This is a discussion on Tech help required.... within the Maintenance & Performance forums, part of the General Motoring Discussions category; i need to tap into the lambda sensor for my air/fuel ratio meter..... which wire should i be using? also ...
| Briskodian Join Date: Jun 2003
| Tech help required.... i need to tap into the lambda sensor for my air/fuel ratio meter..... which wire should i be using? also looking for a good place to drill into the system for an oil temp gauge? suggestions welcome... pref useful ones.... ![]()
__________________ ________________________________________ Some times I just feel like smiling. |
| | #2 | |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Quote:
__________________ Adrian. | |
| VIP Join Date: Nov 2002 Location: South, then East a little bit.
| Yep - for oil temp get a new sump plug and get it drilled out to house the oil temp sensor. Plug sits on the back of the sump so should be OK. I'll be doing mine in the next week or two.
__________________ Dave ![]() Dave's new runaround ^ The Beast: 2001-2007 (now re-homed). 5 1/2 years of frightening the living daylights out of other road users and ashaming various high end cars. |
| cheers anyone got a clue on the lambda?
| Briskodian Join Date: Nov 2003 Location: nottinghamshire
| which lambda probe are you hoping to pipe into. broadband type pre cat or planner type post cat. does make a differance to your readings. |
| | #6 | |
| Briskodian Join Date: Nov 2003 Location: Around the South-East.....
| Quote:
WHITE: HEATER BLACK: SIGNAL GREY: EARTH On three wire sensors you will have one of each, on four wire there will be two heater wires. Not sure what is on the Skoda.....but on the FIAT, 4 wires were present and was able to observe the signal on the BLK wire and earthing to the exhaust using an oscilloscope. Again...not sure of what is on the Skoda....so be careful, no responibility taken blah blah, covering own back etc!!!! ![]() Hope that helps!!! /Gavin
__________________ Back from the dark side. Red Fabia vRS | |
| This site has some info. The Favorit, Felicia and Octavia 1.6 (no other engine sizes listed) all use the Universal 11984 as a replacement which ties in with Gavin's advice on wiring colours. Look at Wire Colours (1) if you want to get really confused by the various permutations of colours used by manufacturers!
| mine has 5 wires?
| | #9 | |
| Quote:
but now im not sure?
__________________ ________________________________________ Some times I just feel like smiling. | |
| | #10 |
| Just take the cat out then it doesn't matter ![]()
| | #11 |
| sorted FYI denis the 1.8T does use the same lambda the site lists it under A4 and Passat thanks
| | #12 |
| Paul - be interested to know what the 5 wires are if you found out. Take it it's 5 on the pre-cat? Cheers
| | #13 |
| 5 pre cat... 4 post.
| Help required: Fitting phone in Fabia | No Waiting | ICE, Security and Insurance | 16 | 27-12-2005 14:16 |
| Trained tech for hire... | Lummox | Off Topic and Chit Chat | 10 | 25-04-2004 19:04 |
| Decent Braking solution required | Gwilo | Maintenance & Performance | 4 | 05-04-2004 12:41 |
| Police advice required | Carjacked Mike | The Roadside Hotel | 12 | 03-02-2004 14:57 |
| Pc Security For Tech Heads | Kentish | Off Topic and Chit Chat | 23 | 01-07-2003 20:41 |
