Date: Apr 2005 Location: Cumbria
Members Car: Fabia vRS Thanks: 245
| Re: Clutch issue! Quote:
carpets and mats interfering with pedal travel happens more than people may think! I had an old lancia thema turbo, and lost the overboost for while, (overboost happens for short periods on full throttle) , took my car in, and it turns out the carpet had slipped under the accelerator, preventing the pedal travel from getting far enough to operate the switch! lol... pull the carpet back, and overboost returns ! ![]()
__________________ Fiat Grande Punto Sporting (158 bhp 314 lbs/ft) in Red.... ![]() Furby vRS , black magic,passenger airbag de-activation switch, (now gone, but not forgotten!) | |
| Re: Clutch issue! Definately not the carpets! I can still smell a little bit of the burning smell in the car! Seems to be there all the time! Any other suggestions? how much would a new clutch be on a vrs? I have a little oil around the oil filler cap on the engine, could it be that which smells? I'm cleaning it off tomorrow, but any suggestions would be appreciated. Thanks |
| Briskodian | Re: Clutch issue! The smell from a burning clutch hangs around for days as we found out ![]() The slave cylinder failed and was replaced by a newer part on my octy under warrenty.
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 46
| Re: Clutch issue! Get it sorted asap or you'll end up with a new clutch + labour associated, which won't be that cheap I'd imagine ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| 500 Power Join Date: Mar 2004 Location: Kent
Members Car: Fiat 500 Thanks: 16
| Re: Clutch issue! Clutch for Furby vrs is aroung £600 incl VAT & Labour, That is waht I was quoted, fortunately mine was a warranty job PHEW !
__________________ Steve Man-Bag ? Girlie Car ? - You Decide ( I have - it's neither ) ![]() |
| | #10 |
| Briskodian Join Date: Jul 2006 Location: Oxford/London
Members Car: 2.0l fabia elegance Thanks: 0
| Re: Clutch issue! I had that EXACT same issue. It needed a new clutch slave cylinder. All done for £100. |
| | #11 |
| Briskodian | Re: Clutch issue! I have an issue with the clutch which is intermittent, but rather than slipping it won't disengage properly? Most of my miles are on the motorway, but quite often once I've driven the 5 miles / 10 minutes through town from the motorway to my house (approx 55 miles motorway first), I start getting gear engagement problems. Sometimes it is almost impossible to engage first or reverse to park, sometimes the car seems to jump a little if I sit with the clutch depressed waiting to pull away. Does anybody have any suggestions please? I noted it 15,000miles ago, but the dealer couldn't find anything wrong? Should have noted that its a 55 plate Furby vRS! Last edited by andfit; 13-11-2006 at 17:27. |
| | #12 |
| Re: Clutch issue! Please can you tell me where the slave cylinder is so as I can check for leaks etc? Thanks |
| | #13 |
| Briskodian Join Date: May 2006 Location: Rochdale
Members Car: ST Thanks: 1
| Re: Clutch issue! Unfortunately my car did exactly the same last night (Clutch pedal stopped about quarter of the way up).... My car absolutly stunk for a while but all gone now. Where is the slave cylinder so I (like SCVRS) can check that all is ok. Thanks Damian
__________________ ![]() |
| | #14 |
| Re: Clutch issue! the slave is on the top of the gearbox on the right as you face the car, iirc to get to it you have to take the battery out |
