This is a discussion on Using a Trolley Jack within the Maintenance & Performance forums, part of the General Motoring Discussions category; Were is the best place to jack you car using a trolley jack ???...
| I have VAG COM Join Date: Jul 2006 Location: South Birmingham
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub ------------------------------------------------ ![]() |
| Briskodian Join Date: Oct 2005 Location: North West
| Ho Hum Join Date: Jan 2006 Location: Not here
| The best place is to be stood back, whilst someone else jacks it up..... Then when it rolls down the slight gradient, and drops off the jack, crushing your sills and squishing your brake pipes you can blame somebody else
__________________ I turned the light off............. |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| You could have even tried a serch and found this usefull bt of info... http://www.briskoda.net/forums/techn...octavia/50063/
__________________ MK2 Golf GTi - APX 225bhp 1.8T - Emerald K3 - Quaife ATB - VR6 Widetrack - VR6 brakes front and rear - Neuspeed ARBs - Speedline alloys - H+R coilovers - Powerflex bushes - Helix clutch G60 flywheel - Adjustable solid top mounts - Custom engine bay - Tornado Motorsport MSA cage - and lots lots more. |
| Briskodian Join Date: Oct 2005 Location: West Midlands, UK
| Jacking points are usually shown in the car manual. Usually somewhere hard that can transfer the weight of the car. I usually insert a thin piece of wood to distribute the forces and not leave dents in the metal. The wood crushes up under pressure and makes the jack more secure. Always put an axle stand underneath as well - it can save your life. I had my discovery slip off its trolley jack once (all 2.5 tons). The axle stand stopped me being killed and the landrover from expensive damage. Axle stands are are cheap too. Jules |
