39,468 Members 1,490,087 Posts
Main Beam!!!
This is a discussion on Main Beam!!! within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hello people, could anyone tell me if the xenon headlight adjustment alters the main beam too or is it just ...
Old 26-03-2008, 15:38   #1
Darren260403's Avatar
Main Beam!!!
Hello people, could anyone tell me if the xenon headlight adjustment alters the main beam too or is it just the headlights?
When i put mine on main beam the light seems far too high (almost into the tree's?) & am sure it's not supossed to be like that?
Once it's sorted i'd like to upgrade the main beam bulbs to some more powerful as too be honest, the xenons are so much better that at the moment i find myself not using main beam hardly at all?
I'd like a crisp blue-ish light, the more powerful the better but obviously not wanting to melt the plastic lenses?
What do you guys use or recommend?? Many thanks in anticipation for your responses!
Darren260403 is offline
Old 26-03-2008, 16:43   #2
downtime's Avatar
Re: Main Beam!!!
Automatic leveling doesn't affect main beam only the dipped beam.
It seems that many of the Octy's are like that, main beam just lights up the treetops You can easily sort this out. There's a screw behind the headlamp unit which alters the up/down position of the main beam.
It's the only updwards facing screw attached to the headlight assembly.
downtime is offline
The Following User Says Thank You to downtime For This Useful Post:
Darren260403 (26-03-2008)
Old 26-03-2008, 19:39   #3
Re: Main Beam!!!
Thanks downtime, will try & sort that out in an our or so once it's dark! The owls, birds & squirrels will be ever so grateful too LOL......
Old 26-03-2008, 22:10   #4
2.0 FSI Sport.
smstext's Avatar
Members Car: Octavia Mk2 FSI Sport
Re: Main Beam!!!
have you got a photo of which one it is, i need to adjust mine, its a bit better with halfords extra bright bulbs tho.
smstext is offline
Old 27-03-2008, 11:40   #5
downtime's Avatar
Re: Main Beam!!!
Yes. Here you go. I hope the picture is clear enough
downtime is offline
Old 27-03-2008, 19:53   #6
2.0 FSI Sport.
smstext's Avatar
Re: Main Beam!!!
cheers, which way does what?
smstext is offline
Old 27-03-2008, 21:10   #7
dstev2000's Avatar
Re: Main Beam!!!
Bear in mind it adjusts the entire main beam reflector and not just the bulb so watch for the reflector moving when adjusting. As for which way is which - give it a twiddle and all will be revealed as it takes quite a few turns to make any big adjustments.
I did mine a while back and it's a vast improvement as I had a gap between the xenon beam cut off and the main beam throw - most off-putting!
MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely!
SWMBO's: MY08
vRS TDI - Standard
dstev2000 is offline
Similar Threads
Xenon + main beam sorted dstev2000 Octavia II 20 07-01-2008 21:21
Xenon / Poor Main Beam Muppit! Octavia II 24 13-12-2007 19:43
Improving main beam to match xenons matchmaker Octavia I 9 01-11-2007 13:50
Main Beam Problem Dmac1969 Fabia I 16 18-11-2006 19:22
Xenon and main beam ChrisRs Fabia I 12 07-07-2005 09:22
