How do the 4 versions of the 1.8T engine fitted to the UK Octavia differ?
This is a discussion on How do the 4 versions of the 1.8T engine fitted to the UK Octavia differ? within the Maintenance & Performance forums, part of the General Motoring Discussions category; The following versions of the 1.8T engine can be found fitted to the UK-spec Octavia with manual gearbox: AGU 110KW/150bhp ...
Old 02-07-2003, 20:05   #1
DGW
BRISKODA Staff
DGW's Avatar
AGU 110KW/150bhp Octavia FWD 10/96 > 07/00
AUM 110kW/150bhp Octavia FWD 08/00 >
ARX 110kW/150bhp Octavia 4X4 08/00 >
AUQ 132kW/180bhp Octavia vRS 12/00 >
Dealing with the 3 current engines first, the AUM, ARX and AUQ share the same block, cylinder head, internal parts, intake system and throttle valve control unit, turbocharger, charge air cooler, exhaust manifold, injectors, spark plugs, lubrication system and fuel system (excluding fuel tank etc). Apart from the fact that the ARX (4X4) has a different return oil line for the turbocharger, and the AUQ (vRS) one different boot (rubber seal/pipe) on the charge air cooler, the 3 engines are identical. The ECUs for all 3 engines do however differ, as do the exhausts. The same clutch is used on all 3 engines (and by the AGU). The AUQ is fitted with a different crankshaft impulse sender to the AGU, AUM and ARX; and the AGU and AUQ use the same knock sensor and harness, while the AUM and ARX both use a different anti-knock sensor.
The AGU was fitted to the UK-spec Octavia 1.8T FWD between 10/96 and 07/00 and remains in production for other markets. Whilst the engine is substantially the same mechanically as the AUM, ARX and AUQ, the cylinder block and pistons are different, as are the cylinder head with valves and camshaft. Specifically, the cylinder head, camshafts, pistons, con rods and bearing shells are different, but the crankshaft, vibration damper, flywheel and clutch are the same. Other differences include the cable throttle, smaller injectors and turbocharger, and the absence of VVT. These differences mean that it is not as tuneable as the later versions. Moreover, unlike the later engines, the AGU was not designed for variable (extended) service intervals.
NB. The ARX initially shared the same turbocharger as the AGU, but from May 2001 is fitted with the same turbocharger as the AUM and AUQ.
DGW is offline
Old 15-08-2003, 12:30   #2
Crossdresser
Quinten's Avatar
Below is another brief overview of various 1.8T engines. This is not a comprehensive overview, but it will show the differences between the main engines used by Skoda and the other VAG brands.
AGU
Skoda Octavia 1.8T FWD (Elegance, L&K), 10/96-8/00
Also found in: Audi A3 1.8T and Volkswagen Golf GTI (earlier models)
Output: 150 hp
Drive: FWD
Emission: Non-VVT, EU3
Throttle: cable
Injectors: small
Turbo: K03
Gearbox: EVS, EGY
AUM
Skoda Octavia 1.8T FWD (Elegance, L&K), 8/00-now
Also found in: Volkswagen Bora 1.8T and Volkswagen Golf GTI (updated models)
Output: 150 hp
Drive: FWD
Emission: VVT, EU4
Throttle: drive-by-wire
Injectors: big
Turbo: K03sport
Gearbox: EBN, ENJ, ESV, FDC
AUQ
Skoda Octavia RS, 8/00-now
Also found in: Seat Leon 20VT Topsport
Output: 180 hp
Drive: FWD
Emission: VVT, EU4
Injectors: big
Turbo: K03sport
Gearbox: EHA (Octavia RS, 5-speed, long gearing - Leon has 6-speed 'box!)
ARX
Skoda Octavia 1.8T 4x4 Elegance, 8/00-now
Output: 150 hp
Drive: Haldex 4WD
Emission: VVT, EU3
Injectors: big
Turbo: K03sport
Gearbox: FEX (5-speed, short gearing)
Other 1.8Ts
APX: Audi TT, 225 hp, Haldex 4WD, K04, 6-speed
APY: Audi S3 (earlier model), Seat Leon Cupra R (earlier model), 210 hp, Haldex 4WD, K04, 6-speed
ARY: Seat Leon 20VT Cupra 4, 180 hp, Haldex 4WD, K03sport, 6-speed
ARZ: Volkswagen Golf GTI, 150 hp, FWD, K03sport, 5-speed
AWT: Audi A4 1.8T/1.8T quattro and Volkswagen Passat 1.8T, 150 hp, FWD or Torsen 4WD, K03, 5-speed
AWU: Volkswagen New Beetle 1.8T, 150 hp, FWD, K03, 5-speed
BAM: Audi S3/TT (updated models), Seat Leon Cupra R (updated model), 225 hp, Haldex 4WD, K04, 6-speed
BFB: Audi A4 1.8T/1.8T quattro (updated model), 163 hp, FWD or Torsen 4WD, K03sport, 5-speed
The 210 and 225 bhp engines as found in the Seat Leon Cupra R, Audi S3 and Audi TT have different internals and a bigger k04 series turbo, all which allow it to produce more power. A chipped version of these engines can reach 260-270 bhp.
Quinten is offline
Similar Threads
ECU Explorer AwesomeAPR Awesome GTI 14 02-12-2004 12:01
Octavia and other Skoda engine codes DGW Maintenance & Performance 12 17-11-2004 14:29
Octavia Modifications Real Skoda Maintenance & Performance 0 24-10-2003 10:29
