This is a discussion on Oil Pressure Sensor Locations within the Maintenance & Performance forums, part of the General Motoring Discussions category; Probably one for Big K, but here goes anyway.... I have fitted an oil pressure gauge to my car. I ...
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Probably one for Big K, but here goes anyway.... I have fitted an oil pressure gauge to my car. I have fitted it in place of the usual sensor (above the oil filter). However, the standard unit is a single wire so I can't complete the circuit and my oil pressure warning light now comes on at anything above idle speed. Just driven 35 miles with it flashing at me and luckily no CEL. Is there an alternate place I could take my pressure feed off of ie a blanking nut in a suitable location? I know on Subarus there is a spare sensor location, with a blanking bolt, on the back of the block. Anything similar on the Skoda engine or is there a way of completing the circuit on the standard pressure sensor? Could I disable the standard sensor with a 1552 or VAG-COM? Thank you!
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian Join Date: Apr 2003 Location: u.k
Members Car: that would be telling Thanks: 1
| is the gauge sensor an inline one ie. remove oil pressure switch bolt on adapter with two ends (and a pipe for gauge) and screw oil pressure into adapter?
__________________ how can me find a jet engine for me rapid ? |
| btw afaik the wire that goes to the oil pressure sensor is on a earth feed so you could probably just earth that wire out and soley rely on the gauge. but don't hold me to that one.
| OK, I'll give it a go, although when I treid earthing it to the block the faultstill came up. Maybe I didn't earth it properly. Now found a co in the states who make a T piece so I can run both, or a 3 way so that I can do temp as well. Now trying to find a UK co that will do the same. Jon
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Jon, since when has your car been LHD? ![]()
| ![]() OK, all now sorted. Found that I can buy an adaptor for the princely sum of £2, so I bought several. All installed and working nicely, even got the standard sensor in place and hooked up. I thought our engines would run more oil pressure. Should be 3-4 bar at 2000 rpm, seems low to me but if that is what the book says....
| | #7 | |
| Briskodian Join Date: May 2003 Location: North East
Members Car: Octavia ahem Hearse Thanks: 0
| Question for Jon Quote:
In addition does anyone know where I can get a 'cheap' DIN panel suitable for mounting 3 x gauges? Or do Skoda/VAG do a blank DIN panel and I'll get the old Dremel out and cut the holes myself. | |
| | #8 | |
| Still a **** | Re: Question for Jon Quote:
Des
__________________ The Red Devil | |
| | #9 | |
| Re: Re: Question for Jon Quote:
| | #10 |
| M10 x 1 is the thread size. Buy a T piece adaptor from a local dealer (VDO if poss). Will cost about £3 ![]() If this works, these are my guages: ![]()
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() Last edited by TaviaRS; 26-07-2003 at 11:33. |
| | #11 |
| VIP Join Date: Nov 2002 Location: South, then East a little bit.
Members Car: 2002 Octavia vRS Thanks: 0
| They look ![]() Just waiting for Mr Disco to extract digit and I'll fit mine too!
__________________ Dave ![]() Dave's new runaround ^ The Beast: 2001-2007 (now re-homed). 5 1/2 years of frightening the living daylights out of other road users and ashaming various high end cars. |
| | #12 |
| | #13 |
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| They sure do look nice... How easy are these to hook up? Just a matter of plugging them in? Q. |
| | #14 |
| Under the bonnet stuf is a bit of a pain, will be easier in a couple of weeks ![]() Turbo guage is really easy. Cut into the vaccum pipe near the FPR, insert the plastic T piece that comes with the guage. Plug in the new vaccum pipe run to the under bonnet control module. Run the lead from the under bonnet control module back through into the cabin and plug in to the control module. Run a lead up to the first gauge from the controller. Wire up the controller (4 connections). Job done. At the same time we fitted the wiring for the oil pressure guage. Remove the OE sensor. Screw in the adaptor and attach both the OE sensor and the Defi one. This is a complete b***ard! Again, run the wiring back into the cabin and plug into the controller. Attach the daisychain wire from the boost gauge to the oil pressure gauge. Job done. I'll be getting some modified adaptors from the States at the end of next week. Unfortunately they cost about £20-£25 each but will make the task a whole lot easier as they are a remote T piece which are mounted about 12" away from the original, making it a lot easier to plug in the sensors. ![]() Whole job will take about 3 hours to wire in both. Jon
| | #15 |
| Briskodian | Jon, What sort of cost are you looking at for the boost gauge, mounting panel and wiring bits from John? Chris |
| Engine oil | ekaradimos | Maintenance & Performance | 7 | 20-10-2007 10:12 |
| Oil change suggestion | Ritchiec | Maintenance & Performance | 2 | 16-06-2004 10:34 |
| Oil Consumption | hugothebear | Maintenance & Performance | 20 | 14-02-2004 19:49 |
| Oil Warning Light | johanny.medina | Maintenance & Performance | 5 | 09-10-2003 11:17 |
| Oil about this then....... | stopan1j | Maintenance & Performance | 38 | 14-08-2003 15:01 |
