This is a discussion on 1.8T 4x4 gearbox issue within the Octavia I forums, part of the Skoda Model Discussion Area category; my mate has had his car in at a "garage" today to check his gearbox. basically he finds it hard ...
| Briskodian Join Date: Oct 2003 Location: shropshire
| my mate has had his car in at a "garage" today to check his gearbox. basically he finds it hard to select certain gears,i said it could possibly be the selection cables. the "garage" has said that they cannot find a problem and that he should either go to skoda or a specialist(the latter i said from the off). anyway before he spends a fortune on it just to find out what it could be,has anyone had an issue with the 1.8T 4x4 box?car has covered 70+k,the clutch he says,doesn't slip,he can select gears smoothly when the car is not running. i have had a searchy searchy ,but nothing seems to tie in with the symptoms above. if it is cable related,anyone got an idea on price a dealership/specialist would charge to repair?iirc from my old SEATs they weren't cheap. but thinking about it if it works fine when sat with the engine off, would this be down to slack cables? thanks in advance.
__________________ louder than war |
| either selectors or clutch master cylinder i'd say. if not does he want to give me the gearbox? i have a lsight issue with mine.
| The Following User Says Thank You to bengie For This Useful Post: | jason (31-05-2007)
| Bully Bully :) Join Date: Jan 2006 Location: West Yorkshire
| Sounds more like worn syncro to me
__________________ Current car: Black MKII Octavia vRS Combi Previous: Black MKI Octavia vRS Combi Black Fabia Elegance 100 BHP |
| The Following User Says Thank You to vRSLen For This Useful Post: | jason (31-05-2007)
| If he can select gears without it running then it cant be adjustment, Either a fault with a clutch or as mentioned syncros.
__________________ Unit 18 Automotive Services |
| The Following User Says Thank You to Lummox For This Useful Post: | jason (31-05-2007)
| i'll give ya £50 for it ![]()
| cheers guys,either way its box out time for him then? any sure fire way of pinpointing it or will they need the box out to find the fault?
| take it to someone that knows first to get it looked at as it might be something simple.
| sourced a VAG specialist in shrewsbury,he's popping in tomorow to have a chat. think i might pop in with him,he's not that mechanically minded. cheers guys
| Briskodian Join Date: Feb 2006
| Before he starts spending it may be an idea to change the gearbox oil. Worked wonders for me....
__________________ Who needs the Nurbergring when you live in the Peak District |
| | #10 | |
| Quote:
__________________ louder than war | |
| | #11 |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
| Mine was lack of snchro and worn teeth on 2 and 3
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| | #12 |
| Was that attributed to normal wear and tear, or a fault with the gearbox? Chris
| | #13 |
| On that mileage, if it's not just occasional blocking of reverse and missing 3rd (like my long shift throw, short arm, high clutch issue with 3rd on fast upshifts), then oil change (ISTR 3l of 75W90EP synthetic needed [well 2.7l, but you can't buy 700ml bottles of gear oil]) first. If that fails I suspect it's box out time. |
| | #14 |
| 2.4 litres of 75W/90 Synthetic.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg... |
| | #15 |
| i doff my cap in your general direction guys(on my mates behalf).i'll see how it goes.
| | #16 |
| Briskodian Join Date: Jun 2005 Location: NW Kent
| Eyes ???? Come on Bengie ,,, pull yourself together man!
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm |
| | #17 |
| sorry, a typo ![]()
| | #18 |
| | #19 |
| | #20 |
| faintree garage are now 698 quid better off. knackered flywheel. my mate is very sad today
