IC Water Mister
This is a discussion on IC Water Mister within the Maintenance & Performance forums, part of the General Motoring Discussions category; I bought the Intelligent water Mister from Autospeed and now trying to figure out the installations..... www.autospeed.com One main issue ...
Old 10-11-2003, 12:02   #1
IC Water Mister
www.autospeed.com
One main issue is the water bottle...
Our Greek specs Oct VRS has only 3L bottle capacity and one pump for the front windshield only. :mad2:
The British specs has rear and wash for the front lights...
What is your capacity??
Does your VRS has 2 pumps installed??
If the bottle is 5,5L and two pumps do anyone know the part numbers in order to buy them??
Please Help....
(When i'll finish i'll post a How-To on this...)
MR FREEZE
Things are getting COOLER now
Loukas is offline
Old 10-11-2003, 12:27   #2
Dinosaur
TaviaRS's Avatar
So, I'm not the only one? Mine has been in and running since september
What you need is:
Washer bottle from an Elegance or L&K spec Octavia. They have headlamp washers. Capacity is 5.5l (IIRC). You will also need:
Headlamp washer pump
Headlampwasher pump grommet
About 50cm of fuel injector hose (IIRC its the 9mm stuff)
1 cable tie
2 pieces of velcro
Some black silicone sealant
Did you buy the nozzle from them? If you did, it will easilly cover the intercooler. As you look at the plastic housing at the front of the i/c (with the bumper off), drill a hole that will fit the nozzle 1/2 way across at the top, as low as you can. Cable tie it in place.
The bits of velcro, I use them to secure the unit under the driver's seat. Before you do the wiring, make a note of which colour is which. We didn't and when we pulled them through, the labels came off and the instructions don't tell you which is which
Can't remember which wire it is, do a search on here and you'll find out, which wire is the pulse feed for the injectors. Looking it up is easier than playing with the 2 wires.
Any questions, let me know.
Jon
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 10-11-2003, 12:37   #3
Dinosaur
TaviaRS's Avatar
Skoda part numbers you require:
5l washer bottle = 8L0 955 453 B
Pump = 3B7 955 681
Grommet/seal = 431 955 465 A
TaviaRS is offline
Old 10-11-2003, 12:48   #4
Dinosaur
TaviaRS's Avatar
For the injector duty cycle, its the pink/purple wire, not the thick red one (thats a constant feed).
5l of water will last about 30mins of track time.
TaviaRS is offline
Old 10-11-2003, 14:39   #5
You make my day Tavia ....Thanks a lot friend..
(your name is famous in GTC club you know... )
All Octavia's sold here havn't any washers front or the wiper back, so the tank is 3L and one pump only... :mad2:
Anyway since i have the P/N I' ll check to buy them.
The pump is dual one?? or there is place in the tank to fit a second one??
THANKS FOR THE DUTY CYCLE CABLE COLOUR...
MR FREEZE
Loukas is offline
Old 10-11-2003, 14:54   #6
Tavia,
Something else,
Is there a P/N for a low water sensor to be fitted in this tank?
MR FREEZE
Loukas is offline
Old 10-11-2003, 15:46   #7
kenny's Avatar
is it an easy mod? dealer do it here in uk?
Ive seen a lot of good things die and im in an over emotional way
So please hand me the bottle I think im lonely now, and please
give me direction I think the hurt has set in, and I don’t feel nothing
kenny is offline
Old 10-11-2003, 16:00   #8
Dinosaur
TaviaRS's Avatar
Loukas, its a different water bottle, and the sensor is different and then you'll have to wire it in I was going to do it but decided that I didn't need to - I'd notice that it was getting slower!
The pump is different to the normal windscreen one - it is very high pressure The new water bottle had a seperate hole for it (goes on the front of the tank, rather than the side where your washer one goes). Its a tight fit, you'll need to move the charcoal filter out of the way and the nuts are a bugger (and plastic not metallic )
Kenny, fairly easy mod. Just need a switched live, an earth, cabling for the new pump and splice into the injector pulse wire. About 2-3 hours.
Found it very good at reducing the temps, plus if its cold out you can disconnect over winter and have the benefits of a 5l washer bottle
TaviaRS is offline
Old 12-11-2003, 10:53   #9
Dan_P's Avatar
Anyone import these over here??
Dan_P is offline
Old 12-11-2003, 11:34   #10
Tavia,
I've just ordered the P/N you've said ....
The tank one code has changed into 3 codes (tank, cap and seal) ...(i hope that these new corresponds to the correct tank).
The others where OK for ordering...
Just a question.
What is the code of the low water sensor that can be fitted in this tank??
I'm thinking to fit it and wire it directly into the Intelligent mister control box.
Thanks,
MR FREEZE
Loukas is offline
Old 26-02-2004, 13:56   #11
Have a look in the How - To i 've made in my VRS for the Water Mister Kit.
It's the 1st part.
Second part is the controller finalization setup & Measures (will follow).
http://www.gtc.gr/Tech/ICmister.htm
There are comments in Greek ....but the pictures are many ..so you understand was is going on...
The same for my custom Grounding Kit...
http://www.gtc.gr/Tech/grounding.htm
And an older stock IC ventilation mod
http://www.gtc.gr/Tech/VAG-IC-vent.htm
I hope these help....
MR FREEZE
Loukas is offline
Old 26-02-2004, 22:17   #12
Dinosaur
TaviaRS's Avatar
Very good.
TaviaRS is offline
Old 26-02-2004, 22:44   #13
BRISKODA Staff
mannyo's Avatar
Nice article Loukas, even if we can only understand the pics. Very comprehensive.
If there is one comment, I would edit one of the pics (ICmist30.jpg) to make you vin less readable, some unsavoury types could use this info to clone your car.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 26-02-2004, 22:58   #14
Dan_P's Avatar
erm......I didnt post this
thyis is the first time i have seen this post.......think maybe something funny is going on
you'll never take me alive................
Currently on Skud #2
Make that Jeep #1
Dan_P is offline
Old 26-02-2004, 23:02   #15
DGW
BRISKODA Staff
DGW's Avatar
Interesting because that post doesn't show in the list of your recent posts although it exists in this thread... But it did come from your PC (or usual IP address).
Denis
DGW is online now
Old 19-05-2004, 14:19   #16
Dinosaur
TaviaRS's Avatar
Pushing this back to the top as it may be of interest for people who were asking on the other thread.
Jon
TaviaRS is offline
Old 05-08-2004, 13:56   #17
(Water Mister cont)
Current update with FMIC installed ....
http://www.gtc.gr/forum/viewtopic.php?t=778&start=90
Read the TAZ post with the photos.
TaviaRS .....now double spray ..
I used finally the heavy duty pump you have mentioned.
Next how-To ....remote display for controller operation into the extra gauges area and the controller hidden.
Last present my temp, etc results using Vag-Com measures when the ambient air temp is 30-40 C.
MR FREEZE
Loukas is offline
Old 14-10-2004, 13:17   #18
This is the second part of my Water Mister setup with Autospeed's Intelligent controller.
http://www.gtc.gr/Tech/ICmister-2.htm
The photos are many so i think you can understand the story (even if it;s Greek).
Try to translate the last two paragraphs where the summary and results are explaned.
If you want you can see the 1st part as well...(link into the above page)
Great results when outside temp is up to 30Celcious or more.
Next mod.....
Water Injection into the engine (custom DIY system)
Parts already gathered
Plan for installation
Functionallity tests before installations
Measures with Vag-Com and LM1, LM3 (A/F, Boost, EGT, RPM, etc)
(if you here a BIG BANG ....that's me testing water/Alchool mixtures into my engine)...
MR FREEZE
Loukas is offline
Similar Threads
Oil into the stock IC & Pipes??? Loukas Maintenance & Performance 5 25-02-2004 16:25
water running off boot lid into boot Dan_P Maintenance & Performance 10 02-01-2004 21:19
Water leak - Octy vRS hatch andy_ccr Maintenance & Performance 5 02-01-2004 10:17
Slight Water Temperature Rise devonutopia Maintenance & Performance 14 21-07-2003 07:39
Water ingress - passenger footwell robmawer Maintenance & Performance 4 13-01-2003 16:43
