39,474 Members 1,490,329 Posts
ESP problem, throttle noises
This is a discussion on ESP problem, throttle noises within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hello All, i have a 4x4 1,8t hatch octavia which i purchased a few mnths ago. On cold damp mornings ...
Old 01-06-2004, 17:09   #1
kostas's Avatar
Members Car: Octavia 1.8T 4x4 Hatch
Question ESP problem, throttle noises
Hello All,
On cold damp mornings when i turn the key once (before ignition) all the lights on the dashboard switch on (which is normal), however the esp light stays on even when i start the engine and i cant switch it back off, to do that i have to stop the engine and turn it on again, i had the ecu reflashed in the garage but it didnt cure it, does anyone know what this is?
could the ECU be faulty or affected by moist conditions and does that? or is it a porblem with the esp?
In addition, again during cold mornings, when i pull away and go into second gear at low revs (1-2k rpm) i get a rattling noise from inside the engine, this goes on for a few seconds or until i pick up revs. Anyone knows what this might be?
Any comments would be greatly appreciated, you can email me directly
kostas is offline
Old 01-06-2004, 17:11   #2
Tavia4x4's Avatar
re rattle: I would be concerned \ check that your oil level \ circulation is fine, as the rattling at low revs sounds very much like the cam chain going across the guide before VVT changes.
re esp, I would get ABS sensors checked, sounds like one \ wiring could be faulty.
Ian
Nice to be important, but more important to be nice...
Tavia4x4 is offline
Old 01-06-2004, 17:15   #3
kostas's Avatar
hi Tavia4x4,
thanks for your response, if any of these that yu suggest is fulty, wouldnt that show on a diagnostic check by the dealer on my ecu?
Kostas
kostas is offline
Old 01-06-2004, 17:19   #4
SimonT's Avatar
Members Car: very carefully
What code or descriptive text are you getting WRT the ESP? If your dealer won't tell you, find someone with VAG-COM or similar.
Si
SimonT is offline
Old 01-06-2004, 17:21   #5
Tavia4x4's Avatar
Kostas, check your dipstick for oil level...
I would expect the 1552 to show a faulty sensor if a "permanent" fault, but if a wiring fault then maybe not (intermittant?) in terms of ABS sensors.
Ian
Tavia4x4 is offline
Old 01-06-2004, 17:23   #6
kostas's Avatar
Dear SimonT,
i dont get anything apart from the esp light staying on which i cannot switch back off unless i restart the engine, the dealer has just told me that he reset the ecu
kostas is offline
Old 01-06-2004, 17:25   #7
Tavia4x4's Avatar
Sounds like all he has done is "reset basic settings".
Ian
Tavia4x4 is offline
Old 01-06-2004, 17:29   #8
kostas's Avatar
yes he has, but wouldnt any faults show anyway?
kostas is offline
Old 01-06-2004, 17:30   #9
SimonT's Avatar
Originally Posted by kostas
Dear SimonT,
Hello again,
Your dealer may have reset the fault code, but it's obviously back . The code I was referring to can be found by a dealer with their equipment (faults which show a light (even intermittent ones) will be logged). Get this code.
Also, although it doesn't help much, Rob's thread here sprang to mind.
Si
SimonT is offline
Old 01-06-2004, 17:32   #10
SimonT's Avatar
Yes, as I said above (sorry, started replying before I saw your latest post). As an alternative, maybe someone local to you would be willing to hook up their VAG-COM.
Anyone near Reading with a 'pooter?
Si
SimonT is offline
Old 01-06-2004, 17:41   #11
kostas's Avatar
Cheers for that Simon,
I will look around and probably revisit my dealer, even though i think they will be of no use as always
kostas is offline
Old 01-06-2004, 18:12   #12
kostas's Avatar
Dear Tavia4x4 thanks for that,
i have checked the oil level along with the other fluids in the car recently and it was ok, if there was an oil preassure problem wouldnt that show on the dash?
kostas is offline
Old 02-06-2004, 09:23   #13
Tavia4x4's Avatar
The pressure and viscosity *should* show an error, unless it's just not circulating properly? How many miles since it's last oil change?
Ian
Tavia4x4 is offline
Old 02-06-2004, 13:29   #14
kostas's Avatar
Dear Ian,
the rattling has appeared when i first bought the car, since then i have covered around 11000, the car went in for a service (and oil change) at 10000 and they couldnt spot the porblem. If there was an oil pressure porblem, wouldnt they spot it or at least wouldnt it show on the dash?
kostas is offline
Old 02-06-2004, 13:55   #15
Site owner
ColinD's Avatar
Members Car: Roomster Scout
Images: 3
Is the steering wheel on straight?
It has been noted on other VAG cars that a misaligned steering wheel (only by a few splines) can interfer with a sensor on the steering thus leaving TC/orange light on. ESP and TC light are very similar and totally linked in the FWD ESP setup.
ColinD
1.9 Scout Roomster - Standard
www.BRISKODA.net :: Site Owner
E-Mail : webmaster at briskoda dot net
Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views.
ColinD is offline
Old 03-06-2004, 08:52   #16
kostas's Avatar
Thanks for that Colin,
Actually, the car tends to the left a bit when i leave the steering wheel, however, if that interfered with the esp light should it stay on all the time when i start the car?
It only does it some cold and damp mornings.
Thanks
Kostas
kostas is offline
Old 03-06-2004, 14:54   #17
kostas's Avatar
Hi Colin,
the car tends to pull very slightly to the left if i let go of the steering wheel, but it goes straight when i hold the steering wheel straight. I had the car aligned by the dealer but they admitted they couldnt get it straight (one wheel was 0.1 degrees misaligned), do you think that can cause the problem?
I will check with the garage, but they seem to know nothing
kostas is offline
Old 03-06-2004, 15:31   #18
Site owner
ColinD's Avatar
Images: 3
Kostas,
Sorry no I meant the steering wheel it'self. It's a condition induced occasionaly when a steering wheel has been removed and then put on a few splines of centre. Thus when the sensor thinks it's turning when it's actually going straight...I don't think it will be this. But might be worth asking the dealer if the steering wheel is dead center (5 mins job if that). Not the alignment of the wheels.
ColinD
ColinD is offline
Old 03-06-2004, 17:34   #19
kostas's Avatar
Thanks Colin,
I will check that with my garage.
kostas is offline
Old 10-06-2004, 17:29   #20
kostas's Avatar
hello, i ahve just picked up the car form the garage, thats what i was told:
ESP Light: faulty ABS ECU, to be replaced
Coil pack to be replaced
Rattle when cold: water pump faulty to be replaced
fortunately the car is still under warranty
Thank you all for your help
kostas is offline
Old 10-06-2004, 17:39   #21
SimonT's Avatar
That's very good news.
Water pumps are known to be weak.
I don't know the mileage of your car, but if it's anywhere near 60,000 miles you might consider having the cam belt changed at the same time. I know that when changing the cam belt, the water pump can easily be done at the same time. I don't know whether the reverse is true but it might save you a bit of money in labour if it is. If not, then scrap that last comment
And thank you for your PM.
Si
SimonT is offline
Old 10-06-2004, 18:51   #22
DGW
BRISKODA Staff
DGW's Avatar
The ABS+ECU for my 2002 4X4 costs £1166.99!
Denis
DGW is offline
Old 11-06-2004, 09:18   #23
kostas's Avatar
Dear Simon, the car has done only 11000m so still early for cambelt change,
Denis 1166£ for the ecu is a lot of money, thankfully the car is under warranty,
I should have realised that the skoda is a cheap car to buy compared to equivalent vw/audis, but it is as expensive to maintain,
Nevermind it is a good drive
kostas is offline
Similar Threads
Snow & salt or ESP fubars my 4x4 brakes ? Fabpreza Maintenance & Performance 15 08-03-2004 16:59
ESP - Is It A Waste Of Time ? Fabpreza Maintenance & Performance 54 24-12-2003 17:56
Sticking Throttle??? numskull General Car Chat 16 19-07-2003 22:11
Throttle Body Alignment KLB Maintenance & Performance 6 29-05-2003 12:56
Serious cold start problem Dutch4x4 Maintenance & Performance 6 28-04-2003 10:09
