This is a discussion on Hard changing springs? within the Maintenance & Performance forums, part of the General Motoring Discussions category; any special things to think about?...
| Briskodian Join Date: Oct 2002
| Hard changing springs? any special things to think about? |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| nope, dead easy, just make sure they don't pop out of the compressors. The rears are very very easy to do.
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian Join Date: Dec 2002 Location: Stockholm, Sweden
| I found the passenger side front spring to be the worst to remove. Well, not the spring but the whole damper since the driveshaft hits the subframe when you lower down the supension. I took off the brake disc and loosened the driveshaft to be able to remove the damper. I think it was a little bit more work than I expected... |
| Christian Did you have the front suspension geometry checked after changing the springs/dampers, or wasn't it necessary? Time to check the dog's dampers........ ![]()
| You'll need to get the geometry done if you have lowered it. I assume you have as the Swedes seem to love trying to get the sump to hit the road! ![]()
| Nope, didn't change/check geometry since no camber adjustment is possible. According to my friend and mechanic (who did most of the work) it's not necessary, and I trust him... I think Havn't managed to crack the sump yet ![]() |
| | #7 | |
| Quote:
| Changing number plate bulbs | humsk | Maintenance & Performance | 5 | 18-03-2004 20:57 |
| which springs | mqvrs | Maintenance & Performance | 2 | 12-11-2003 08:47 |
| Vrs Performance Springs | nat | Maintenance & Performance | 16 | 03-09-2003 17:19 |
| Which lowering springs? | FabiaTDi | Maintenance & Performance | 24 | 15-05-2003 17:33 |
| Lowering Springs - Advice | devonutopia | General Car Chat | 23 | 08-05-2003 11:16 |
