tdi gearbox
This is a discussion on tdi gearbox within the Maintenance & Performance forums, part of the General Motoring Discussions category; just had my octavia in for its first service. asked the service manager to check the gear change from 1st ...
Old 09-04-2003, 14:04   #1
tdi gearbox
just had my octavia in for its first service. asked the service manager to check the gear change from 1st to 2nd and 2nd to 3rd as it was quit bad when the car was cold. when i went to collect the car he said this was normal and was a common thing with octavias and it was nothing to worry about, anybody else had this problem
mark.j.o is offline
Old 09-04-2003, 14:33   #2
DGW
BRISKODA Staff
DGW's Avatar
I also have this problem on my 4X4 and asked for it to be checked before I took delivery. No fault was found but at least I have it in writing that the gearchange was being obstructive then. The problem has been widely discussed on at least one VW forum, and I believe that the Octavia has the same VW-manufactured gearbox as is fitted to some Golfs. The UK-MKIVS Forum is down at the moment but I think that this is a relevant link. One possible solution is to change the type of oil in the gearbox. If that doesn't work, a gearbox rebuild or swap is needed. I intend to investigate having the oil changed first. Incidentally, I have noticed that the gearchange is getting marginally better as the weather warms up, and it is also less obstructive if the engine is allowed to idle for a few minutes before driving off (not something I normally do).
PS Link now mended. MKIVs address has changed.
Denis
DGW is online now
Old 09-04-2003, 14:43   #3
BRISKODA Staff
SkodiRS's Avatar
When I first got my previous Octy (SLX TDi) the gear change can be best described as being agricultural; from various motor mags I gather that diesel gearboxes tend to be likes this. May be due to them requiring stronger 'boxes to deal with the torque??
Anyway with miles it gets much better; mine had done 35k miles in just over 2 years and I near had any problem with it.
VAG parts are notorious for getting better with age. The 16v engine in the mk2 would be just getting into it's stride around the 60k mark.
I wouldn't worry but as you've had it checked out at least you have some evidence on your side if something were to go wrong.
Cheers.
Adrian.
SkodiRS is offline
Old 09-04-2003, 15:40   #4
Site owner
ColinD's Avatar
Images: 3
I too noted a difficulty engaging 1st/2nd on my 4x4. When I compared it againt another slighly more abused model I was very concerned I had a faulty box. However after 17k miles and a few crunched gears it's a lot better. I also use 2nd to 1st engine braking in traffic, I was a bit mifed untill it became easier. Squeaky clutch pedal my next biggest gripe.
ColinD - 97/100 Limited Edition Octavia vRS < For Sale £2500 Going to Dealers on the 29th...
www.BRISKODA.net :: Site Owner.
E-Mail : webmaster at briskoda dot net
Got a comment to make about the site? Please feel free to use the feedback form here, we welcome your views.
ColinD is offline
Old 09-04-2003, 15:59   #5
Kentish's Avatar
I havent had a VW that hasnt had this problem, and that includes a 1.1 Polo, 1.3 Jetta, 1.9 td Vento, my old 1.9 tdi 90 Octy and even my new Superb tdi130. Once warmed up and bedded in they are fine, or have been for me every time.
Cheers
Andy
Owner of a sense of humour.
Kentish is offline
Old 09-04-2003, 16:00   #6
thanks for your quick replies. if i change the oil in the box what type should i use and how easy is it.
mark.j.o is offline
Old 09-04-2003, 16:05   #7
Don't talk, drive!
ncarring's Avatar
Originally posted by ColinD in this post
...However after 17k miles and a few crunched gears it's a lot better....
Colin's gears all have nice rounded edges now - very smooth and silent :p
Nick
North Wiltshire RoADAR
ncarring is offline
Old 09-04-2003, 16:12   #8
BRISKODA Staff
mannyo's Avatar
Here is a link to the ukmkiv's forum, tried searching but cant find anything.
http://213.196.3.135/uk-mkivs/forum/
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 09-04-2003, 18:14   #9
skomaz's Avatar
Just thought I'd add a bit to this if it helps...
Our Fabia TDi doesn't suffer this but... it is a common problem on Mazda MX5's (my other car). In the latter it's due to a poor design of sychromesh between 1st and 2nd but is definitely helped by different oils. I seem to recall that the best we've found for solving the problem is a fully sythetic oil made by Redline but I can check it out.
If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables!
Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS
skomaz is offline
Old 09-04-2003, 18:31   #10
skomaz's Avatar
Right just checked on the oil and it's "Redline MTL" which can be sourced from mtmotorsport.co.uk at £12.50 per quart (946ml). Works a treat on the 5 but if you want to check on whether it's OK for the Octavia try calling Redline Oils on 01476 861195 (Gavin Scott I think)
Hope it helps!
skomaz is offline
Old 09-04-2003, 19:26   #11
VT5
My gearbox used to be a little bit reluctant to change ratios when the transmision oil was cold, but not when warmed up.
Its much better now I have done a few more miles. I used Millers TRX in a previous car which was good as it had good viscosity characteristics.
Millers oils
Their Diesel Power Plus (Dieselclean) fuel additive is good too and they have recently started to make an oil especially for the VW group Pumpe Duse TDI engines.
Hope this helps
Was: 2003 Allard Tuned Fabia vRS VT5 Turbo Conversion
Now: 2008 Audi A3 Sportback TDI
FabiaTDi is offline
Old 09-04-2003, 19:42   #12
Kentish's Avatar
But I think you will find the newish Millers oil isnt long-life compatable, it may be ok for 10k servicing but not variable.
Cheers.
ps I hope they have an oil that is soon as I think Millers is the dogs dangleys for diesel oil, and there Diesel clean plus fuel additive too.
Andy
Kentish is offline
Old 10-04-2003, 09:38   #13
DGW
BRISKODA Staff
DGW's Avatar
The link in my earlier reply was broken. It is now fixed and can be read here.
Denis
DGW is online now
Similar Threads
Gearbox Noise On Tdi skomaz Maintenance & Performance 29 05-12-2006 00:17
Fabia & Octavia Tdi Gearbox Oil Specs pikestan Maintenance & Performance 4 01-10-2003 10:34
