This is a discussion on What's next after Remap? within the Maintenance & Performance forums, part of the General Motoring Discussions category; I've got a 2003 Octavia vRS and had it remapped by JabbaSport at 7k miles. Now on 61k and I ...
| Briskodian | What's next after Remap? I've got a 2003 Octavia vRS and had it remapped by JabbaSport at 7k miles. Now on 61k and I need more power! What is the next step? |
| King Rat Join Date: Jan 2006 Location: West Yorkshire
Members Car: MK11 Octavia vRS Thanks: 169
| Re: What's next after Remap? Bigger turbo looks like the next step if you want a lot more power ![]()
__________________ Current car: Black MKII Octavia vRS Combi Previous: Black MKI Octavia vRS Combi Black Fabia Elegance 100 BHP |
| Briskodian | Re: What's next after Remap? What does that involve? Is a brake upgrade required? Clutch? |
| Re: What's next after Remap? If you do a search it will bring up plenty of ideas ![]()
| Briskodian Join Date: May 2006 Location: Miles from where I want to be.
Members Car: Octy VRS Tdi Thanks: 9
| Re: What's next after Remap? Makes the remap pretty pointless if you go that way would be lots of money with all the other things that need uprating and then would need to have a different map put on.. CAI and exhaust would be the cheaper options. |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: What's next after Remap? yup exhaust will be worth it or failing that a read ARB is a well worth upgrade that im yet to do myself |
Members Car: Fiat Panda Thanks: 15
| Re: What's next after Remap? Depends what you want from the car. If you want big power figures, talk to Jabba about the best way to achieve them (imagine exhaust, better induction, FMIC and bigger turbo (IHI?) will be on the shopping list). May also want to look at a 6-speed gearbox too and LSD. If you want a car that is quicker in real terms, then look at suspension upgrades (KW3, uprated ARBs, lightweight wheels with sticky tyres and better brake discs, fluid and pads). If you want the best of both worlds, then go for it..... Chris
| Permanently banned Join Date: Mar 2006 Location: Buckingham Palace Car Park
Members Car: Honda Civic Type-R Thanks: 86
| Re: What's next after Remap? The only way your going to get a lot more power, is with a bigger turbo, from here-on. |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Re: What's next after Remap? There are two things to decide first 1. What can you afford & remember money spent on tuning is rarely recovered when you sell the car 2. How long will you keep the car
__________________ Speed is an addiction for which thankfully there is no cure |
| | #10 | |
| The Stig Join Date: Jan 2007 Location: Folkestone
Members Car: Race Blue vRS TFSI Hatch Thanks: 47
| Re: What's next after Remap? Quote:
__________________ "And when he gets to heaven to Saint Peter he will tell... One more Soldier reporting Sir... I've served my time in Hell"Mods done so far : Revo Stge 2, Forge Adjustable Spacer, Forge Diverter Valve, Miltek CBE, Evoms, Stu's Cruise , Autotech Fuel Pump, Xenons Upgrade, Koni FSD, Eibach Springs, Forge Short Shifter, VF Torque Arm Insert, NGK Iridium Plugs, Sachs Clutch & Flywheel, MFD3 Mods to come: KO4 Conv, LSD, Big Brakes | |
| | #11 |
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Members Car: 345bhp Silver Octavia vRS Thanks: 48
| Re: What's next after Remap? If you intend to keep the car I’d go for the BIG turbo…believe me it makes one hell of a difference in the power delivery!! You would need a lot of extras though…….. Handling: • Solid poly bushes up front (front and rear of wishbones). • S3 bottom chassis brace. • Rear Neuspeed 28mm or Eibach ARB – A front ARB will counteract the effect of the rear so don’t bother with it!! • KW (v.1 or 3) or Weitec coilovers are a good option for springs and dampers. Brakes: • Either Brembo 4 pots or AP Racing 4 or 6 pots with anything from 323mm-355mm discs + uprated brake fluid and pads etc. • Don’t bother touching the rears as there is very little brake bias to them. • Brake hoses are pointless too as the standard vRS (and 4x4) hoses are steel reinforced inside the rubber! Engine: • FMIC (Jabbasport) • Milltek 2¾” system + 3” downpipe (Jabbasport special!) • Cold air induction kit. • Oversized boost, turbo, intercooler hoses (3”) • Bigger injectors (440cc) • Turbo and manifold etc. (IHI vf34 roller bearing turbo) • Various oil pipe lines and attachments etc. • Beefier clutch, single mass flywheel…..or fit a 02M 6 speed box to avoid possible gearbox failure. Or you could just fit a milltek turbo back system, FMIC, decent CAI, DV and get it mapped again, prob to around 240bhp I would think.
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() |
