This is a discussion on GSF Car Parts within the Maintenance & Performance forums, part of the General Motoring Discussions category; can anyone tell me if they have used GSF Car Parts, cheap car parts direct to you for anything for ...
| Briskodian Join Date: Jul 2008
| GSF Car Parts can anyone tell me if they have used GSF Car Parts, cheap car parts direct to you for anything for their Skoda. I am pricing up a new clutch and flywheel and they seem pretty cheap, does anyone have any experience of their parts - they good quality or a bit cheapo ? Thanks |
| Briskodian Join Date: Jul 2007 Location: Rugby, Warwickshire
| Re: GSF Car Parts GSF are very very good. Enough said?
__________________ ![]() 2003 Superb Classic TDI 130 - Project Diary - Updated 22/11/08 2006 Fabia vRS - Project Diary - Updated 11/10/08 |
| The Following User Says Thank You to Bluefox For This Useful Post: | chappers849 (11-08-2008) |
| Briskodian Join Date: Aug 2006
| Re: GSF Car Parts Excellent quality, usually the same make as OE but often better. They sell metal impeller water pumps and Dayco cambelts which last longer than the crappy Continental belts VAG fit which last only 4 years. The brake pads are Textar or ATE - same as OE. One of the major advantages of owning a VAG vehicle is the availability of pattern spares and software, due to these cars' high European market penetration. Going to VAG for fast moving spares is a sheer waste of money. rotodiesel. |
| Briskodian Join Date: Jan 2004 Location: Ireland
| Re: GSF Car Parts Another positive vote for GSF
__________________ Dear Lord.. The gods have been good to me. For the first time in my life, everything is absolutely perfect just the way it is. So here's the deal: You freeze everything the way it is, and I won't ask for anything more. If that is OK, please give me absolutely no sign. OK, deal. |
| The Following User Says Thank You to pdhealy For This Useful Post: | chappers849 (11-08-2008) |
| Re: GSF Car Parts just leaves me with another question. Anyone know of a good gargage or mechanic in or around the Bristol area that could fit the parts without boshing it like a dealer ? Thanks ![]() |
| Briskodian Join Date: Dec 2004 Location: Wotton-Under-Edge, Gloucs
| Re: GSF Car Parts Some GSF parts are OK, but others are a tad sub-standard imho- at least, that's the experience I've had with Corrado parts. Never bought anything for the vRS. Things like bushes, engine mounts, shocks etc seem to fail very quickly. VW Parts - Audi Parts are much better imho. Nearly all the parts are Febi/Bilstein which are at least as good as OEM, but cheaper. Always had brilliant service too. Maybe a bit too far for you, but Blake Services in Thrupp near Stroud are brilliant!
__________________ '05 Octavia vRS Estate::BMC::Forge: erformance Torque::Whiteline::Lifelong, long suffering Hammers fan |
| Re: GSF Car Parts Asked what make the parts were from GSF and he told me they were LUK and said that they were top end parts. Is that correct, are they ok ? |
| Briskodian Join Date: Dec 2004 Location: Hawkinge Kent
| Re: GSF Car Parts Yes LUK make pretty good clutches. |
| Re: GSF Car Parts thanks, while it is apart would you replace the slave cyclinder as well ? |
| | #10 |
| Re: GSF Car Parts Skoda Use LuK or Sachs for their DMF's in the MK II Octy IIRC and yes LuK are a big name.
| | #11 |
| Re: GSF Car Parts thanks, can someone tell me if the slave cyclinder should also be replaced at the same time ? Is the slave cyclinder inside or on the outside of the gearbox ? |
| | #12 |
| ECUless Join Date: Mar 2005
| Re: GSF Car Parts It is outside the gearbox and doesn't usually require replacement. |
| | #13 |
| Re: GSF Car Parts thanks very much |
| | #14 |
| Briskodian Join Date: Sep 2006 Location: Walsall
| Re: GSF Car Parts I've used GSF for years, and if you buy their OEM quality stuff it's very good. LUK supply VAG as an OEM: they are very good quality.
__________________ -- Chris ---------------------------------------------------- The Devil may care, but I don't mind. |
| | #15 |
| Briskodian Join Date: May 2008
| Re: GSF Car Parts I used these for spares on all my previous VW's. There tip top if you ask me & a damn sight cheaper than the main stealers! Its a |
| | #16 |
| Briskodian Join Date: Feb 2008 Location: leeds, west yorkshire
| Re: GSF Car Parts what is vag?
__________________ Fabia sport Soon to be unleashed |
| | #17 |
| Briskodian Join Date: Feb 2008 Location: ****-ryside
| Re: GSF Car Parts |
| | #18 |
| Re: GSF Car Parts
__________________ Black Octy vRS - 18"s - Jumbobox - Electric Pack - Factory fit. Revo stage 1, TFSI Fuelpump mod, Koni FSD's, Eibach prokit, forge short + side to side shifter, Maxtidot, OEM Bluetooth and Stu's cruise control |
| | #19 |
| Briskodian Join Date: Sep 2007 Location: Dundonald, nr Belfast
| Re: GSF Car Parts GSF also distribute Bilstein in the UK too, so they're a cheap source of dampers and springs.
__________________ 2008 Vauxhall Vectra SRi 1.8VVT, 140hp of pure tarmac ripping power. Vectra owner and driver by night, Octavia driver by day... |
| | #20 |
| Getting a flat! Join Date: Dec 2007 Location: Redruth, Cornwall
| Re: GSF Car Parts |
| | #21 |
| Re: GSF Car Parts
| 10% discount at GSF Car Parts | Quinten | Suggestions & Site Issues | 7 | 26-02-2007 10:56 |
