This is a discussion on Help Airbag Warning Light Staying On within the Maintenance & Performance forums, part of the General Motoring Discussions category; hi there im new to this site as only just purchased my skoda felicia 1.3 lxi (R) . Iam having ...
| Briskodian Join Date: Jun 2003 Location: uk sw
| Help Airbag Warning Light Staying On hi there im new to this site as only just purchased my skoda felicia 1.3 lxi (R) . Iam having a bit of trouble with the airbag warning light coming on and staying on could some one tell me what could be up with it or where to look to check it out. This would be much appreciated many thanks in advance alanelf |
| Briskodian Join Date: Apr 2003 Location: u.k
| my advice to you is to take car to dealer for them to plug car into machine there a few possible faults low/high voltage (under or overcharging) a problem with the slip ring (a ring that sits under the steering wheel) a problem with the wiring or the airbag it's self faulty please don't attempt to repair your self as if wires are shorted out that will cause airbag to deploy and if you was sitting in the car at the time well you won't be here anymore. if you do feel the need to take a look at the airbag system please disconnect battery. when finished turn ignition on shut door (nobody in car) and refit battery terminal (for you own protection) hope this helps big k.
__________________ how can me find a jet engine for me rapid ? |
| How mant forum members does it take to change a light bulb? | roo | Off Topic and Chit Chat | 15 | 21-06-2005 20:46 |
| Airbag warning light problem | tfboy | Diagnostics & VAG-COM | 8 | 14-03-2004 01:21 |
| How Many Forum Members Does It Take To Change A Light Bulb? | Tavia4x4 | Off Topic and Chit Chat | 15 | 30-10-2003 17:09 |
| Oil Warning Light | johanny.medina | Maintenance & Performance | 5 | 09-10-2003 11:17 |
| Engine Warning Light | SilveRS | Maintenance & Performance | 3 | 09-08-2003 21:08 |
