This is a discussion on Oil Pressure Sensor Location. within the Maintenance & Performance forums, part of the General Motoring Discussions category; Trying to locate the oil pressure switch on the octy as need to put in a t piece for my ...
| Briskodian Join Date: Jul 2003 Location: Under The Bonnet
Members Car: Fabia VRS Thanks: 0
| Trying to locate the oil pressure switch on the octy as need to put in a t piece for my oil pressure gauge. Found a pic but only gives a general area. To many hot pipes in the way. Will have another look tomorrow before i rip all the hoses off ![]()
__________________ Octavia VRs mk1 |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Is this thread of any help? PS Just found Jon's writeup which accompanies that picture. It's pretty comprehensive. "Get a 2 way adaptor and plug into the existing pressure pickup point. You need to keep the standard one plugged in or you get the oil pressure light on all the time. It's on the righthand side of the block, below the L shaped bit of plastic that goes round the side of the engine, near the crank case breather pipe, as per below. Remove A, shift B out of the way and follow the Arrow (C). It has a single wire going in and the connector is quite stiff. Mind you don't rip the wires out."
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 18-06-2004 at 18:52. |
| Thats the one i was looking at Denis. Got all the bits to do it but had a quick look for it and there is a mass of pipes there but cannot see any sensors going into the block. Will have a proper look tomorow when i fit some other engine items!!!!!!!!!!!
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| I was surprised to find Mike (from Jabba) plugging in the boost gauge somewhere underneath the engine cover (can't be any more technical than that, sorry ). When asking him about it he said that the best place would be at the DV, but this was more convenient (as it was just for checking boost level after remap adjustments where made)... any of the techie guys able to confirm this? |
| Oil Pressure and temperature sensor tie ins. | Steve vRS | Maintenance & Performance | 7 | 10-05-2004 10:11 |
| Oil Consumption | hugothebear | Maintenance & Performance | 20 | 14-02-2004 19:49 |
| Oil Warning Light | johanny.medina | Maintenance & Performance | 5 | 09-10-2003 11:17 |
| Oil about this then....... | stopan1j | Maintenance & Performance | 38 | 14-08-2003 15:01 |
| Oil Pressure Sensor Locations | TaviaRS | Maintenance & Performance | 15 | 30-07-2003 18:59 |
