HID conversion kits
This is a discussion on HID conversion kits within the Maintenance & Performance forums, part of the General Motoring Discussions category; help please anybody after a really good re-map 212bhp, a stainless zorst and k+n panel filter giving tons of smiles ...
Old 01-11-2007, 22:54   #1
HID conversion kits
help please anybody after a really good re-map 212bhp, a stainless zorst and k+n panel filter giving tons of smiles per gallon in the 2001 octy i thought i might treat meself to a hid xenon conversion kit seeing as it is now officially dark all day, i trawled the net doing me homework due to being a lot of a novice then a mate mentioned the legalities of kits. i have been told i need an H4 bi-xenon 6000k kit but after reading threads today i am even more confused some say"ace" some say"poo" some say "illegal" does anyone have experience or a definitive answer cos if i dont spend the money soon the missus will take the money and spend it on make up and things!
splodge is offline
Old 02-11-2007, 00:04   #2
The Stig
Mater's Avatar
Re: HID conversion kits
Legally your not supposed to do it.
search on here its been brought up in a thread before. although if you are going to then i recommend Hids4u.co.uk they seem to be quite knowledgable and will be able to help you further
Carl
"And when he gets to heaven to Saint Peter he will tell... One more Soldier reporting Sir... I've served my time in Hell"
Mods done so far : Revo Stge 2, Forge Adjustable Spacer, Forge Diverter Valve, Miltek CBE, Evoms, Stu's Cruise , Autotech Fuel Pump, Xenons Upgrade, Koni FSD, Eibach Springs, Forge Short Shifter, VF Torque Arm Insert, NGK Iridium Plugs, Sachs Clutch & Flywheel, MFD3
Mods to come: KO4 Conv, LSD, Big Brakes
Mater is offline
The Following User Says Thank You to Mater For This Useful Post:
splodge (03-11-2007)
Old 02-11-2007, 00:11   #3
Fezboy's Avatar
I was quoted £200 all in fitted local to me and in the leaflet about the kits it even said they were not legal
I just went to Halfords and got some super bright bulbs £14.99 each but BOGOF
They lights are twice as bright across the road at night and you can see so much more along the little lanes
Octavia VRs ***SOLD***
The futures somkey! The futures diesel
Fezboy is online now
The Following 2 Users Say Thank You to Fezboy For This Useful Post:
splodge (03-11-2007), VeeKar (02-11-2007)
Old 02-11-2007, 10:51   #4
KLM
KLM's Avatar
130 watt rallye bulbs. £20 from Halfrauds. Fitted mine 3 weeks ago.
All the light you will ever need.
Mark
KLM is offline
The Following User Says Thank You to KLM For This Useful Post:
Old 02-11-2007, 11:29   #5
mattbeef's Avatar
There is a massive thread about these on the seatcupra.net forum.
the top and bottom of it is this.
1) they are illegal as they aren't E marked
2) they will give you bad light depending on the design of the head lamp glass and the reflector (Octy's should be ok)
3) as long as they pass on the MOT then no one will ever know that they are illegal
4) if they are OEM then they have to have head lamp washers. The part about self leveling is a bit of a grey area as you can get round it by using the adjuster in the car.
Now if anyone else knows something else then feel free to chip in
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
The Following User Says Thank You to mattbeef For This Useful Post:
Old 02-11-2007, 13:31   #6
EU law states that if HID's are fitted, they must be in CE marked housings, which have been approved for use with HID bulbs, have to have headlamp washers, and must be automatically adjusted by a system linked to the rear suspension of the vehicle. The twiddly adjuster **** on the dash is not an acceptable alternative.
But no-one will ever know!
Still not sure of the legal implication of fitting HID main bulbs to an Octy 2 that has factory Xenon dip beams!
Phil
My Car - 2.0 TDI Octavia L&K
My Toy - 95 Corrado VR6 STORM
SWMBO's - 55 Navara
storm monkey is offline
The Following User Says Thank You to storm monkey For This Useful Post:
Old 02-11-2007, 14:06   #7
KenONeill's Avatar
My understanding of the E-mark situation seems to differ slightly here. AIUI the lack of an E-mark means that it is illegal for the motor trade to fit HIDs for you, but you can do it yourself without actually breaking the law.
KenONeill is offline
The Following User Says Thank You to KenONeill For This Useful Post:
Old 02-11-2007, 14:13   #8
kynastonp's Avatar
Mark
are these lamps e marked ?
kynastonp is offline
Old 02-11-2007, 15:42   #9
woodenspatulas's Avatar
ive had some in my vectra for ages, even went through the mot with them in. properly adjusted and bulbs which arent mega mega power or blue shoudl be fine.
in fact i found using the rally type high output bulbs got me flashed by people most nights. now with the hids in i dont get flashed at all
Where has my sig pic gone????
woodenspatulas is offline
The Following User Says Thank You to woodenspatulas For This Useful Post:
Old 02-11-2007, 15:44   #10
Phil
actually thats only if your car was FACTORY FITTED with HIDs. if they are retro fitted you do not need auto adjustment. as long as your beam patterns are good then you wont have a issue. but as with most mods, some setups are better than others and some MOT testers are different to others too.
Old 02-11-2007, 17:24   #11
KLM
KLM's Avatar
KLM is offline
Old 02-11-2007, 19:31   #12
vindaloo's Avatar
One question worth posing is this. I import a car from Japan or OZ. It has installed RHD factory HIDs. But that model of car is not sold in the UK.
Would they pass it through SVA? Assuming model report and other bolox exists.
For an EU or UK car. Could you SVA the car with a HID retro-fit or complete custom styling, including be-spoke headlight outer lenses?
The DETR "Official statement" letter thing that's been circulating seems overly authoritarian and beaurocratic. And maybe not entirely based in proven case law.
I think that even with a H4 conversion on an older car. Should you stick with "halogenesque" colour temperatures, and there's not too much glare, no one will bat an eyelid. It'll likely pass an MOT.
J.
Slowly turning the planet sooty.
vindaloo is offline
Old 02-11-2007, 20:47   #13
dstev2000's Avatar
I think most HID kits will be OK as long as you don't go mad with the K rating of the lamps, keep it below 8000K or you'll stick out like a sore thumb, one die hard traffic officer could make your life pretty difficult otherwise. I found the rear reflector in the Octavia I wasn't well suited to a HID lamp and it fired a lot of the light upwards. If you have the ellipsoidal projector lenses you will achieve better results with the beam output.
With regards to the higher rating rally bulbs, bear in mind they are typically DOUBLE the wattage of standard lamps and therefore draw around twice the current putting your wiring loom under great strain. There is also the issue of the heat generated by the uprated bulbs and it's effects on the reflectors and plastic lenses.
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
The Following User Says Thank You to dstev2000 For This Useful Post:
Old 02-11-2007, 21:27   #14
Illegal, best not to fit them. I fitted upgraded xenons and was very impressed search threads for NightBreaker to see my comments if interested.
juicey is offline
The Following User Says Thank You to juicey For This Useful Post:
Old 02-11-2007, 22:39   #15
dstev2000's Avatar
Also, there is a world of difference and confusion with bulbs advertised as 'Xenon'.
Proper Xenon HID bulbs are "High Intensity Discharge" and involve using an electrical arc and xenon gas to achieve the enhanced light output.
A lot of the advertised 'Xenon' bulbs are in fact normal incandescent bulbs with a small quantity of Xenon gas to alter the light output colur by a small quantity but will never come close to the output of Xenon HID's.
Incandescent halogens are pretty good these days but have more or lesss reached the limits that the technology can offer. LED's will provide the lighting of the future and will also make HID obsolete.
SWMBO's: MY08
vRS TDI - Standard
Old 02-11-2007, 23:03   #16
V5-Steve's Avatar
Thumbs up Re: HID conversion kits
I have a Bosch HID setup in my Fabia, I must say the light output is fantastic but they do seem to throw a lot of light away from the road. This is on standard lights so I need to find some that will stop the light going up and outwards away from the road. Anyone got ideas on these lenses, sorry to hijack the thread. But get them as they make such a difference
V5-Steve is offline
Old 02-11-2007, 23:16   #17
VeeKar's Avatar
Was looking at these the other day and thinking do they really???
So thanks for the vote of confidence
How on earth do they get their Halfrauds reputation I'll never know
VeeKar is offline
Old 02-11-2007, 23:27   #18
deleted
fatbob is offline
Old 02-11-2007, 23:35   #19
dstev2000's Avatar
[quote=fatbob;1070073
Oooh ah like a good flash [/quote]
Dirty bugger!
There are laws against that sort of thing
SWMBO's: MY08
vRS TDI - Standard
Old 03-11-2007, 00:44   #20
Fizzy Bubblech
mikeSM56's Avatar
Retrofit HiD's
Yes you can fit them to any car But they'll be illegal! In time the car will fail it's MOT or worst case you could be served with a roadside prohibition notice.
If factory fit HiD's are fitted you can retrofit the mainbeam. Legislation centres on dipped beam.
Legal requirements are: Projector/Pre focused headlamp unit as fitted to Octy 2, Headlamp wash or wash/wipe & Automatic self levelling in lamp, Rear suspension is an acceptable alternative.
If you do fit a set, Enjoy them while you can.
As for colour temp the rule of thumb is the lower the better, The lower the temp the more light the capsules emit.
OEM are 4100K-4300K aim for 5000K/6000k, 8000k and above will only draw attention (The wrong type)
mikeSM56 is offline
The Following 3 Users Say Thank You to mikeSM56 For This Useful Post:
KLM (05-11-2007), splodge (03-11-2007), storm monkey (05-11-2007)
Old 03-11-2007, 09:37   #21
Originally Posted by mikeSM56 View Post
Retrofit HiD's
but both mine and my missus's cars passed MOTs with HIDs in. ive never been pulled over with them or find myself being flashed by oncoming motorists ( and lets face it if you get flashed all the time eventually you will be flashed by a copper too!)
with retro fitting there is no concrete legislation. as long as you have a beam pattern that accptable by a mot station theres nothing wrong. my light output is much better now, and therefore i have better vision at night. thats the main reason behind me putting them in. i think the real issue is with the older type lamps which have the pattern lens at the front of the light (ie where the glass is) these seem to suffer with bad pattern when combined with HIDs.
i think the whole issue with HIDs is the same as tints on the front side windows. its hit and miss to weather anyones going to get pulled. act like a moron or drive a overly loud or cavvy car and prepared to be pulled and scrutinised! also there will always be camps of people for and against them, but then thats what makes the world a interesting place!
Old 03-11-2007, 10:12   #22
Fizzy Bubblech
mikeSM56's Avatar
I personally think HiD's are best thing since sliced bread, It was the ability to specify them on the Fabia that helped in my decision to buy one. I just don't want to see anyone fall foul of the law after retrofitting a set. But again there's always an inherent risk in one form or another in any changes you make to your car away from standard.
mikeSM56 is offline
Old 03-11-2007, 13:11   #23
spot on. i even declared mine on insurance and they said it dosnt matter of count as a mod! (bit disapointed at that as i now have so many mods from stanard i felt like they were taking something away! lol!)
as you say its down the the individual to choose and justify the risks. i personally keep the bulbs boxes and some spare normal bulbs in the boot. IF i was stopped i would simply swap them over there and then to apease the copper.
Old 03-11-2007, 14:40   #24
ultra_joel88's Avatar
Retro fitting them to PROJECTOR style lights such as on your roomster is fine.
Technically, they ARE illegal. But its pretty unlikely you'd get caught unless they were incorrectly aligned.
HOWEVER fitting them to the Dual Epsilloid style lights such as on the standard FABIA 1 lights is VERY DANGEROUS as it will scatter the beam pattern not concentrate it.
'04 Fabia VRS - 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints
ultra_joel88 is offline
Old 03-11-2007, 15:08   #25
simonsheil's Avatar
The isuue on legality is unanswered as there has never been a test case to prove it. It will only fail an MOT if the alignment is out but so can normal bulbs.
The department of transport state they are illegal as mentioned due to no E mark, however, there is a strong argument this only applies to the vehicle manafacturer and not after market accessories (do seat covers need E marks). Until a case goes to court there is no test case either way, hence legality has not been established.
simonsheil is offline
The Following User Says Thank You to simonsheil For This Useful Post:
