Fabia winter tip...
This is a discussion on Fabia winter tip... within the Maintenance & Performance forums, part of the General Motoring Discussions category; From my experience last winter the Fabia washer & wipers system doesn't like 'extreme' cold - last winter two recurring ...
Old 25-01-2004, 15:45   #1
Off we go Mo
maffwilson's Avatar
Default Fabia winter tip...
From my experience last winter the Fabia washer & wipers system doesn't like 'extreme' cold - last winter two recurring problems:
1. The system's pipes fall off, leading to sudden total loss of screen wash ability, which with the amount of salt the Highways Agency is promising to chuck about, is not a nice situation to be in as the salt thrown up by others sticks on the windscreen.
2. The pump system ices up easily, which leads to a fuse blowing should it try and move ice through it when you activate the washers. This then leads to very strange behaviour on the windscreen wipers, where they only work on intermittent when you move the stalk 'forward', which normally activates the rear wiper (which doesn't function at all with the fuse gone). Again, not great in poor weather.
So before this cold weather we've been promised strikes, make sure you put plenty of screen wash that contains an anti-freeze (not diluted too much), in the washer reservoir and pump it through (dealer's suggestion to the probs outlined above).
maffwilson is offline
Old 25-01-2004, 19:10   #2
andy ellis's Avatar
Default
Use VAG screenwash 750mls in the2.5l standard tank gives you protection down to -16!
Fabia TDI PD100 "Q" and driving school car.
Citroen C4 Coupe 1.6hDi+EGS with disability adaptations.
andy ellis is offline
Old 25-01-2004, 20:13   #3
playing dadsie
Quinten's Avatar
Default
Which costs £2.37 inc vat from my local Skoda garage. They could have explained the dilution a bit better though... Thanks K
Awooga!!!
Quinten is offline
Old 25-01-2004, 20:16   #4
who...?
AndyC's Avatar
Default
Its down to -37c in Canada at the moment, I wonder what they use for screen wash there??
Andy C
AndyC is offline
Old 25-01-2004, 21:56   #5
andy ellis's Avatar
Default
Ah now if you use VAG screenwash I've calculated for a 2.5l furby tank.......
...................water (ml)......screenwash (ml)
summer..........2000.................500
-16...............1750.................750
-35...............1250................1250
-40................750.................1750
Old 26-01-2004, 19:43   #6
flyingscot's Avatar
Default
Apparently no screenwash in Canada at -37 as it would break the water bottle! Think of all the zealous cops dishing out £60 fines if that was here! Diesel in your tank would be frozen at that temp!
Colin
To come second is to be the first of the losers!
flyingscot is offline
Old 26-01-2004, 20:21   #7
DGW
BRISKODA Staff
DGW's Avatar
Default
Berlin temperatures went down to circa -20ºC in winter. I used a hefty dose of vodka as antifreeze in the washer bottle. It only cost a couple of dollars for a large (4 pt?) bottle from the American BX so was cheaper than the 'proper' stuff.
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg...
DGW is offline
Old 26-01-2004, 20:25   #8
redbaron's Avatar
Default
so thats why your such a windows licker is it Denis...
________________________________________
Some times I just feel like smiling.
redbaron is online now
Old 26-01-2004, 20:37   #9
Default
I don't know where but I've seen pictures of Russian truck drivers keeping fires lit under their trucks to keep the diesel from freezing. I know diesel has different ignition properties to petrol but none the less.
Rich.
Skoda Octavia RS
rich1068 is offline
Old 26-01-2004, 20:49   #10
roo
white car
roo's Avatar
Default
Just a tad, diesel gives off a vapour at 70oC (hence glow plugs and compression ignition to get it to ignite) whereas petrol gives off a vapour at +45oC. In theory you can use diesel to put out petrol fires but i would not do it (although i heard somewhere that is what they do on the oil rigs).
Jeff: Ambitious, but rubbish
Originally Posted by Douglas Adams
There is an art to flying, or rather a knack. The trick is to throw yourself at the ground and miss.
Jeremy Kyle, helping normal people feel superior since 2005
roo is offline
Old 26-01-2004, 20:54   #11
Steve vRS's Avatar
Default
I think you mean -45degC
I was at a lecture once where the lecturer explained that the ash on the end of a cigarette acted in the same way as the mesh in a flame arrestor. He then demonstrated this by putting out a Marlboro in a cup of petrol
Steve
From Tavia vRS 230bhp to Impreza WRX STi Version V Type R to Clio 182 Cup and now a vRS TDi Octy II in Lightning McQueen Red
Steve vRS is offline
Old 26-01-2004, 20:56   #12
Default
Steve
Did you get your coat?
Rich.
Skoda Octavia RS
rich1068 is offline
Old 26-01-2004, 21:06   #13
roo
white car
roo's Avatar
Default
no but i'll get mine, i pushed the wrong button (so much for two years learning car mechanics and having to take a fire course every year on the underground eh)
roo is offline
Old 26-01-2004, 21:44   #14
flyingscot's Avatar
Default
A guy gave a demostration of a CO2 fire extinguiser at 2pm on a hot day on a fire safety course. It really scared the **** out of me!
Colin
Old 27-01-2004, 12:58   #15
spinndrift's Avatar
Default
Had my mate Pug Deisel Turbo freeze up in the Scottish Highlands a few years back. We didn't bother lighting a fire under it - just stayed in and drank lots instead of coming home.
Rev. Andy
The Rallying Reverend
www.miniroadrunnerrallying.co.uk
No money for rallying makes Andy a dull boy
spinndrift is offline
