This is a discussion on Speakers and power cable within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi! Q1: Does anybody know the maximum mounting deepth and maximum diameter of the magnet for the front speakers in ...
| Briskodian Join Date: Jan 2003
| Speakers and power cable Hi! Q1: Does anybody know the maximum mounting deepth and maximum diameter of the magnet for the front speakers in an Octavia RS? I have read about the plastic cover and it's ok for me to remove it, but I asume that there aren't much room anyway!? I would like to go for the DLS UP6 speakers. Q2: Is there a hole somewhere in between the enginge room and the coupe were it's possible to have a power cable for my amplifier? Regards, Per, Stockholm - Sweden |
| Once the plastic cover is off, there are just 4 screws to undo to remove the speaker. Its may be quicker to do that yourself than wait for an answer. But if you do, please post the answer to your question for the benefit of others!
| Briskodian Join Date: Dec 2002 Location: Stockholm, Sweden
| Re: Speakers and power cable [quote:f149e75cc1="amahay"]Hi! Q1: Does anybody know the maximum mounting deepth and maximum diameter of the magnet for the front speakers in an Octavia RS? I have read about the plastic cover and it's ok for me to remove it, but I asume that there aren't much room anyway!? I would like to go for the DLS UP6 speakers. Q2: Is there a hole somewhere in between the enginge room and the coupe were it's possible to have a power cable for my amplifier? Regards, Per, Stockholm - Sweden[/quote:f149e75cc1] Hi Per. I just recently described the installation of the front speakers on another forum(Zatzy). Here is a link to that thread: http://forum.zatzy.com/showthread.php?s=6b4c302d35b33de64216b4caff1e3352& amp;threadid=78504 Regarding the power cable it´s a little bit more job involved. I drilled a hole in(I think) the plastic cover for the wiper motor on the drivers side. Would probably be easier for me to describe it in swedish Mvh / Christian |
| Per You will find information about routing a power amp cable here: http://www.briskoda.net/modules.php?op=modload&name=phpBB2&file=vi ewtopic&t=401
| Briskodian Join Date: Dec 2002 Location: Panama Republic of Panama
| Check this picture. The red arrow shows whats its look like a groumet to pass a wire to the from batery similar to the factory ones at the right. Also could it be possible to take the power from the nuts thats show the yellow arrow????? and forget to pass a wire o the front batery???? http://cards.webshots.com/c44398599urvfyr |
| [quote:48cfbc3231="Turbo_Boss"]Check this picture. The red arrow shows whats its look like a groumet to pass a wire to the from batery similar to the factory ones at the right. Also could it be possible to take the power from the nuts thats show the yellow arrow????? and forget to pass a wire o the front batery???? http://cards.webshots.com/c44398599urvfyr[/quote:48cfbc3231] If you dont plan to use an amplifier that needs alot of juice it wouldnt be any problem to use that connection. But if you however is going to use something that needs many ahmperes you have to connect the power cable to the battery. That is what a mechanic, a carstereo store and my common sense told me :wink: The coneectors the picture shows obviusly has to supply lots of other things with power so that is why you shouldnt connect an amp there. Sudden powerdrains might damage something. I use an amp that is measured to 1x605wrms in 2 ohms and I can clearly see the dashbord lights and headlights "fading"(?) when I play music... hmmm. Well, pretty loud :roll: |
| I have just found these three links on the UK MKIVs Forum with photos of how to pass a power cable through the bulkhead and connect it to the battery. The installation is for a Golf but may be OK for the Octavia too. If the links are of use, please report back and we will put them in our web links as a DIY Guide. http://193.109.68.9/ukmkivs/forum/topic.asp?TOPIC_ID=5242 http://193.109.68.9/ukmkivs/forum/topic.asp?TOPIC_ID=5321 http://193.109.68.9/ukmkivs/forum/topic.asp?TOPIC_ID=5455
| http://193.109.68.9/ukmkivs/forum/topic.asp?TOPIC_ID=5321 I almost did the same install. The only difference is that I, after putting the cable in the channel underneath the airbox, I removed that filterthingy and drilled a hole in a plastic cover behind it and just pressed the cable thru the hole and voila! The power cable was now down by the pedals. After reinstalling the filter the power cable is totally hidden. This install I did also means you don't have to have the cable as near the engine + it is even more discrete than shown in the pics. Oh an btw, everything looks exactly the same in the Golfs engine compartment as in an Octavia. I hope you understood any of this ![]() |
| Chrille All of it, thanks. Keep up the good work - your input is very useful. ![]()
| | #10 |
| [quote:aa6491f75a="DGW"]Chrille All of it, thanks. Keep up the good work - your input is very useful. [/quote:aa6491f75a]Great! Glad to help.If anyone have any other questions about carstereo installation in the Octavia I will try my best to answer them. Otherwise there might be somone on this board who's native language is english and maybe could help out. Its a little hard with certain terminology. I know what everything is called in swedish but in english it´s a little harder :? Best regards / Christian |
| L&K Upgraded Speakers | pearce_jj | ICE, Security and Insurance | 15 | 15-03-2004 10:36 |
| What Speakers | Nigel26 | ICE, Security and Insurance | 38 | 06-01-2004 17:07 |
| Škoda Octavia Gets A Power Surge With PD Technology | ColinD | General Car Chat | 3 | 17-05-2003 09:23 |
