Ignition Coil's --heads Up!
This is a discussion on Ignition Coil's --heads Up! within the Maintenance & Performance forums, part of the General Motoring Discussions category; Probably not the right place for this - but this is a head's up for all 1.8T owners -- it ...
Old 16-09-2003, 07:55   #1
skodaw's Avatar
Location: This area is under construction - please call back later :)
Exclamation Ignition Coil's --heads Up!
Probably not the right place for this - but this is a head's up for all 1.8T owners -- it would appear we are heading for a new ignition coil problem -- we have been advised that we need to build our stock's of ignition coils significantly -- i.e over 100 types of each to be held in stock at any time.........
When you consider that our normal stock level is between 6 & 8 of each type --- Oh Dear, Here we go again...
We don't think this is part of a recall,as recall parts are usually automatically issued - so as not to mess with our auto stock levels software.
Just thought it might be worth mentioning - those that don't have spare coils - it might be a good time to find one or two !
Dave
'05 Silver Fabia vRS
skodaw is offline
Old 16-09-2003, 08:15   #2
Dinosaur
TaviaRS's Avatar
One or two? Hmm, I'd better sell some of mine then
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 16-09-2003, 08:48   #3
Om nom nom nom
Neo_VR's Avatar
PFFFFT.. another Coil problem.. i think theres only one way round this.... buy a diesel
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 16-09-2003, 08:56   #4
studioman's Avatar
To be fair, my dealer in Cardiff, White Dove called me in and changed all mine to type J coils. Still carrying two new J's in the boot though - with some extra clutch parts for Jon, just in case.......................
My carbon footprint can be seen from Jupiter
studioman is offline
Old 16-09-2003, 09:22   #5
LadyLoki's Avatar
Oh for fuxake.... not again. Have you any idea how much it cost in hire cars last time? Will they never learn..???
LadyLoki xxx
If I hadn't been sitting in it a moment ago, I'd say you were out of your mind.
LadyLoki is offline
Old 16-09-2003, 10:16   #6
Dutch4x4's Avatar
Location: kicking up feet in the Formula Stealth paddock
So which type of coilpacks are you stocking up then, Dave?
Does this mean that the "reliable" replacement packs have seen their first failures?
Mrs D's Briskoda: Octavia 4x4 turbo (2003), Oettinger 210, Koni Sport, MAD Sportive, Dotz Le Mans 17", Bridgestone Potenza S-03, sports interior. And a Fiesta ST (2006) for myself...
Dutch4x4 is offline
Old 16-09-2003, 11:42   #7
LadyLoki's Avatar
I have spoken to someone here and he reckons it's a contingency plan to prevent what happened earlier this year (when it was cold) happening again (now it's getting cold)
so maybe no need to panic just yet
LadyLoki xxx
LadyLoki is offline
Old 16-09-2003, 11:44   #8
robmawer's Avatar
Or a 1.4/1.6/2.0... :p
Well, there had to be an advantage somewhere...
Rob.
robmawer is offline
Old 16-09-2003, 11:44   #9
LadyLoki's Avatar
Oh, and- no reported failures on the new and improved packs that we are aware of!
LadyLoki xxx
LadyLoki is offline
Old 16-09-2003, 14:36   #10
Dutch4x4's Avatar
Thanks, Niki, that's a relief.
I was lucky to start off with those in the first place, of course. (Phew!)
Dutch4x4 is offline
Old 16-09-2003, 16:24   #11
DGW
BRISKODA Staff
DGW's Avatar
I have two Js in stock in my glove compartment just in case....plus a large screwdriver, 10mm socket and 5mm Allen key in the 'boot' for a quick roadside repair.
Denis
Last edited by DGW; 06-11-2003 at 22:58. Reason: Correction to size of Allen key. 5mm NOT 8mm.
DGW is offline
Old 16-09-2003, 16:47   #12
Stimps's Avatar
* Wonders if Denis realises that "Js" are also slang for something entirely different... *
Steve
« Nature Green 1.4 16v Fabia Comfort »
Stimps is offline
Old 16-09-2003, 16:48   #13
redbaron's Avatar
do we know a date from which all new builds were J ?
do i need to worry?
________________________________________
Some times I just feel like smiling.
redbaron is offline
Old 16-09-2003, 16:58   #14
LadyLoki's Avatar
Can't confirm a date but it is around Jan this year.
LadyLoki xxx
LadyLoki is offline
Old 16-09-2003, 17:09   #15
redbaron's Avatar
so my 03 should be ok... delivered in june?
redbaron is offline
Old 16-09-2003, 17:14   #16
LadyLoki's Avatar
I'd say so mate, but get it checked, and as I have said- if one coil goes they'll replace it- if 2 go, they'll do the lot for you, no arguments.
If they do get funny, ring me or any of my lovely coven here.
LadyLoki xxx
LadyLoki is offline
Old 16-09-2003, 17:17   #17
DGW
BRISKODA Staff
DGW's Avatar
If you do a search you will find that the 06B 905 115J has been superceded by the L in later cars, and that the latest cars are fitted with yet another coil - the 06A 905 115A - whch is not a replacement for the problematic coils. Chassis numbers for the latest coil are from:
1U-3-810 087>>
1U-3A020 277>>
1U-38712 054>>
(The engines in question are the AUM, ARX and AUQ)
Denis
DGW is offline
Old 16-09-2003, 17:26   #18
redbaron's Avatar
cheers guys...
btw Denis... your avatar seems to contain a pic of jon when he was younger? is this deliberate?
redbaron is offline
Old 16-09-2003, 20:05   #19
DGW
BRISKODA Staff
DGW's Avatar
Yes - but as you well know it's a current picture of him...
Denis
DGW is offline
Old 16-09-2003, 20:13   #20
skodaw's Avatar
I can confirm what LadyLoki said - we have had NO failures of new type coils (J or later) however,we are starting to see an increase (again) of the earlier type failures -- some cars had these fitted when the originals failed -- we have had 3 in today -- I have 2 that I know of so far for tomorrow -- the only strange thing is -- it's not cold yet !
I think there may be a knee jerk reaction by other dealers not in the know -- if they suddenly see the ABDG dealers ordering 200+ coil's -- they might just panic a little
oh sorry -- forgot - ABDG - Audi Business Development Group -- is made up of Audi boss's and dealer principals from the top 25% of Audi UK dealers -- they are the people responsible for such things as what colour toilet paper we have -- I kid u not !!
Dave
skodaw is offline
Old 16-09-2003, 20:43   #21
Crossdresser
Quinten's Avatar
And what colour is it?
Awooga!!!
Quinten is online now
Old 16-09-2003, 20:47   #22
DGW
BRISKODA Staff
DGW's Avatar
Probably Black Magic Pearl-effect...
Denis
DGW is offline
Old 16-09-2003, 21:07   #23
skodaw's Avatar
Only after a heavy night on the Guiness
Audi specify white or pink toilet paper -- not that anyone takes any notice !!
When we moved into the new dealership 4 years ago -- we had light grey fire doors -- a WEEK after we moved in - they changed spec to the light wood(beech?) -- we had to change around 15 fire doors -- which were then thrown in a skip !!
The other crazy thing....when we moved in Audi had no guidelines for site signs i.e parking / speed etc -- so everyone went it alone - we had some made by a local company - an Audi rep saw them - loved them - they became the standard -- next visit we had -- you must change the signs - they not corperate -- YES they are says us -- NO there not -- you didnt get them from us -- but whats the difference,same design,same company ? -- you didnt get them from Audi - CHANGE THEM NOW! -- sometimes they can be total tommy tankers
Dave
skodaw is offline
Old 16-09-2003, 21:39   #24
big k's Avatar
haven't heard the rummor about coil packs yet but will over stock this winter (hope skoda take back excess stock) as for audi dictating colours tell me about it skoda are the same i guess they have gaines that bulls**t from the vag group.
how can me find a jet engine for me rapid ?
big k is offline
Old 16-09-2003, 21:49   #25
Crossdresser
Quinten's Avatar
**** indeed
Awooga!!!
Similar Threads
Advice on finding an ignition live for my Snooper! gilly ICE, Security and Insurance 10 02-02-2006 15:03
Engine warning light on, Ignition coils? vRS_Si Maintenance & Performance 22 12-02-2004 10:38
Ignition Coil Update LadyLoki General Car Chat 75 11-11-2003 13:19
Coils Again jawsnpaws General Car Chat 7 06-08-2003 10:35
HELP COILS KarlRS General Car Chat 2 29-01-2003 10:12
Disclaimer: This is not an official SKODA site and is not affiliated to SKODA in any way. Visit the Official SKODA W
