This is a discussion on Suspension Octy MK1 within the Maintenance & Performance forums, part of the General Motoring Discussions category; I know, i know, - it's been covered millions of times. Having spent a few thousand lately on the car ...
| Bumble Bee Join Date: Aug 2006 Location: West London
| Suspension Octy MK1 I know, i know, - it's been covered millions of times. Having spent a few thousand lately on the car and now the new clutch is run in, the suspension is showing its age/milage 70,000. What do you have fitted/recommend and where did you source it from and cost. I mostly want your views on ride comfort/handling and i dont want to drop the car to much. Thanks for any helpfull info. |
| Re: Suspension Octy MK1 Eibach Springs with Koni FSD ![]() Failing that the FSD work pretty well with stock springs I hear.
| | #3 | |
| Silver bullet Join Date: May 2003 Location: Planet Earth......
| Re: Suspension Octy MK1 Quote:
Eibach 25mm. from Jabbasport. £160 ish When the bushes go have powerflex poly bushes fitted, these make a hell of a lot of difference too! All these will improve the handling without lowering it or making it more uncomfortable. Weitec coilovers (KW v1's) are excellent too, well worth having, they cope very very well with big power and belting it round corners, and are comfortable enough for normal driving around town etc.......unlike some which will break your back within months..... Hope this helps. Steve
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() | |
| | #4 | |
| Still a **** Join Date: Nov 2002 Location: Chatham, Kent
__________________ The Red Devil | |
| Site owner Join Date: Oct 2002 Location: Hill & Mountains of North Wales
Images: 3 Thanks: 24
| Re: Suspension Octy MK1 For me, ARB's did more than KW v2 for improved feel and grip. I've done arb's and FSD's on std RS springs and it's not as harsh as coilovers but feel way better t drive when pressing on. Certainly for normal welsh roads it's better. It's not lowered or wick'd, but corners like files on a farmers spade and returns to a comfortable ride when not pushing on.
__________________ ColinD - 97/100 Limited Edition Octavia vRS < For Sale £2500 Going to Dealers on the 29th... www.BRISKODA.net :: Site Owner. E-Mail : webmaster at briskoda dot net Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views. |
| Re: Suspension Octy MK1 I thought he said is suspension was showing it's age, eg knackered?
| Re: Suspension Octy MK1 I have Neuspeed anti roll bars fitted which made a huge difference to the handling the trouble im having now under hard excelleration is the front lifting to the stars and the back dragging its ar$e which isnt helping in the braking and excelleration department and through the twisty bits gets a little skittish. I dont want to loose the comfort and CANT lower any more than standard as London is speed hump city. I will probably go for FSD shocks but was unsure what sort of spring to mix them with. Thanks for your input Guy's |
| Re: Suspension Octy MK1 You can still keep the standard ride height using most coilovers... My weitecs can be set to just over the standard ride height.....if needed. Worth a thought perhaps.
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
| Re: Suspension Octy MK1 Eibach do not list a specific springs for the Octy vRS, and from my own experience FSD's with Eibach do not mix well at all. I was told certain ones would be alright , and they were not. Well, not unless you like doing 360's on every roundabout, as they are the wrong poundage for the car. |
| | #10 |
| Briskodian Join Date: Apr 2006 Location: Sheffield
| Re: Suspension Octy MK1 weitec's can bet set to standard ride hight can they hmmm now thats always good to know ![]() |
| | #11 |
| Re: Suspension Octy MK1 You can use FSD with stock springs. JKM were doing a big group buy on eibach and FSD, but these lower the car so no use anyway.
| | #12 |
| Briskodian Join Date: Jul 2007 Location: Oxfordshire
| Re: Suspension Octy MK1 How have you guys found the powerflex bushes as all ive heard are horror stories about them? just interested to see if the horror stories are just a crock of **** or not.
__________________ Must Go Faster |
| | #13 | |
I have them, as others do, and cannot fault them as they tighten up all the slack you get with the OEM ones, you get a bit of vibration at first, especially from the dog mount one until they wear in a bit, but as they are a much firmer bush (No Puns Please) what would you expect? | |
| | #14 |
| Re: Suspension Octy MK1 heard of them splitting from a few people, and a lot of people complaining about them ruining handling and been just ridiculously stiff and shaking the car.
| | #15 |
| Briskodian Join Date: May 2004 Location: fife
| Re: Suspension Octy MK1 Fsd konis should be the best compromise with std springs but i ask koni uk and they said the best combo is with eibach sport springs. I had bilstien sports on mine (non shortened rod type) on mine just took them off to fit koni adjustable so they are available. I foun them to be just marginally firmer than std but with much less pitching and rolling especially over undulating b roads. It all depends on the type of driving you want, i changed as wanted to go firmer thats all but the bilstiens were more than fine for fast road |
| | #16 | |
however......![]() My apologies for trying to be humorous...... ![]() I should get out more.........once out of re-hab maybe I will....
| | #17 | |
Powerflex are very good though. | |
| | #18 |
| Re: Suspension Octy MK1 Also had the bushes, tighens things up well, not had any issues with them. (all round) Re the rollbars, yes it will encourage the back to be awakened; that's good though isn't it ![]() My rear arb is in middle setting and I find it dials the front understeer out nicely, along with a little more rear pressure; Thanks TaviaRS ![]()
| | #19 |
| Re: Suspension Octy MK1 Being serious now...... I've had my powerflex bushes in for nearly 3 years and they have been fault free, silent in operation and have done wonders for the feel of the car without any compromise in the comfort department.
| | #20 |
| Re: Suspension Octy MK1 Thanks to all for your input guys i think i'll try the FSD shocks with standard springs first to see if that sorts it out. Steevie Wonder where did you get your Weitec from as i might look into them a little more. Did some price checks and Awesome Gti seem to be the cheapest (JUST) on the FSD unless anyone know's different ? Also would it be best to source some new standard springs to fit with the FSD's if i go that way, car has covered nearly 70,000. |
| | #21 |
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: Suspension Octy MK1 New, standard springs? If theyre in decent nick keep using them.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| | #22 |
| Re: Suspension Octy MK1 If the old ones are OK then they will stay but thought if its having the new shocks put on then it might as well have new springs. Not sure what the life expectancy is on the standard springs. |
| | #23 |
| Re: Suspension Octy MK1 I'd probably change the springs myself as there were a few incidents of the things snapping and if you don't mind the cost of parts the extra labour is there anyway, so you might as well save having to have it done twice.
| Octavia Mk1 RS Suspension - Confused!!! | trevkx125 | Maintenance & Performance | 3 | 02-04-2007 17:40 |
| Aero wiper upgrade Golf MK5 or Octy 2 wipers/arms to Mk1 Octy. | ecklad | Octavia I | 34 | 19-02-2007 20:35 |
| 6x | ||||
