This is a discussion on Strange Behavior within the Maintenance & Performance forums, part of the General Motoring Discussions category; Hi all, My RS pulls clearly harder when I reduce the throttle, for a second or two, then comes back ...
| Briskodian Join Date: Jan 2003
| Hi all, My RS pulls clearly harder when I reduce the throttle, for a second or two, then comes back to normal. It happens especially after a hard acceleration and always when you want to brake fast Anyone noticed the same behavior? Mine did that form day one but now is more obvious than before. Any solution? Thanks, Mircea. |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| Mind used to do the same. Now cured by the remap.
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian Join Date: Mar 2003 Location: SE
| .... also cured with my 4x4 remap. I'd actually forgotten until now that it used to happen. (Emissions related - Impreza Turbo had a noise control routine which behaved similarly - reduced boost) |
| Briskodian Join Date: May 2003 Location: West Lothian
| Mine seems to pull better if I don't actually floor it ..... but I don't think we're talking about the same thing here, are we ?
__________________ An idiot is somebody who persists in holding their own opinion even after I have enlightened them with mine |
| It may be the same thing.... Mine does the same, but only for a limited amount of time, 10s or so, after that you should floor it again. However, after 4500-5000 rpm I need to keep it floored for maximum power. There is any procedure to realign the accelerator module (something similar with throttle body alignment)? Can you see with VAG-COM or other tool the value (a percentage will be the best) that accelerator module is sending to the ECU? Mircea. |
| Briskodian Join Date: Feb 2003 Location: kicking up feet in the Formula Stealth paddock
| Similar experience as Greg's here. A slightly more delicate touch gives more wollop. Flooring it will often lead to ECU rethink or even the wastegate opening - probably the standard chip treatment as opposed to a remap.
__________________ Mrs D's Briskoda: Octavia 4x4 turbo (2003), Oettinger 210, Koni Sport, MAD Sportive, Dotz Le Mans 17", Bridgestone Potenza S-03, sports interior. And a Fiesta ST (2006) for myself... |
| Yep, its almost like a time delay if you use full throttle. Once the boost gauge was fitted I noticed UI got more boost on 1/2 throttle than if I tried to mash it thought the floor boards ![]()
| | #8 | |
| Quote:
![]() But why?
__________________ Mrs D's Briskoda: Octavia 4x4 turbo (2003), Oettinger 210, Koni Sport, MAD Sportive, Dotz Le Mans 17", Bridgestone Potenza S-03, sports interior. And a Fiesta ST (2006) for myself... | |
| Perhaps because the electronic throttle is programmed for progressive movement, rather than the on/off action of flooring the accelerator pedal. For drivers who want to be so heavy footed, a simple on/off switch would suffice rather than using a pedal. In aircraft with FBW control systems, if applying full control movement resulted in immediate full deflection of the selected control surface, the aircraft would break. And with jet engines, if full throttle resulted in the immediate delivery of max fuel flow, the engine would overfuel and could flame out. What I am saying is that if the ECU is programmed correctly, progressive application of throttle should give a better response (and performance) than flooring it, and I would be disappointed if it did otherwise..
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 28-07-2003 at 22:21. |
| | #10 |
| Hmm, seems reasonable, Denis. So it's the electronics saying to the driver, "Hey, don't do that silly stuff to me, or you'll kill us both!" Oh well, doesn't hurt me much - I'm a progressive pedaller anyway, also on the brakes, for that matter. An on/off switch? You mean like on a bumper car? Or what Jon's RS will feel like once the dustbin-sized turbo is fully operational... ![]()
| | #11 | |
| Discordian Join Date: Jan 2003 Location: Newport, Newport - so good the Post Office named it twice
| Quote:
![]() I've noticed a similar sort of phenomenon when taking my foot completely off the accelerator pedal at high revs (not something I do deliberately - just when I'm not planning far enough ahead, and have to lose speed faster than I intended). Engine revs stay high for a few seconds, even though the car is slowing down appreciably. Presumably the ECU and Transmission Control Module (TCM) are discussing the best way to deal with the instructions from the human at the controls... ![]()
__________________ Mike | |
| | #12 |
| Denis, This in not exactly what I am talking about.... Perhaps I get the meaning of flooring wrong, in my opinion it means to get the accelerator pedal at the maximum and it has nothing to do with how fast you do that... please correct me if am I am wrong I agree that the ECU should filter stupid driver actions, and open the throttle in a progressive manner, but it should fully open finally and the boost should get at maximum level… It seems that this is not happening… I do not see any ECU intelligence in the fact that the car pulls harder when you apply about 80% of maximum throttle or even when you reduce the throttle (slowly, it still happens) …. Mircea. |
| Strange thing on new BMWs | William | General Car Chat | 17 | 20-01-2004 00:56 |
| Strange Noise Of Throttle Lift-off | Freakcrab | Maintenance & Performance | 14 | 20-11-2003 17:17 |
| Strange electrical issue. | robmawer | Maintenance & Performance | 12 | 20-11-2003 10:33 |
| Fabia Vrs Speedo (strange) | VRS_Barry | General Car Chat | 16 | 07-10-2003 17:58 |
