39,468 Members 1,490,087 Posts
Must Do Better
This is a discussion on Must Do Better within the Maintenance & Performance forums, part of the General Motoring Discussions category; Ever get the feeling you just aren't doing enough to make you 1.8T go faster....
Old 15-08-2003, 20:12   #1
Still a ****
delcac's Avatar
Members Car: A red one
Images: 3
Must Do Better
The Red Devil
delcac is offline
Old 15-08-2003, 20:17   #2
Still a ****
delcac's Avatar
Images: 3
How about 600bhp at the wheels.
The Red Devil
delcac is offline
Old 15-08-2003, 20:26   #3
Dutch4x4's Avatar
Location: kicking up feet in the Formula Stealth paddock
So how do you scoop that in?
Mrs D's Briskoda: Octavia 4x4 turbo (2003), Oettinger 210, Koni Sport, MAD Sportive, Dotz Le Mans 17", Bridgestone Potenza S-03, sports interior. And a Fiesta ST (2006) for myself...
Dutch4x4 is offline
Old 15-08-2003, 20:29   #4
Still a ****
delcac's Avatar
Images: 3
That's the same engine in the top pic.
The Red Devil
delcac is offline
Old 15-08-2003, 20:43   #5
Dutch4x4's Avatar
So that's how they do it.
Dutch4x4 is offline
Old 15-08-2003, 20:47   #6
Crossdresser
Quinten's Avatar
What's that VW badge doing on front of your car Des?
Awooga!!!
Quinten is offline
Old 15-08-2003, 20:55   #7
VT5
Members Car: Fabia vRS
600bhp at the wheels?
Is the car in question a front wheel drive? If it is, driving it must be "interesting"
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 15-08-2003, 20:57   #8
Jimmy's Avatar
Members Car: Octavia ahem Hearse
That turbo's the size of a dustbin lid.. Massive
Jimmy is offline
Old 15-08-2003, 22:14   #9
Still a ****
delcac's Avatar
Images: 3
How about this one, now that's what I call a tight fit.
The Red Devil
delcac is offline
Old 15-08-2003, 22:54   #10
Don't talk, drive!
ncarring's Avatar
And how long does one of these engines last, approximately?
Nick
North Wiltshire RoADAR
ncarring is offline
Old 16-08-2003, 08:45   #11
Still a ****
delcac's Avatar
Images: 3
Next you'll be asking if the warranty has been voided by all these mods.
Oh and it's probably shot the mpg as well.
Des
The Red Devil
delcac is offline
Old 16-08-2003, 11:12   #12
Don't talk, drive!
ncarring's Avatar
Des - no it was kind of a serious question ... Is this the kind of engine that needs a rebuild every couple of thousand miles - it looks like it....
Are you planning one like this for your Octy? Can't imagine the shell would take 600bhp without bits falling off - would need lots of strengthening.
You post all these pics, but nothing to tell us what they are, or what your plans are. You mustn't be surprised when we ask questions
Nick
ncarring is offline
Old 16-08-2003, 13:04   #13
redbaron's Avatar
Members Car:
Des
is that AET's GT30 and tubular manifold w extneral wastegate?
or someother monster?
________________________________________
Some times I just feel like smiling.
redbaron is offline
Old 16-08-2003, 13:20   #14
Don't talk, drive!
ncarring's Avatar
Need someone to explain what/where a wastegate is now, please.
Footnote: Yes I know I look dumb asking all these questions but at least I act as a whipping boy for all the others who'd like explanations as well :p
Nick
ncarring is offline
Old 16-08-2003, 15:06   #15
Crossdresser
Quinten's Avatar
<image of a line of newbies taking one step back leaving just Nick to deal with it>
Awooga!!!
Quinten is offline
Old 16-08-2003, 17:12   #16
Still a ****
delcac's Avatar
Images: 3
Originally posted by ffelan in this post
Des
Nick,
I suppose it would depend on what you used the car for and how hard you pushed it, wouldn't have thought it had the longevity of an OE engine.
Paul,
It's made by Trial don't know what the part number is.
Des
The Red Devil
delcac is offline
Old 16-08-2003, 21:34   #17
KLB
Discordian
KLB's Avatar
Location: Newport, Newport - so good the Post Office named it twice
It isn't a dumb question!
The wastegate controls how much exhaust gas flows through the turbine part of the turbocharger (and hence how much boost is generated).
If the wastegate is closed, all the exhaust gas goes through the turbocharger, making it generate lots of boost pressure.
On VW 1.8T engines, though, the boost pressure is selected by the ECU. To do this, it controls the wastegate, which allows variable amounts of exhaust gases to rnter (or bypass) the turbo.
Mike
KLB is offline
Old 16-08-2003, 23:14   #18
Don't talk, drive!
ncarring's Avatar
Hmmm - during my remap, Mike showed me a valve which he explained controlled the boost pressure by means of an open/shut ratio controlled by the ECU. However, this valve was in line with rubber hoses, which I find hard to believe contained hot exhaust gases. I therefore believe this valve was on the cold air side of the turbo, and was not the wastegate. Am I wrong?
PS I read up on wastegates and your explanation agrees with what I read - the wastegate is a bypass valve on the hot gas side of the turbo, i.e. it allows hot exhaust gas to bypass the inlet stage of the turbine.
Nick
ncarring is offline
Old 18-08-2003, 10:44   #19
Eric_R's Avatar
Members Car:
No, thats correct. The wastegate is operated by boostpreassure and that valve controls
how much boost the wastegate sees. Called N75 valve and is available in a few versions
that can be used to change the amount of surging or boost peak the car has.
Eric_R is offline
Old 18-08-2003, 10:47   #20
Don't talk, drive!
ncarring's Avatar
Thanks Eric - sorry for doubting you, Mike
Nick
ncarring is offline
Old 18-08-2003, 11:16   #21
redbaron's Avatar
Members Car:
you can adjust the n75 ther eis a little screw on it... not sure which way to turn though or the actuall effect? if someone knows i will try it?
redbaron is offline
Old 18-08-2003, 11:34   #22
Don't talk, drive!
ncarring's Avatar
Since that seems to be the main component of the remap I'm loath to mess with it. I don't want to make any gross changes to the boost pressure etc. after Mike spent so long getting it right
Nick
ncarring is offline
Old 18-08-2003, 11:41   #23
KLB
Discordian
KLB's Avatar
It's probably not a good idea to screw around with the screw - all it does is get the ECU upset. See here
Mike
KLB is offline
Old 18-08-2003, 11:50   #24
redbaron's Avatar
Members Car:
so if i have surging already turing the valve down may help then? (assuming that as per the link turing it up causes surging?
redbaron is offline
Old 18-08-2003, 11:54   #25
Don't talk, drive!
ncarring's Avatar
Was the surging caused by your remap, Paul? If so IMHO you would be better getting the map tweaked for the particular throttle angle/RPM where the surging occurs. If you alter the N75 valve you are changing its effect over the whole spectrum of throttle angles/RPM, and may have negative effects on other parts of the map.
Nick
ncarring is offline
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
