This is a discussion on Hybrid Turbo within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi Im thinking of putting a hybrid turbo in my Fabia Vrs. Does anyone have any recomendations? Did it make ...
| Briskodian Join Date: Aug 2006
| Hi Im thinking of putting a hybrid turbo in my Fabia Vrs. Does anyone have any recomendations? Did it make a difference to the performance? Any Help is Appreciated. Thanks Last edited by birky; 01-11-2006 at 22:51. |
| Briskodian Join Date: Jan 2004 Location: South Yorkshire
| There are a couple of folks on here who have had Hybrid/Bigger Turbo upgrades, but its not just a matter of whacking on a Turbo. Other things to consider includeuprated clutch and gear box, plus a remap to handle the altered Turbo. All money TBH I'm sure one of the main techies will be along soon to fill you in in more depth. Which vRS BTW? Octy or Furby?
__________________ Paul My Car - Nightfire Blue Superb - 2.5 V6 TDi - Dark Leather Interior - Xenons - Serious Pimp Tints - Sat Nav - Detchable Towbar - Green Cotton Panel Filter - MINTEX Xtreme Performance Brake Pads - Chrome Wing Mirrors - 18" New RS4 Rims - Neuspeed Lower Rear ARB - Pipewerx Custom Stainless Exhaust with 200cel Cat - Custom Code PHASE II Remap - Huge Smile - Can my bank account keep up? ... |
| C+ à Paris! Join Date: Sep 2003 Location: Tilehurst, Berkshire
| I have a hybrid turbo, but as Paul says, if you want to get the most out of it, you'll definately need a new clutch and possibly a FMIC for when it gets warm. Of course, you'll also need a re-(re)map. Once you add all the bits in, and labour, it's probably the wrong side of £2000 unless you buy the parts and then fit everything yourself / friends' help Edit: I cheated Well, bought the car with the hybrid already on there. Added the clutch and FMIC, but still need to get the re-remap sorted out
__________________ Xavier |
| check out allard and turbo dynamics for turbo's.
__________________ John Its small, black, gets laughed at, makes 125bhp at the wrong wheels, does 50mpg and makes a cracking Sponge Cake |
| Briskodian Join Date: Sep 2004 Location: South Bucks
| did anyone mention injectors? 'Cos I reckon they'd be needed too unless you like smoke screens.
__________________ Slowly turning the planet sooty. |
| Briskodian Join Date: Sep 2005 Location: Berkshire
| Mongreller Join Date: Apr 2003 Location: Ooo-ar, Oi be from Devonshire
| Definitely worth upgrading the clutch if pipping 200bhp. ![]() Front mount is an option, but it will be heatsoak city come the summer, and maybe even at cooler times of year. Injectors on the pd130 do not appear to be necessary. I've seen reports of people running 245+ on standard injectors with a hybrid turbo (big bugger ) so its fairly clear that the oem injectors are pretty good and not worth spending £800+ on i.m.o. I'm waiting on camshaft developments now, which is likely to be the only "internal" engine mod I do, and its quite an easy one at that (compared to pistons, etc) ![]()
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. See the mongrel's 260bhp Dyno Video! |
| | #8 | |
| Quote:
__________________ John Its small, black, gets laughed at, makes 125bhp at the wrong wheels, does 50mpg and makes a cracking Sponge Cake | |
| | #9 | |
| left briskoda.net Join Date: Mar 2006 Location: Buckingham Palace Car Park
| Quote:
| | #10 |
| Bigger injectors will help with the EGT side of things, but they're well expensive. I've got a hybrid turbo + FMIC and it seems to be a good combo, in that the hybrid is able to deliver more volume of air as well as keep boost at nice levels whilst in the 'safe' area of use. Thing is, if you go down this road things DO get pretty expensive pretty quickly. I've got an LSD & uprated clutch & pressure plate to help put the power down, there are a fair few things left to play with though ![]() Good value for money are the evry mod (not ideal but reasonable), a decent remap that doesn't overdo it. Beyond that it depends on how much reliability and performance you want/need from your car. If you are prepared to use your gearbox you can probably keep your standard clutch alive for a fair bit ![]()
__________________ WW --->> Project Journal (pic links in first post there)Fabia vRS alloys for sale incl tyres, spare wheel with tyre + spare tyre - make me an offer via PM |
| | #11 |
| hardcore modder Join Date: Feb 2006 Location: Henley-on-Thames
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #12 |
| Sounds rather nice that one ![]()
| | #13 |
| Briskodian Join Date: Jan 2003 Location: Winchester
| I had a ride in Lukes VRS at Jabba on Saturday thats had a hybrid added, front mount & one of Jabbas legendary remaps. Ill admit to being somewhat Impressed at just how good it was & how well it could pull in high gears from low revs. Certainly opened my eyes to what can be achieved by people who know what they are doing
__________________ Speed is an addiction for which thankfully there is no cure |
| | #14 | |
| Quote: I got a hybrid KKK, blueflame, clutch and remap and get 380 lb.ft for about 1.5k less. Still, looks nice | |
| | #15 |
| Hybrid KKK. Whats one of these then? The hybrids from the likes of turbo dynamics & Allard are made stronger to handle more boost then next stage is to have a larger compressor from a VNT20.
| | #16 |
| Lukes VRS at Jabba is making 227 bhp & 375 lbft torque, its also still kicking out 190 when it hits the limiter note its still on std injectorsCars spec as follows Red Fabia V/rs, full Milltek exhaust, decatted blueflame downpipe, jabba FMIC, Jabba Remap, Jabba ARB, Jabbasport stage 2 hybrid turbo, green filter, 160pd intake pipe, kw v2 coilovers, 312mm disks, team dynamics 1.2 wheels in black, tinted pimp windows, B&M quick shifter, black leather seats and doorcards, Leon cupra R splitter 227 bhp 375lbft and still growing
| | #17 | |
| Quote:
I take it that the Larger compresser from VNT20 is a stage 2 Hybrid Turbo? | |
| | #18 |
| Thats for a turbodynamics one yes. Also Allards VT2 uses a VNt20 compressor.
