Eibach pro-spacer kit?
This is a discussion on Eibach pro-spacer kit? within the Maintenance & Performance forums, part of the General Motoring Discussions category; Anyone fitted wheel spacers such as the Eibach pro-spacer kit? Just wondering if they make any worthwhile benefits to handling ...
Old 22-01-2005, 13:48   #1
VT5
Question Eibach pro-spacer kit?
Just wondering if they make any worthwhile benefits to handling & bodyroll etc.
Do they increase load on wheel bearings - anyone had any fail because of fitting them?
Extra long wheel bolts would be essential then!
cheers.
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 22-01-2005, 14:13   #2
Om nom nom nom
Neo_VR's Avatar
IIRC the rear track on the fabia is a few (5 or 6) mm narrower than the front.
fitting spacers to compensate will increase stability under heavy braking.. but you will need longer wheelbolts.. and it will increase load on wheel bearings (i have had a rear bearing fail... almost wouldnt do it under warranty due to aftermarket rims)
tbh your looking at over £100 for a pair of spacers and the relavent bolts.. its not really worth it
EDIT: badger 5 can supply hubcentric spacers.. will be much cheaper than comparative eibach set
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 22-01-2005, 14:37   #3
VT5
Prices on motorsportworld.co.uk range from £26.44 for 10mm spacers to £72.51 for 50mm spacers per set - plus wheel bolts. 16,30 & 40mm also available.
Did you fit spacers or did the bearing fail because of the 17"s
where can i find details of these badger 5 ones?
cheers Colin!
btw I found this on the Eibach site..
Eibach Pro-Spacer is the ideal combination for use with the Eibach Pro-Kit as well the Sportline, if the original or aftermarket wheels are missing that last optical "kick". With the Eibach Pro-Spacer installed the car looks wider and better, as the wheel fills the arch. That's how the car's look gets its final touch.
By increasing the track width, not only is the appearance improved, you also achieve an optimized driving behavior combined with higher stability, as the roll of the chassis is influenced in a positive manner.
FabiaTDi is offline
Old 22-01-2005, 14:45   #4
VRS_AML's Avatar
Originally Posted by FabiaTDi
By increasing the track width, not only is the appearance improved, you also achieve an optimized driving behavior combined with higher stability, as the roll of the chassis is influenced in a positive manner.[/b]
While this is infact true it's also worth knowing a little rule-of-thumb that for every 30mm wider you make a vehicles track, dropping the car height by 10mm will have the same affect on the vehicles c of g.
Just my 2p worth
Skoday Mo Fo
New:
BMW 130i M Sport
265bhp, 232lb/ft, 1450kg,
Gone:
Black Magic Fabia vRS
Cruise, Parking Sensors
Heated seats, Xenons
VRS_AML is offline
Old 22-01-2005, 14:52   #5
Om nom nom nom
Neo_VR's Avatar
Give bill a call... or PM him
i did consider adding 5mm spacers each side on the back.. but the cost was prohibitive. are the eibach ones hubcentric??
my 17"s were a slightly bigger offset than the OE ones which is what they were trying to blame the failure on. the car will look better with them on (eg ross's TTcomp wheels are a bigger offset and fill the arches better) but i think youll have arch clearance problems with more than 5mm on each side.
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 25-01-2005, 19:05   #6
badger5's Avatar
Not sure if its same for Fabia as it is for ibiza, but adding rear track width settled down the rears 'nervous' feel, especially over uneven ground and heavy braking. Made the rear seem more planted on ibiza's when adding 15mm/side
They were 35mm narrower rear than front as std.
517bhp / 378lbft SEAT Ibiza Badger Mobile
badger5 is offline
Similar Threads
Eibach springs and damper kit for vRS. Lummox Fabia I 6 04-11-2004 12:33
Cheapest place for an Eibach Spring Kit? camerashy General Car Chat 3 08-09-2004 22:48
Fabia vRS with eibach kit faboka vrs Maintenance & Performance 42 20-07-2004 22:00
