This is a discussion on Transmission losses within the Maintenance & Performance forums, part of the General Motoring Discussions category; i have been informed recently that as a direct result of the decent amount of camber on my rear wheels ...
| i have been informed recently that as a direct result of the decent amount of camber on my rear wheels i have higher transmission losses on my car. now i know that is a perfectly reasonable conclusion but it was suggested that my excessive camber could be costing me about 20WHP, does this sound reasonable? if so then i might well gain 20WHP for under £300 ![]()
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| Re: transmission loses Seems a bit high to me (in a totally non-scientific, finger in the air kind of way) |
| Briskodian Join Date: Sep 2003 Location: Scotland
| Re: transmission loses some cheap horsepower there ![]()
__________________ Ive seen a lot of good things die and im in an over emotional way So please hand me the bottle I think im lonely now, and please give me direction I think the hurt has set in, and I don’t feel nothing |
| Re: transmission loses possibly, would be nice if its 100% right ![]()
| Re: transmission loses I think its a bit like saying you'll gain 20BHP by putting more air in the tyres. I understand the thinking behind it but just think the decimal point is in the wrong place. |
| Re: transmission loses 20WHP? No chance. Maybe 5-7bhp, but for that I'd expect it to be waaaay out... Just my humble opinion of course. If it is so, then wahay!!
| Re: transmission loses by the way i am running a fair bit of rear camber, i'll go take a picture ![]()
| Re: transmission loses i cant see how having more negative camber can make a difference to your wheel HP , if you have a slightly smaller tyre contact area due to the negative camber , wouldn't that give you less frictional losses or is it something to do with the way the drive gets to the rear wheels through the diff , just seems a very high figure for a bit of neggy camber
__________________ not so bored now |
| Re: transmission loses Aren't the rear wheels only driven when the front wheels slip so WHP should be unrelated? Chris
| | #10 |
Images: 5 Thanks: 76
| Re: transmission loses I "think" WHP is basically the power at the end of the driveshaft, not at the point of tyre. When you see these engines strapped onto a dyno, the sensor always seems to be bolted on the end of the driveshaft. So essentially, WHP is simply "post gearbox" or "post haldex" in this case? How the WHP is put down to the ground is obviously something the choice of rubber and contact area / camber affects. ![]() I was told with mine, that it had an unadjustable negative rear camber of about 1 degree, which is apparently what all the uber scoobs go to get their rear camber changed to. ![]()
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| | #11 |
| Re: transmission loses WHP is what it says it is jason, the power at the wheels. the make/model/size of tyres affects tranny loses as does the pressure of the tyre, if you run race slicks compared to cheapo tyres your transmission loses will be affected again as the overall resistance of the transmission system between the engine and the tarmac has changed. what also affects transmission loses is the angle that drive shafts sit at as a cv thats sitting at 10 degrees is less efficient than a perfectly straight drive shaft.camber, toe, wheel size, wheel weight, worn cv's etc etc all have a bearing on transmission losses. i was just wondering how much difference the camber might actually make?
| | #12 | |
| Re: transmission loses Quote:
Good old Powerstatiion Chris
