This is a discussion on Help on Braking upgrade/performance within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi all, Does anyone know what kind of calipers (front and rear) the Fabia 1.4 16v has? Has anyone tried ...
| Briskodian Join Date: Nov 2003 Location: Athens, Greece
| Help on Braking upgrade/performance Hi all, Does anyone know what kind of calipers (front and rear) the Fabia 1.4 16v has? Has anyone tried the TarOx 6-pot calipers on a Fabia 1.4 16v with 15’ rims? And if yes which type since I cannot find any particular type for fabia in the tarox catalogue Apart of the above has any tried the EBC Brake Plates (Turbo Grooved)/Pads (Green or other) or Black Diamond Disk plates? What were the gains if any? And last what brake fluids should I use for fast road driving? Generally how Can I improve my braking performance (taking in mind the 15’ rims)? Thanks |
| Be impressed if you could get a 6-pot kit under 15" rims, but, as always, I stand to be corrected ![]() Best way to improve performance is to get a dot 4 performance brake fluid, something like Ferrodo DS2500 pads and replacement performance discs if they'll fit. This should cost you a few hundred and be a significant improvement for road driving.... Chris
| Oh, and don't touch the EBC pads, unless you go with the EBC disks as you'll end up warping them! ![]() Chris
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
| I belive Stimps has a 1.4 16v and he has just gone down the Black diamond discs and predator pads. but i reccomend DS2500.. very very good brakes (except im running them on 312mm brakes) |
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
Images: 3 Thanks: 24
| No need for 6pots on road IMHO. Fluid and pads! IIRC pots = stability at high speed. thats why DB7's have 10's and so on far higher speeds to kill. TBH the 2's on the RS and 4x4 were fine....DS2500's all round drilled and grooved discs and your laughing, screaming or head butting the dash Normally in that order eh Huck ![]() So given my very limited knowledge same sized discs and pads a 2 potter should stop aswell as a 4potter. That might be rubbish, but hey ho...only fell unsafe on the 2's on road under 6+ hard braking onto suregrip. But the fluid was 15months old OEM stuff. Change fluid and not a 200ml top up and yet to find there limits...roll on saturday ![]()
__________________ ColinD - 97/100 Limited Edition Octavia vRS < For Sale £2500 Going to Dealers on the 29th... www.BRISKODA.net :: Site Owner. E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. Last edited by ColinD; 20-04-2004 at 14:54. |
| Briskodian Join Date: Jan 2003 Location: Colchester
| Indeed I have, Col ![]() Black Diamond Grooved Discs front & back & matching B.D. Predator Pads. Also changed the brake fluid. The parts are as listed for a fabia 1.4 16v, and they looked to be a direct swap for the OEM brakes. I changed the wheels at the same time so can't really say if they'd fit with 15"s, but my fabia came with 14" steels originally... Make some enquiries first, but I'd say they'd fit ok... Ferodo Pads are well liked by other members btw...
__________________ Steve « Nature Green 1.4 16v Fabia Comfort » |
| I will probably go ahead with B.D. combis but I was curious if there will be any problem with the ABS? will it be affected in anyway? |
| | #8 | |
| Briskodian Join Date: Sep 2003
| Quote:
Are you sure they aren't singles? ![]() Oh, and you have a txt ![]()
__________________ Si | |
| | #9 | |
| Quote:
| | #10 |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| Yep, they are single pot hook n grab callipers
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Left foot braking? | JSTdi | Maintenance & Performance | 6 | 23-03-2004 01:21 |
| Braking Judder & Sticking Clutch Pedal | rollerskate96 | Maintenance & Performance | 3 | 12-01-2004 10:30 |
| Diesel Engine Braking? | KLB | General Car Chat | 5 | 15-09-2003 20:19 |
| Braking At High Speed | Witchfinder | Maintenance & Performance | 8 | 23-07-2003 14:59 |
| Braking warning following a long wet drive - RS ? | stopan1j | General Car Chat | 16 | 09-04-2003 17:19 |
