39,468 Members 1,490,086 Posts
MAF Problems again??
This is a discussion on MAF Problems again?? within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi I am still having problems with what might be the MAF. My symptoms are progressively getting worse. Could someone ...
Old 17-04-2004, 15:43   #1
gibbo01's Avatar
Members Car: Octavia vRS
Could someone enlighten me as to whether these could be MAF related.
Last night it was feeling very sluggish even on full jabba boost but it was very wet?? Clutching at straws now.
Symptoms are
1. Loss of power under load, even when on jabba full boost hard to quantify but it feels slower. (intermitant)
2. SLightly Lumpy idle when warm
3. upon cold start, the car is virtually undrivable it is VERY VERY hesitant to the point of stalling in second gear, and kangaroo's like i am a learner (sits back and awates jokes!!)
Skoda tech finds no fault codes but i think they are getting fed up of me keep asking for it to be checked out, the only thing else i can think of is the MAF but at 250 odd notes i would prefer to know for sure.
I have also tried injector cleaner to no avail.
Any tech peeps help me out?
Mike
He that walketh with wise men shall be wise: but a companion of fools shall be destroyed. Proverbs:13:20
gibbo01 is offline
Old 17-04-2004, 16:32   #2
RipRock's Avatar
Members Car: Octavia VRS
I have syptoms very similer to you gibbo,and was advised it could be MAF problems because it was intermitant in nature.Although i haven`t experianced the mad kangaroo effect the other 2 problems seem very much like mine.Although the performance drop is not drastic,it feels like your only running at 90% at times and the car can feel a little lazy in pick up after changing gear.This last point made me think DUMP VALVE because the lag between gear chages seemed pretty bad sometimes,although i was informed that DV`s tend to go completely and not just intermitantly.Dispite this i decided to get a new aftermarket DV (hyperboost) and while its early doors yet i can honestly say that the 40 mile drive i gave it yesterday where some of the best ive had in it .The pick up from first to second gear now seems almost instantanious! .The OEM dv that was taken off didnt appear to have any obvious problems so before commiting to a new DV id wait for a bit until i can get back to you on how mine contniues to perform.
Yesterday may have been a fluke cos like i said even with the stock DV sometimes it ran as if there was no problem and i may have got the new DV on a god day yesterday.So its possibly might be an Intermitant MAF problem and/DV combo ,you never know .Im doin 500 miles all next week,remind me next friday and ill post if it seems to be still behaving itself .
P.s The hyperboost makes a SLIGHTLY louder PSSSSSSTTT noise aswell..........BONUS!!!
Yours
Dash
RipRock is offline
Old 17-04-2004, 16:39   #3
TIMVRS's Avatar
Sorry to hear the news Mike.
Lets hope it gets sorted for you and doesnt cost a packet.
Tim
TIMVRS is offline
Old 18-04-2004, 08:54   #4
gibbo01's Avatar
Cheers,
I have changed the DV and it did seem better for a while, i would appreciate your findings after next week.
Tim
Hopefully if it is a maf problem it "should" be covered under warrenty but it might cost me initially, as they wont swap it unless it fails!!
Mike
gibbo01 is offline
Old 18-04-2004, 10:34   #5
Dinosaur
TaviaRS's Avatar
Members Car: Merc E class & SLK
Try cleaning the MAF.
You will need: Some Isopropynol alcohol spray or fluid (used for cleaning circuit boards) and some of the flat cotton buds from Boots.
Firstly, unplug the MAF. Its a snap connector on top of the MAF. You then need to undo 2 star bolts. They are of the security type with the raised centre (to stop you doing it!), you can probably do it if you are careful/lucky or get yourself to a DIY store / Maplins (get some spray whilst there) and get some of the right tools.
Pull out the MAF sensor. Spray with the IPA spray then VERY CAREFULLY use the flat cotton buds to clean the carp off it. Spray again, wipe and allow to dry. If you have fluid rather than spray, put some in a zip lock freezer bag, insert MAF sensor and swoosh it around. Remove and wipe VERY CAREFULLY withe the flat cotton bods. Repeat. Allow it to fully dry (you can put it in the airing cupboard.
Put the sensor back in the MAF housing once dry and give it a spin.
Hope that helps, it worked on mine.
******PLEASE NOTE, I accept NO RESPONSIBILITY if it all goes horribly, horribly wrong and you damage the sensor!******
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Old 18-04-2004, 13:41   #6
gibbo01's Avatar
Cheers tavia
I will do that tonight its worth a shot, i hope it works
When you say clean the "carp" off it do you mean the common type or mirror type?
Mike
Disclaimer duly noted
gibbo01 is offline
Old 18-04-2004, 15:24   #7
Dinosaur
TaviaRS's Avatar
the common type
TaviaRS is offline
Old 18-04-2004, 19:52   #8
Clarey's Avatar
Members Car: skoda
If there is any koi 'carp' on it, should i leave it there?
Cheers,
Phil.
Clarey is offline
Old 18-04-2004, 19:56   #9
GAFF's Avatar
Members Car: Octavia II vRS
Originally Posted by gibbo01
Cheers tavia
Originally Posted by clarey
koi 'carp' on it
Sorry for the stupid question but what do the different types mean ?
GAFF is offline
Old 18-04-2004, 21:19   #10
Dinosaur
TaviaRS's Avatar
They are types of carp. Didn't think the swear filter would let me type crap, but evidently it does
TaviaRS is offline
Old 18-04-2004, 21:22   #11
Elculo's Avatar
Members Car:
isnt this the same Bosch MAF that cause probs for BMW drivers? and Scoobs i think
why not jst change the MAF? I know a bloke who carries spares!
Elculo is offline
Old 18-04-2004, 21:24   #12
Dinosaur
TaviaRS's Avatar
I used to after mine degraded and took my engine out
TaviaRS is offline
Old 18-04-2004, 22:33   #13
gibbo01's Avatar
Would like the name and number please if i need to buy one i might as well do it as cheapl as poss
Mike
gibbo01 is offline
Old 18-04-2004, 22:59   #14
DGW
BRISKODA Staff
DGW's Avatar
Mike
Look in the stickies at the start of my Maintenance. Cheap isn't a word which comes to mind in this context.
Denis
DGW is offline
Old 22-04-2004, 08:49   #15
Dinosaur
TaviaRS's Avatar
Did cleaning it work?
TaviaRS is offline
Old 22-04-2004, 10:53   #16
gibbo01's Avatar
No John
Not initially,
Gave it a good soaking in contact solution first, then VERY carefully wipped it with a flat cotton bud, dried it out properly and then re installed.
Took it for a spin and my intermitent loss of power wasnt intermitent anymore.
it drove like S**t and even on full bost it didnt make any difference.
So disconnected battery (if all else fails disconnect battery!)
This didnt work either,
so it looked like i might need a new one.
Until this morning when it drove fine again
I might leave it for a couple of days and see how it goes.
Someone off another forum has had similar problems and said it "might" be the N75 Valve so £30 for the "J" version might be worth it insted of £278 for the MAF first.
Thanks for the help i will keep u posted
Mike
gibbo01 is offline
Old 22-04-2004, 10:59   #17
Dinosaur
TaviaRS's Avatar
I'll bring you a N75 valve on Saturday if you want.
TaviaRS is offline
Old 22-04-2004, 12:20   #18
gibbo01's Avatar
Thanks,
But i aint bloody going on saturday.
I might have a word with my friendly postman (read, Colin D)
See if he will pick it up for me.
at this rate he will need a trailer to bring all the stuff he is picking up for me on saturday.
Looks like a few pints are in order.
So please bring it, i will sort something out, if it doesnt work i will post it back to you, if it does i will send you the money for it.
Cheers
Mike
now wheres that PM buton
gibbo01 is offline
Similar Threads
Fabia vRS - any common problems? waynef General Car Chat 277 12-08-2005 13:46
MAF Problems gibbo01 Maintenance & Performance 24 05-02-2005 13:48
possible pieburg maf problem? anotherbadname Maintenance & Performance 3 12-04-2004 20:46
Felicia - cold starting problems DGW Maintenance & Performance 2 27-11-2002 21:46
