39,426 Members 1,488,319 Posts
Intake manifold cleaned, EGR delete pipe fitted - wow!
This is a discussion on Intake manifold cleaned, EGR delete pipe fitted - wow! within the Maintenance & Performance forums, part of the General Motoring Discussions category; Finally got round to fitting the Allard EGR delete pipe. As the intake manifold was also dirty, I decided to ...
Old 25-11-2007, 08:07   #1
Hardcore
Basil's Avatar
Smile Intake manifold cleaned, EGR delete pipe fitted - wow!
Finally got round to fitting the Allard EGR delete pipe. As the intake manifold was also dirty, I decided to do the right thing and remove it for cleaning as well.
The EGR was filthy, and this with only about 20K (tuned) miles on the car - about 35% blockage. I has some issues with hesitation with startup that have gone away now (likely sticking EGR flap).
The manifold had about 3-4 mm of gooey sticky black crud that scraped off like dark cholocate icing. The actual intake ports had a full 2mm of the stuff choking the exits.
A whole can of carb cleaner was used then to clean it, and air blown through to make sure there was no residual cleaner left in the manifold. This has to be the dirtiest bit of DIY possible! Took me 3 days of scrubbing to clean my hands with you name it....
Results:
Excellent tbh - the car starts better, revs faster, less smoke, more power felt and power is smooth all the way to redline. I let the CEL issue put me off this mod for a long while - too bad.. Don't notice any shutdown shudder, even though I was expecting some...
Well worth the trouble and the considerable mess!
for earlier pics see: http://www.briskoda.net/forums/maint...-engine/89753/
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 25-11-2007, 10:14   #2
john_grant358's Avatar
Re: Intake manifold cleaned, EGR delete pipe fitted - wow!
Is this a hard job to do?
I used to do a little bit of work on my mini but havent touched the fabia.
Can u balls it right up if you dont no what your doing?
Its obviously worth doing, my car is coming up to 3 years old and has 29,000 miles on it, would it be worth paying a mechanic to do the work?
how many hours of labour do you think they would charge me?
john_grant358 is offline
Old 25-11-2007, 10:23   #3
Mongreller
devonutopia's Avatar
Images: 5
If you just want it cleaned, perhaps 2 hours. Easy enough to whip the EGR/mainfold assembly off the car. But if you want to clean the actual manifold that means unbolting the manifold off the head, which is tricky due to lack of space. The cleaning itself will take most time I reckon.
Jason - Only a Skoda.
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
The Following User Says Thank You to devonutopia For This Useful Post:
john_grant358 (25-11-2007)
Old 25-11-2007, 13:20   #4
Hardcore
Basil's Avatar
Not that hard to do, tbh. Took me about 3-4 hours:
unclip rubber air hoses either side of intake manifold.
Unbolt EGR from manifold and turbo.
3x 5mm head allen bolts to intake, 2x 10mm (or was it 12mm?) bolts to turbo.
If you're fitting a EGR delete pipe - fit the blanking plate now - you dont want to drop anything inside the turbo! otherwise cover with a plastic bag/elastic band.
Remove 2 tight rubber vac hoses from EGR
unbolt 2x 10mm bolts from top and Left of intake manifold.
unbolt intake manifold 6x 6mm allen key head bolts - you'll need to feel for them and/or use a mirror.
Pull off manifold and remove metal gasket.
on re-assembly - use a new metal gasket (preffered). Need to judge (guess) 18 Nm of torque - just tight and then a bit....The intake bolts need a combo of different length 6mm allen keys - some ball-headed ones would've helped, but I didnt have any...
Really FILTHY job - anything you wear will become garbage....
If you plan it as an overnight job - soak the manifold in some solvent in an enclosed container.
Things to watch out for - dropping stuff into the turbo/EGR union (very bad). That's why if you have a blanking plate - fit it first...
But it really is worth it....
HTH
Bas
Basil is offline
The Following 2 Users Say Thank You to Basil For This Useful Post:
john_grant358 (25-11-2007), viewer (12-08-2008)
Similar Threads
Fabia vrs air intake mod to pd160 intake pipe mac67 Fabia I 158 11-01-2008 12:41
ABD intake manifold?? Steevie Wonder Maintenance & Performance 20 16-10-2007 19:55
Intercooler/EGR pipe keeps coming off? Irf Fabia I 9 05-08-2007 08:04
Intake Manifold Cleaning......... Pythix Maintenance & Performance 2 27-04-2004 09:13
