This is a discussion on Hesitancy under acceleration... within the Maintenance & Performance forums, part of the General Motoring Discussions category; SWMBO has an A3 1.8T which uses the 150 bhp AGU motor. Now for the last couple of months I've ...
| Briskodian Join Date: May 2003 Location: North East
| SWMBO has an A3 1.8T which uses the 150 bhp AGU motor. Now for the last couple of months I've noticed a slight hesitancy under load. It's quite intermittent and occurs at any engine speed / temp etc and usually lasts a second or so. The plugs were changed about 6k miles ago, I've just cleaned the MAF and replaced the DV for good measure. VAG-COM hasn't flagged up any error codes. Anyone any ideas? |
| Anyone........??? ![]() |
| Briskodian Join Date: Aug 2003 Location: Warrington
| I would say my Octavia suffers from that all the time. Floor-it, seems to start accelerating, but doesn't, waits, then the revs start to rise. It is very noticeable in 2nd, say when waiting for an overtaking opportunity and hanging in 2nd gear at 30mph, quickly flooring it then will result it a definate pause immediately after the first "lets-Go" response. |
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
Images: 3 Thanks: 24
| You could try resetting the throttle body, mine was a bit poorley even after a service. A quick throttle body alignment and she's going great now. Can be done via vagcom or the boot open pat your tummy method.
__________________ ColinD - 97/100 Limited Edition Octavia vRS < For Sale £2500 Going to Dealers on the 29th... www.BRISKODA.net :: Site Owner. E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. |
| | #5 | |
| Briskodian Join Date: Jan 2004 Location: Sheffield
| Quote:
| Don't talk, drive! Join Date: Feb 2003 Location: The B roads of Britain
| Not sure that applies to AGU engines... |
| Briskodian Join Date: Jan 2003 Location: North Manchester
| Hi Jimmy, any update on this issue? My RS has just started with this problem. I took it to the dealer this morning so they could plug in their diagnostics tool and they said it had an error code which they will investigate. I don’t think it is an obvious problem as they had some idea of what to check for but said I would need to book the car in for some investigation work. I will post back with my findings, probably in the next couple of weeks as I will need a curtsey car and that delays things a bit. The dealer said I would be ok to drive as normal but may experience some intermittent hesitation. Sounds like the same issue as your Audi. |
| | #8 | |
| Quote:
![]() If you get any joy please post it up and I'll do the same if I get to the bottom of it in the meantime... | |
| Hi mate, will keep you posted. The dealer took a printout of the error code so at least they have a record of it when my car gets booked in. |
| | #10 |
| Update: Fuel Regulator valve replaced. I can't remember what the original error code was, but apparently the fuel regulator valve is suspect if your car has these symptoms and all hoses and conections are ok. Last edited by SilveRS; 16-12-2004 at 19:17. Reason: Update on fault |
| | #11 |
| Now getting worse. Still no fault codes showing up on VAG-COM and still very intermittent. Might be worth changing the Fuel Reg Valve. Anyone with ETKA have a part # and price if possible? Bloody Audis...... ![]() |
| | #12 |
| Just to add when I originally ran VAG-COM after the problem occurred I got the following fault code: Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 06A 906 018 AQ Component: 1.8L R4/5VT MOTR HS D03 Coding: 04000 Shop #: WSC 06313 1 Fault Found: 16885 - Vehicle Speed Sensor: Implausible Signal P0501 - 35-10 - - - Intermittent Readiness: N/A As mentioned previously I cleared this code at the time and it hasn't re-occurred even though the symptoms are getting worse. |
| Fabia vRS drivers seat creaking under acceleration | pbirkett | Maintenance & Performance | 13 | 15-10-2004 22:10 |
| Vibration on Acceleration | Broadsand | Maintenance & Performance | 5 | 14-11-2003 15:48 |
| Hesitant Acceleration | Digby | Maintenance & Performance | 2 | 09-07-2003 23:44 |
| "Judder" on acceleration? | kgb | General Car Chat | 14 | 17-12-2002 11:05 |
