Squeaking radiator mount - help!
This is a discussion on Squeaking radiator mount - help! within the Maintenance & Performance forums, part of the General Motoring Discussions category; Right then, our Octavia has a little annoying squeak everytime you shut the doors! I've traced it to the radiator ...
Old 13-11-2004, 22:24   #1
I've traced it to the radiator mountings, when the door shuts hard, the whole assembly jiffles (as you would expect). This gives a squeaking sound, it sounds almost like a rubber bush creaky type noise (though it was supspension at first).
Has anyone else had this problem? I'm probably going to grease it to start with but wondered if its a regular thing.
Cheers - Phil.
Goochie is offline
Old 23-11-2004, 14:04   #2
get the car on a ramp then insert some rubber strips (old cambelt is ideal!) in the gap at the bottom of the radiator surround.Fixed mine last week! Let me know how you get on.Also check that there is no contact between the radiator surround and the drain valve for the air-con bottom lh corner of the rad. surround.
JSTdi is offline
Old 23-11-2004, 14:33   #3
Don't talk, drive!
ncarring's Avatar
The rubber worked for me for about 5 minutes. What worked better was to slacken the bolts holding the radiator mount, lift the radiator bodily as much as you can, then tighten the bolts again, still maintaining the lifting force. I looked into taking the rad out to replace the mount, but there's too much to dismantle. The lifting and tightening fix worked for over a year - the squeak's just coming back now.
Nick
North Wiltshire RoADAR
ncarring is offline
Old 24-11-2004, 14:06   #4
thanks guys, will try something at the weekend and let you know how i get on
Goochie is offline
Old 24-11-2004, 20:53   #5
stopan1j's Avatar
A Skoda mechanic told me its very common on the RS Octavia and that its quite a pain to change - for some reasoin affects RS's possibly because of the stiffer suspension
stopan1j is offline
Old 24-11-2004, 21:00   #6
Dinosaur
TaviaRS's Avatar
Yep mine went on my RS - warranty job.
A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast.
Official mobile chicane for Briskoda trackdays
TaviaRS is offline
Similar Threads
Octy vRS squeaking suspension mannyo Maintenance & Performance 67 30-10-2008 12:11
squeaking suspension jonny 5 Maintenance & Performance 8 24-06-2004 23:07
Severly squeaking front suspension on Octy vRS! kennyhkw Maintenance & Performance 6 18-05-2004 07:43
Strange Squeaking devonutopia Maintenance & Performance 44 06-10-2003 18:06
