GFB Hybrid BOV (PICS)
This is a discussion on GFB Hybrid BOV (PICS) within the Maintenance & Performance forums, part of the General Motoring Discussions category; Just fitted a GFB Hybrid Blow Off valve(excellent quality piece of kit) to my brothers Octavia VRS.Decided to go for ...
Old 28-09-2004, 15:08   #1
Just fitted a GFB Hybrid Blow Off valve(excellent quality piece of kit) to my brothers Octavia VRS.Decided to go for the Hybrid as it recirculates the pressure as std in normal driving conditions,then when the throttle is closed after hard acceleration,the excess boost is dumped to both atmosphere and inlet.
I had to make a small bracket to anchor the BOV to, to ensure it cleared the plastic inlet cover but other than that it was a quick and easy job
So far there have been no running problems and although its not the loudest BOV in the world, its plenty loud enough for my taste
Heres a couple of pics
aps remap,hpa short shift,r32 farb,coldside dv,abd tip+strut brace,blitz boost gauge,powerflex dogbone mount
MR G is offline
Old 28-09-2004, 21:52   #2
VIP
DaveU's Avatar
Is that installed the right way round???
Dave
Dave's new runaround ^
The Beast: 2001-2007 (now re-homed).
5 1/2 years of frightening the living daylights out of other road users and ashaming various high end cars.
DaveU is offline
Old 28-09-2004, 23:20   #3
ChrisYeow's Avatar
I don't think it is, when i installed my dump vavle it had to go in the other way but then i may be wrong
ChrisYeow is offline
Old 28-09-2004, 23:39   #4
DGW
BRISKODA Staff
DGW's Avatar
These fitting instructions posted on BugMod show the same BOV installed on its side compared with the pictures posted by MR G. That said, I haven't a clue which is right.
Denis
DGW is online now
Old 29-09-2004, 08:38   #5
BRISKODA Staff
SkodiRS's Avatar
Ooooo...that makes a nice sound......oh...it's the waste gate chattering.
Adrian.
SkodiRS is offline
Old 29-09-2004, 11:01   #6
Have to admit i thought the sound was more like the compressor surge i used to have in my GT Turbo ,so are you guys saying it should be mounted with the trumpet upright
MR G is offline
Old 29-09-2004, 12:08   #7
redbaron's Avatar
i think thats what they are hinting at...
try it the other way.. you wont damage anything...
________________________________________
Some times I just feel like smiling.
redbaron is offline
Old 29-09-2004, 12:14   #8
BRISKODA Staff
SkodiRS's Avatar
I can't remember which way Dave had fitted his...needless to say though.....you can tell if it's on the wrong way...you'll hear the waste gate chattering under acceleration.....not so good for your turbo I believe.
Adrian.
SkodiRS is offline
Old 29-09-2004, 14:21   #9
Yep, it was the wrong way round ,obvious if i'd thought about it ,anyway its definately connected correctly now and its much louder than i was expecting ,just out of intrest what boost pressure does a std VRS run at the turbo outlet??
MR G is offline
Old 29-09-2004, 14:27   #10
stathap's Avatar
Dave what have you done here
"Classic" Black Magic
stathap is offline
Old 29-09-2004, 14:31   #11
BRISKODA Staff
SkodiRS's Avatar
More a case of.....what he had done.
That said we're all infallable....I for one...edited posts by mistake.
Adrian.
SkodiRS is offline
Old 29-09-2004, 14:45   #12
stathap's Avatar
Erm, Adrian, the way the dv is positioned in Mr Gs last post is exactly the way round that Dave had his (albeit a different design) when he got scalded by the lads at AMD on the rolling road day http://www.briskoda.net/forums/showt...&highlight=amd (I think Dave's was an in joke (made me fall off the settee anyway)).
Mind you Mr G ... if it works like it is, sounds top and isn't detrimental to the performance then you're spot on and we can all learn a bit wooooosh paatisssh
stathap is offline
Old 29-09-2004, 14:51   #13
BRISKODA Staff
SkodiRS's Avatar
Pete,
IIRC, Dave didn't have his GFB DV fitted at the AmD day.......this is a hybrid DV...part BOV, part DV. From Dave's experience and others that I have read, this works fine with a standard car but not a remapped one.
Dave is running a Forge DV006...IIRC.
All my usual disclaimers apply.
Adrian.
SkodiRS is offline
Old 29-09-2004, 14:54   #14
stathap's Avatar
Mind you Mr G ... if it works like it is, then you're spot on and we can all learn a bit
Adrian,
I completely agree
stathap is offline
Old 29-09-2004, 14:58   #15
BRISKODA Staff
SkodiRS's Avatar
Adrian.
SkodiRS is offline
Old 29-09-2004, 16:46   #16
The way i understand it,at lower boost levels eg not foot to the floor,the piston only partially opens on throttle closure and 'dumps' the air back into the air filter pipe(inlet side of turbo).Then on full boost situations, when the throttle is closed the piston opens fully and allows the air to dump through both outlets(inlet and atmosphere) Is this correct ???
MR G is offline
Old 29-09-2004, 19:30   #17
VIP
DaveU's Avatar
Yup it is!
I fitted mine the wrong way round - and unlike the Forge 006 i have now it didn't actually work when installed back to front - although it did make perhaps the coolest noise ever heard - second only to my exhaust
GFB is OK as a DV but it just dont work with remapped cars! You will actually get a louder 'whoooooshh' noise with a recirc (like a Forge) and an induction kit like ABD / Carbonio or Jabba's new one.
...and we all make mistakes now don't we Adrian <cough>front discs</cough>
Dave
DaveU is offline
Old 29-09-2004, 23:08   #18
BRISKODA Staff
SkodiRS's Avatar
Adrian.
SkodiRS is offline
Old 30-09-2004, 07:48   #19
Still a ****
delcac's Avatar
Fancy putting the front discs on the back.
The Red Devil
delcac is offline
Old 30-09-2004, 08:44   #20
BRISKODA Staff
SkodiRS's Avatar
Even I'm not that bad.
Adrian.
SkodiRS is offline
Old 30-09-2004, 12:27   #21
VIP
DaveU's Avatar
Close - but not that bad
Dave
DaveU is offline
Old 04-10-2004, 13:39   #22
Nigel26's Avatar
(couldnt find the quota button so copied and pasted this from Daves post) "You will actually get a louder 'whoooooshh' noise with a recirc (like a Forge) and an induction kit like ABD / Carbonio or Jabba's new one".
Anyone got any details on this "new one" from Jabba !!??
i believe the standard boost on the octy vRS is 0.75 bar or 0.9 bar... one or the other, someone will correct me anyhow.
Sea Grey Mondeo Titanium X
Nigel26 is offline
Old 04-10-2004, 13:52   #23
BRISKODA Staff
SkodiRS's Avatar
Very similar to the Neuspeed indcution kit.......highly polished, lazer cut heat shiled which seals on the underside of the bonnet. Filters are paper...so no oil. Obviously replaces standard air box but uses the formers retaining fixure points. Also uses the standard input to the airbox.
I also have some ducting from the lower front grill (used for my Dynatwist previously).
Sooo what's it like......loud. Gives a nice deep, roarty induction sound.....and you can definately hear the DV venting. You can also hear the turbo spool up a lot more clearly as well.
Feels more responsive at low revs.
Cost: £230 inc fitting.
Expensive but quality of fit and finish very good.
Will post up some pics if I remember.
Adrian.
SkodiRS is offline
Old 05-10-2004, 11:17   #24
Nigel26's Avatar
(still cant find the quote button) "Will post up some pics if I remember"
You read my mind
Nigel26 is offline
Old 05-10-2004, 11:33   #25
KentStu's Avatar
Try the little "Reply" button on the bottom right of the post you want to quote
Stu
Yellow Octy RS & '58 Morris Minor Tourer Owner .......... not a hairdresser
KentStu is offline
Similar Threads
Briskoda Bruntingthorpe Pics (new) RichvRSRevo General Car Chat 11 08-06-2004 20:52
I got it back + pics for the sicko's devonutopia Off Topic and Chit Chat 23 02-02-2004 10:59
New Octavia - first pics Kay General Car Chat 133 23-01-2004 18:44
Hybrid Dv Fram Maintenance & Performance 2 27-06-2003 08:56
