This is a discussion on Jabba filter fitted within the Maintenance & Performance forums, part of the General Motoring Discussions category; well i got round ma n pa's on saturday to use the garage cause of the weather but after a ...
| Briskodian Join Date: Nov 2003 Location: Walsall, West Midlands
| Jabba filter fitted well i got round ma n pa's on saturday to use the garage cause of the weather but after a couple of hours (did a few other bits as well) the filter was fitted and running sweet. anyway, heres a few pics.
__________________ Sea Grey Mondeo Titanium X |
| top one is before work started, then airbox out and then stainless housing in place. these next couple are maf and stainless pipe conected and fitted then filter in. the smaller filter is for the end of the return to airbox pipe, you get a steel bar to bolt this down but i couldnt find anywhere i was really happy with so i just cable tied it to another hose.
| i've got an avi file to but i'm not sure how to upload this as i havent got any web space to host it. can i attach it to a post ?? it's 4.4mb
| fitting was easy enough, i did have to cut a small slot into the side where it sits into the wing cause the bolt for holding it into place didnt line up, nothing major just a snip with some metal cutters and the job was done. hardest part was joining the maf and the stainless tube together, i could take the maf sensor out of the housing cause of the poxy security screws they've used on it so had to be careful. in the end i used a rubber malet to gently tap the two sections together, you do have to heat the pipe though to make it expand slightly. dont think they'll be coming apart though ![]()
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Hey...........that looks my car! ![]() Good job Nigel. What do you think of it then? Feel any different performance wise? Does SWMBO approve of the noise? ![]()
__________________ Adrian. |
| Briskodian Join Date: May 2004 Location: Peterborough
| looks sweet... if you dont mind how much are they?? and we need answers to SkodiRS questions Joel
__________________ Everyday car: Pimp Black Skoda Octavia VRS, 230bhp, 250lb custom remap, blueflame stainless exhaust, lowered, Hyperboost Dump Valve, ABD tip. 1/4mile in 14.99 secs Project Car: Vintage Mk2 Golf, to be turned in to a 1/4 mile beast, 1.8T 20v engine conversion! Watch this space!!!! |
| IIRC, Nigel got his for Ł225 inc p&p. Would be less for you Joel as you're a Peterborough resident and could collect. Would be good to compare Nigel thoughts/feelings on it to my own.
| does it get much air there???? the airflow to it don't look to good, or is there air coming from the side/bottom?
| Briskodian Join Date: Sep 2004 Location: WALTERS ASH
| i have got to ask, what is the point of fitting an induction kit if you have no cold air going to it. you may as well fit a panel filter in the airbox and modify that. this site is worth a visit http://www.autospeed.com/ for tuning advice. search on articles about pressure drop and air intakes. |
| | #10 | |
| Quote:
Utilises the same air inlet as standard......you can, of course, add further ducting from the lower grill if you like. It's not all about airflow....also air temp as well. Standard airbox has quite good airflow once you stick in a freer flow filter and cut out a few internal webbing fins. However it's not so good on the temp side.
__________________ Adrian. | |
| | #11 | |
| Quote:
One thing i have noticed is that the car feels more eager low down. I'll give a better report on performance when i work it out myself ![]() SWMBO actually likes the sound of the filter, she said it reminds her of a scooby and said it reminds her of when we first got the R19 and i bolted filters etc to that. i was surprised to be honest, she said it sounds better now than it did standard ! i do find myself short shifting through the gears when driving normally though, you can hear the turbo spooling from as little as 1500rpm and the recirc valve dumps loudly at as little as 2000rpm, the induction note is pleasant and you can somehow feel the acceleration and speed more when theres a bit more noise, the one thing i didnt like about the car before was the lack of noise when you went for it, at least it has some now.
__________________ Sea Grey Mondeo Titanium X | |
| | #12 | |
| Quote:
| | #13 | |
| Quote:
i'll find out on the way home from work today how the new filter copes with heat soak in traffic... somehow i dont think its going to though. with the bonnet down the stainless housing round the filter creates a box which is nigh on sealed from the engine bay.
| | #14 | |
| Quote:
| | #15 |
| the dv sounds louder as the noise your hearing is coming out through the filter.induction noise on turbo charged cars is very little compared to n/a cars, this is down to the turbo - although that said you do get some noise. the only way you can compare intake temps is to get a temp probe pre turbo and carry out proper research. |
| | #16 | |
| Quote:
like i said i reckon if it needed extra Jabba would have put it in. BTW, that nice Mr SimonT is going to host my avi for me so that should be up later on. its not the best quality (only used my fuji S304) but you'll get the idea.
| | #17 |
| Big thanks to SimonT for the hosting. http://67.18.251.30/briskoda/RoarPpptttssshhh.AVI Yes the noise does make you giggle like a 3 year old !
| Introduction to the NEW Octavia | ColinD | Octavia II | 2 | 22-02-2007 20:09 |
| Octy DV an air filter fitted | Joel_vRS | Maintenance & Performance | 3 | 23-06-2004 09:24 |
| Pipercross Viper air filter | andy_ccr | Maintenance & Performance | 1 | 22-02-2004 15:49 |
| ATTENTION - how Briskoda goes about making a Jabba group buy | SkodiRS | JabbaSport | 0 | 09-12-2003 14:19 |
| Is Jabba or Revo better for a Fabia vRS? | tfboy | Maintenance & Performance | 22 | 05-10-2003 23:03 |
