Tips for a new Octavia vRS driver
This is a discussion on Tips for a new Octavia vRS driver within the Maintenance & Performance forums, part of the General Motoring Discussions category; I've only had my Octavia a week and its the first turbo I've ever owned. Sometimes whilst I'm driving it ...
Old 19-02-2004, 16:42   #1
Question Tips for a new Octavia vRS driver
I've only had my Octavia a week and its the first turbo I've ever owned. Sometimes whilst I'm driving it picks up really fast and other times it dosen't pick up half as well. I now this is down to technique as my brother used to own a scooby turbo and he said it took him a couple of weeks to understand how to make to scooby really go.
Any tips on making me an knowledgable vRS driver would be appreciated.
Cheers
Andy.
Brrrrmmmm Brrrmmmmmmmm
Andyhumble is offline
Old 19-02-2004, 17:05   #2
Nigel26's Avatar
had mine for a few weeks now and find the same thing at times, the turbo comes in at 2K rpm on mine (i'm assuming the others are the same) so when i want to move along swiftly i try to keep the revs high enough to come back in the next gear at somewhere around that point.
has caught me out a couple of times trying to pull away quickly though, too much acceleration results in the traction control spitting its dummy out !
loving every minute though
Nigel26 is offline
Old 19-02-2004, 19:14   #3
humsk's Avatar
As nigel said, "keep the motor spinning". Practice on a quiet road, flooring the accelerator at different engine speeds and see what happens ..... getting to know a new car is part of the fun.
Hope you like the vRS experience.
BFN,
Andrew
___________________________________________
Octy II - 4X4 TDI (leather, cruise & 16" alloys)
humsk is offline
Old 19-02-2004, 19:51   #4
remember to wait until the engine is warm before thrashing it too much and when you stop after a hard run let the engine idle for a while before turning it off to let the cooling system take some of the heat out of the turbo.There was a recent thread about this which explained in more detail but it was dure to the tremendous heat produced in the turbo boiling the oil off then giving you dry bearings in the morning
marc
scrutineer is offline
Old 19-02-2004, 20:09   #5
Jono's Avatar
marc
Tried to find the thread, failed.
Can anyone post a link please?
Jono
Octy vRS
Jono is offline
Old 19-02-2004, 20:27   #6
Dinosaur
TaviaRS's Avatar
http://www.briskoda.net/forums/showthread.php?t=6689
http://www.briskoda.net/forums/showthread.php?t=347
http://www.briskoda.net/forums/showthread.php?t=2038
TaviaRS is offline
Old 19-02-2004, 21:27   #7
SilveRS's Avatar
Just drive in a lower gear, 2.5k onwards, gives instant power and better engine braking
SilveRS is offline
Old 20-02-2004, 12:47   #8
Nigel26's Avatar
must admit the only time i find it "bogging" is when i'm in 4th or 5th and trying to accelerate from 40 or less...
Was trying a few things on the way home from work last night and found 3rd gives a very good response from 30.
Nigel26 is offline
Old 20-02-2004, 19:16   #9
Leeboy's Avatar
For pottering in the urban zones, use gears that will keep the revs below 3 to 3.5. This will save you inadvertantly accelerating up the tail pipe of the car infront should you be in slow going traffic. Otherwise when you want some grin , floor it in any suitable gear to get the tachometer needle whizzing round the dial quick as something quite quick!
Lee
Leeboy is offline
Old 20-02-2004, 19:59   #10
greg2302's Avatar
Personal favourite is flooring it in 2nd at 40 ............... whoosh !
An idiot is somebody who persists in holding their own opinion even after I have enlightened them with mine
greg2302 is offline
Old 21-02-2004, 07:44   #11
Re cooling the car after a thrash I would suggest driving gently for the last mile or 2. Ok I agree its a good idea to let the engine cool after a thrash but other parts of the car, brakes etc are also hot & will benefit from some air flow to cool them off .
Some might also say it gives the driver a chance to let the adrenolin levels drop & he then exits the car as a normal human being not some pumped up monster
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Old 22-02-2004, 00:21   #12
JayTee's Avatar
Thumbs up
For that sort of performance you need a diesel!!
John.
John Thomson
Seat Toledo Sport DSG TDi - Platinum Grey
Sunroof, Bi-Xenons, 17" Alloys, Park Sensors,
Bluetooth, Heated Seats, Rear Sliding Seats, Spare Wheel! (yes, it is optional )
JayTee is offline
Old 22-02-2004, 08:51   #13
Steve vRS's Avatar
Watch out for wheel spin when pulling away from junctions or out of slow corners and wet roundabouts. The traction control helps but is easily beaten.
Steve
From Tavia vRS 230bhp to Impreza WRX STi Version V Type R to Clio 182 Cup and now a vRS TDi Octy II in Lightning McQueen Red
Steve vRS is offline
Old 22-02-2004, 09:01   #14
VIP
DaveU's Avatar
Hi Andy,
If you are pootling around and want economy - change up nice and early. If you want to give it some larrup, normally drop it a cog or two so your revs are 3k+ then floor the throttle and hold on!
Most importantly though and I can't stress this enough (even though Stuart has mentioned in above), with a turbo car you can drive it like a nutter when you get used to it but please please treat it with some mechanical sympathy by not flooring it until the engine is warmed up. So when you take it out, make sure you 'pootle' around for a least 5/10 minutes so the engine is nice and warm before you boot it.
When you have finished driving like a loon, make sure you 'pootle' it back home for the last couple of miles or if this isn't possible then sit on the driveway with it running for a few minutes to let the turbo cool down.
Even more importantly than the above though - enjoy it
Dave
Dave's new runaround ^
The Beast: 2001-2007 (now re-homed).
5 1/2 years of frightening the living daylights out of other road users and ashaming various high end cars.
DaveU is offline
Old 24-02-2004, 22:54   #15
stathap's Avatar
Accept the lag... it's there and will never go away... it may even get worse the more you tune it.
Part throttle it 'til the turbo kicks in ... (hold a bit more then back throttle, blow of the dv...optional)
Then boot it !
Boost !
First time passesnger response is "whas a ..... that?"
Recline the seat... dial down the lumbar support and smile
"Classic" Black Magic
stathap is offline
Similar Threads
Octavia vRS with a 4X4 system? pietch Off Topic and Chit Chat 28 26-05-2004 09:50
Googlisms! Tavia4x4 Off Topic and Chit Chat 46 30-10-2003 17:49
Magic Black Octavia vRS is HERE!!!!! ecklad General Car Chat 5 09-05-2003 15:17
