This is a discussion on Spurious Fault Warning within the Maintenance & Performance forums, part of the General Motoring Discussions category; I had just started the car on Saturday morning, and hadn't driven more than a few yards, when the fault ...
| Discordian Join Date: Jan 2003 Location: Newport, Newport - so good the Post Office named it twice
| Spurious Fault Warning I had just started the car on Saturday morning, and hadn't driven more than a few yards, when the fault warning system decided to give me a fright. The red "thermometer" icon lit up, and the multi-function display showed "STOP! check coolant". I missed the rest of the warning message. Anyway, I stopped, looked where I had been parked - no puddles on the ground - opened the bonnet and checked the coolant tank - well above the "min" level. Started up again - no warning. Drove on, keeping an eye on the temperature gauge, which moved up to "normal", and sat there. Is this likely to be a warning of impending doom, or should I just treat it as a glitch (maybe the mythical alpha particle flipping a bit in the ECU's cache memory)?
__________________ Mike |
| MY Senator had a similar fault which I cured by fitting a new coolant bottle cap with sensor.
| Briskodian Join Date: Apr 2003 Location: u.k
| sounds like a expasion tank sensor playing up to me
__________________ how can me find a jet engine for me rapid ? |
| | #4 | |
| Quote:
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... | |
| Fault codes 17705 & 17545 | GAFF | Octavia I | 108 | 18-08-2008 15:07 |
| warning lights abs, asl ,brake , | kye | Maintenance & Performance | 3 | 06-03-2004 18:24 |
| Oil Warning Light | johanny.medina | Maintenance & Performance | 5 | 09-10-2003 11:17 |
| Door Open Warning Light | Jimmy | Maintenance & Performance | 3 | 18-05-2003 21:04 |
