This is a discussion on Coolant sensor location? within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi, Please can someone give me an idea where the coolant sensor is on a Fabia vRS? Im looking but ...
| Briskodian Join Date: Dec 2003 Location: Bolton
| Hi, Please can someone give me an idea where the coolant sensor is on a Fabia vRS? Im looking but im not seeing! Thanks... |
| R/H/S of the head , underneath the fuel pump , there is another housing with coolant pipes attached , the sensor is at the bottom of this housing facing towards the bulkhead HTH
__________________ not so bored now |
| The Following User Says Thank You to ric04vrs For This Useful Post: | helpmedisappear (22-06-2008)
| Thank you very much! Ive found it...it looks seriously tight to get at, is it accessable from under the car? I might get it on some ramps and have a look. Thanks again. |
| | #4 | |
| Briskodian Join Date: Sep 2004 Location: South Bucks
| Quote:
Though I elected to have Skoda do mine.... - do the job when the coolant is cool/cold and unpresurised. - Leave coolant cap on to reduce coolant loss. I guess you can remove "lots" to help with elbow room.... Engine cover, air inlet hose, airbox lid at least etc. J.
__________________ Slowly turning the planet sooty. | |
| The Following User Says Thank You to vindaloo For This Useful Post: | helpmedisappear (22-06-2008)
