This is a discussion on Help! I've "Jasoned" my foglamp covers! within the Maintenance & Performance forums, part of the General Motoring Discussions category; With hindsight, it probably wasn't a good idea to try and change my foglamp bulbs in the cold, with gradually ...
| Discordian Join Date: Jan 2003 Location: Newport, Newport - so good the Post Office named it twice
| Help! I've "Jasoned" my foglamp covers! With hindsight, it probably wasn't a good idea to try and change my foglamp bulbs in the cold, with gradually numbing fingers... Anyway, all went well until I tried to put the covers back on. One by one, they leapt out of my fingers, and are now hiding out of sight - one somewhre near the horn on the nearside, and the other somewhere down by the intercooler. Is there any way I can retrieve them without taking the car half to bits?
__________________ Mike |
| Briskodian Join Date: Oct 2003 Location: Woking
| You need a small child to retrieve them for you. They'll be a pig to get.
__________________ Rev. Andy The Rallying Reverend www.miniroadrunnerrallying.co.uk ![]() Engine data aquisition is fun |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Mike, I can't remember rightly...but do the right/left small grills pull out? If so and you have Des-esque sized (small ) hands, then you might be able to get at the errant pieces. If not you probably will have to remove the arch liners to get inside the bumpser. HTH. Adrian.
__________________ Adrian. |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| Remove the grills at the bottom of the bumper - they should just pull out. Hopefully you can then reach them. Oh if you need to remove the centre one, its push (or kick ) rather than pull. |
| Briskodian Join Date: Jan 2003 Location: Rochdale
| ![]() ![]() But seriously...you need to find out where they are, and either get a long poking device, or get in front of the car and try reaching around the underside of the bumper... Rob. |
Images: 5 Thanks: 76
| ![]() Nice to see my shenanigans with headlight covers has meant my name is no longer a noun but now a verb. ![]() To Jason, one Jasons, he Jasons, they Jason. ![]()
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: Dec 2003
| I was going to ask about the lights actually, me being a newbie to the vRS you have 3 in each front cluster? what do each of them do? 1 looks like a traditional light, the other two look more like a lens? and generally are they ok..powerful enough? Last edited by FTM; 16-12-2003 at 16:31. |
| The one on it's own (inside) is the main beam bulb. The two above each other are the sidelight bulb (below) and the dipped beam bulb (above) - at least I think so (just confirmed by looking at a piccie of mine) The main beam is powerful enough when using non-standard bulbs. ![]() and the dipped beam is powerful when using philips vision plus bulbs. ![]()
| hmm mine look like this I am sure (Octavia vRS) http://news.kak.net/bilder/skoda.tes...avia_rs38s.jpg incidentally some nice piccies on that site...cannot understand the language but the piccies are nice...I have no idea what it evens looks like lit up inside in the dark...just another thing to look forward to ![]() http://news.kak.net/modules.php?op=m...rticle&sid=905 |
| | #10 |
| They look like Xenon lights. ![]() I shan't even go there because I'm not familiar with how Xenons work at all. sorry
| | #11 |
| actually I just checked and looked closer and I am wrong...the one closest to the grille looks like a normal headlight but the light closest to the indicator looks like one of those lens types...I dont think it is split into 3 like that picture just one of those other things that skipped my mind...I was still buzzing from the drive oh well I will just wait and see |
| | #12 |
| Thanks, guys - problem solved ![]() The nearside one was accessible once I removed the grille (thanks for the tip, Jon) . The offside one was a bit more difficult - it was on a sort of "shelf" above the intercooler. I could see it, and even grab it with ine of those "long flexible grabber" things, but couldn't get a firm enough grip to retrieve it. I managed to manouevre it to a position where I could reach it with my hand, though. Didn't lose much skin ![]()
| | #13 |
| Well - this is a piccie of the dipped beam / sidelight arrangement on my car - blue sidelights below, and the vision plus bulb above. The main beam bulb is out of shot though... As far as I know the vRS comes with the same arrangement, or at least very similar ![]()
| | #14 |
| Briskodian Join Date: Jul 2003 Location: Peak District
| the lens in the headlamp is the fog light and the main beam bulb is comined low and high beam IIRC |
| | #15 |
| C+ à Paris! Join Date: Sep 2003 Location: Tilehurst, Berkshire
| I think the lights on those are Xenons as Jason suspected. If you look at this pic: http://news.kak.net/bilder/skoda.tes...avia_rs77s.jpg you'll notice there's only the dash brighness adjuster, and not a dipped-beam level adjuster which you only get on normal halogen bulbs. ![]() May of course be wrong having never owned or looked at a tavia vrs in detail ![]() Edit: having looked at more pictures, I think I've got it completely wrong ![]()
__________________ Xavier |
| | #16 |
| Briskodian Join Date: May 2003 Location: Deepest Fenland
| Xavier, you were right first time. Xenons indeed. Headlamp washers are also a bit of a giveaway (yes, Denis, I know you can get them on other models). The lamp cluster looks rather different on a more common Octavia (<ducks and runs for cover>). ![]()
__________________ Howard Octavia TDi L&K in Cayenne Member of the exclusive "Social Misfits" and "Objectionable To55ers" community |
| | #17 | |
| Briskodian Join Date: Nov 2003 Location: Hampshire
| Quote:
Lee | |
| | #18 |
| yes they are legal for 2 reasons: 1. They are e marked for use as sidelight bulbs 2. They illuminate white rather than blue |
| Seat covers for Fabia vRS | vrsfab | General Car Chat | 55 | 01-09-2005 21:22 |
| furby vRS seat covers | kenny | Styling and Car Care | 15 | 25-02-2004 20:52 |
| Seat covers for Fabia vRS | Alan Guest | Styling and Car Care | 2 | 26-12-2003 18:50 |
| Standard Seat Covers & Side Airbags... | shaman | Maintenance & Performance | 9 | 26-09-2003 17:18 |
| RS shedding wheel-nut covers | Freakcrab | Maintenance & Performance | 15 | 18-02-2003 18:06 |
