White Smoke From The Exhaust!!!!!!
This is a discussion on White Smoke From The Exhaust!!!!!! within the Maintenance & Performance forums, part of the General Motoring Discussions category; I own a Skoda Octavia RS 1.8 L Turbo petrol. In the begining, 7 months after i purchased the car ...
Old 24-10-2006, 14:52   #1
Default White Smoke From The Exhaust!!!!!!
I own a Skoda Octavia RS 1.8 L Turbo petrol. In the begining, 7 months after i purchased the car there was thick white smoke from the exhaust of the car. Initially i thought it wasbecause of rains here in INDIA but later i realised that was not the reason and i sent the car for workshop.The Skoda authorised workshop (Mahavir Motors) person kept the car for more than a month and at the end he did not solve the problem.Later to my surprise after i gave a complaint to the main Skoda branch in India they replaced my car's engine with a new one.Two monthe after they changed the engine I am still facing the problem of white smoke from the exhaust and my car isnt performing like RS..and it give a mileage of 6 kmpl in the city even after maintaing 2500rpm..wat do u guys say about this..any such complaints wit anyone of u?
Saikrishna is offline
Old 24-10-2006, 15:27   #2
Don't talk, drive!
ncarring's Avatar
Default Re: White Smoke From The Exhaust!!!!!!
It sounds like a failed head gasket, but why a new engine would exhibit the same symptoms shortly after replacement is a mystery. Without meaning to cause offence, what is the quality of the petrol like out there?
My mileage used to be around 7.3 miles per litre - so nearer 12 kmpl. Different, but not _that_ different, especially if your car is mainly used for short trips in the city. Does the white smoke persist if you take the car on a long run?
Nick
North Wiltshire RoADAR
ncarring is offline
Old 24-10-2006, 20:31   #3
landwomble's Avatar
you should probably ask lummox, but does the white smoke smell like steam, or like oil? steam means prob head gasket (bad), oil might mean blown turbo.
whatever it is, it's definitely not normal and there's no excuse for the dealer not sorting it out...
landwomble is offline
Old 24-10-2006, 20:35   #4
Briskodiodion
TeflonTom's Avatar
i've seen problems with the water jacket splitting through to the exhaust turbine on the water cooled turbochargers before, especially where the car has been driven really hard then not enough time is allowed for cooling before switching off the engine, to be honest the first thing i would check is the cylinder head gasket, then the turbo
vorsprung durch czechnik
TeflonTom is offline
Old 25-10-2006, 11:33   #5
the white smoke smells kind of oil..definately not steam..the fuels used are pretty ok..its same as the other octavia users..no one had such complaints..and when the white smoke comes out the car's powers reduces especially at higher rpm
Old 25-10-2006, 11:37   #6
blueriver's Avatar
I had a friend with the same problem with an old MR2.
So many people said it was the turbo that had gone.
Also with the loss of power seems to be an indication of this too.
Keep on at the dealer until it's fixed.
Si
blueriver is offline
Old 25-10-2006, 11:43   #7
Briskodaholic
Tom_vRS's Avatar
Really is sounding like a potential turbo failure then going by what mr Teflon says...
97/R BMW 328i in Boston Green.
Don't miss the new DR COLORCHIPS GROUP BUY!
Tom_vRS is offline
Old 25-10-2006, 12:43   #8
BRISKODA Staff
mannyo's Avatar
When they replaced the engine, was it the whole thing including turbo or did they reuse the ancillary components. Does sound like turbo to me.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 28-10-2006, 15:22   #9
they said they've changed the engine not turbo
Old 28-10-2006, 15:47   #10
landwomble's Avatar
bear in mind it'll probably have destroyed your catalytic converter too. get them to sort it. is there a different garage you can take it to? This one doesn't sound very competent...
Old 28-10-2006, 15:51   #11
splash!!!!
bengie's Avatar
in my limited knowledge and experience, turbo.
owner of a skoda octavia 4xvrs3
bengie is offline
Old 29-10-2006, 23:35   #12
cheezemonkhai's Avatar
From what you desribe i'd say turbo.
cheezemonkhai is online now
Old 30-10-2006, 01:22   #13
Briskodiodion
TeflonTom's Avatar
normally when you order a complete engine from the dealers,they come with engine block, bearings, crank, conrods, pistons, valves, camshaft,oil pump, rocker cover & sump. unless otherwise stated (except pd engines which come with injectors!)
all the other ancilleries such as intake/ exhaust manifolds, brackets , alternators, pumps, flywheel, clutch, etc and not included........
and if you purchase a recon engine from sombody like VEGE Uk, or even a recon from the dealer, they dont include and ancileries, and also they dont have any pulleys or belts too....
the only general exception to all this is when you buy a brand new type 1 or type 2 'old' beetle/bus engine (from vw deakers).... these normally come supplied with everything inclding the alternator and ht leads and they are ready to fit to the car.
Old 12-11-2006, 22:28   #14
Timo's Avatar
I had the blades on the water pump go. the car went into 'limp' mode, and after a mile or two more trying to limp home, white smoke started to come out. Scary. Had a new water pump, but they changed the head gasket and cam belt whilst there. Seems fine now.
Timo is offline
