Still Skoda Estelle brakes
This is a discussion on Still Skoda Estelle brakes within the Maintenance & Performance forums, part of the General Motoring Discussions category; I hav the rear wheel cylinders removed, cleaned them up, just to then replace them...while I was at it, I ...
Old 12-04-2003, 21:36   #1
I hav the rear wheel cylinders removed, cleaned them up, just to then replace them...while I was at it, I changed the brake-shoes too...put the whole thing together, and took it for a spin in the back-yard...no brake power.
The pedal goes just about trough the floor before there's a tiny brake-effect!
I have a car, which has a brake-booster (servo)is the problem in the master cylinder or in the servo, or may it be in the lines, or should I check the wheel brake systems again? *getting desperate*
mich.
mklrnn is offline
Old 13-04-2003, 09:26   #2
BRISKODA Staff
mannyo's Avatar
I would check that the vacuum pipes to the brake servo have not perished and are connected correctly
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 13-04-2003, 10:01   #3
DGW
BRISKODA Staff
DGW's Avatar
Have you tried bleeding the brakes again to rule out the possibility that there is still some air in the system? If the brake servo is not working I would expect the brake pedal to be hard to push, but it shouldn't be possible to push it to the floor.
Denis
DGW is online now
Old 13-04-2003, 10:36   #4
big k's Avatar
try bleeding brakes from master cylinder (undo both banjo bolts and let fluid drip out (free-off any bubbles) then try bleeding brakes again in the normal way skoda estelle's and rapids have a bad problem of master cyl failure ie pistons in master cylinder do not move alot when brake pedal is ok but when doing work to brakes/bleeding the piston travel the whole distance in master cylinder causing damage to pistons/seals hope this helps
how can me find a jet engine for me rapid ?
big k is offline
Old 13-04-2003, 10:55   #5
big k's Avatar
also r u sure the self adjusters on rear brakes are working/ fitted correctly ?
big k is offline
Old 21-04-2003, 20:41   #6
stopan1j's Avatar
If you have 4 pot calipers on the front are you bleeding all 3 bleed nipples on each caliper? Suggest you also bleed the brakes with handbrake off.
John
stopan1j is offline
« De-lock | Canbus »
Similar Threads
Skoda Estelle (120) fix-up questions... mklrnn Maintenance & Performance 4 06-04-2003 19:11
Skoda Estelle brakes mklrnn General Car Chat 4 03-04-2003 12:03
