This is a discussion on 1.8t vs NA, Tap Throttle Response within the Octavia I forums, part of the Skoda Model Discussion Area category; Say both cars (ie 1.8t 4x4 and NA Civic) and ticking over. If you tap the civic's throttle pedal, you ...
| Briskodian Join Date: Dec 2005 Location: Caribbean
| Say both cars (ie 1.8t 4x4 and NA Civic) and ticking over. If you tap the civic's throttle pedal, you see the revs rise up pretty quiclky. Now you try that in the 1.8t (DBW) and you barely get any response. I know the turbocharger is creating lot's of backpressure, but how slow is too slow when it comes to throttle response in our cars? Last time i vagcom'd my car, i had the multiplicative trim in -20%, which indicates something is wrong, but i havent found out what it is. Anyway, is my richness choking the engine at low revs and reducing my throttle response, or are the 1.8t really that lifeless? ![]() |
| Briskodian Join Date: Jul 2005 Location: South UK
| Smaller capacity revvy NA cars will always have quicker throttle response than FI larger capacity cars. There's more momentum in the engine to gain/loose, I expect VAG 1.8t has a much larger flywheel, and of course, at idle it doesn't have any boost, making it effectively a very low compression ratio NA engine compared to a high compression ratio engine.
__________________ Parents: '02 Octavia 1.9TDi Me: '99 V Honda Accord Type-R |
| | #3 | |
| Quote:
Now, could my -20% multi trim be reducing my response even further? | |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Also have to consider the DBW has a built in "sneeze factor" so you will loose a certain amount of immediate response. I expect the cable throttle 1.8t to have slightly better response to accelerator inputs.
__________________ Adrian. |
| Which measuring block is that trim reading in? PS: Just found it on Ross-Tech's website here. It's Group 032 - and a figure somewhere near +/- 10% is normal.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg... Last edited by DGW; 04-05-2006 at 22:22. |
| | #6 | |
| Briskodian Join Date: Sep 2003
| Quote:
__________________ Octavia 4x4 | |
| | #7 | |
| Quote:
Now that we are already talking about all this stuff, what can be causing the -20% multi trim, besides the fpr ? | |
| Briskodian Join Date: Dec 2005 Location: North West England
| re-mapped and fitted with a K&N throttle repsonse is improved, but nowhere near that of my old, slightly tweaked Focus.
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close |
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| I think its a turbo thing. The 350Z revs much more freely than a remapped 1.8T and the Z has a much large capacity engine too. |
| | #10 |
| Briskodian Join Date: Nov 2003 Location: Walsall, West Midlands
| its not to do with the flywheel in the 1.8t is it? i'm sure i read somewhere that they have a single mass flywheel to keep the idle steady when rolling in traffic... may be barking up the wrong tree there. i've noticed the throttle response on mine is nothing like the R19 16v i had before. i just put it down to DBW and being turbo'd.
__________________ Sea Grey Mondeo Titanium X |
| | #11 | |
| Quote:
Should be duel mass flywheel....it's a fair point.
__________________ Adrian. | |
| | #12 | |
| Quote:
its something else i notice with the vRS, how slow the revs die off when your blip the throttle... i know thats down to the flywheel. maybe the same is said for the revs rising...
__________________ Sea Grey Mondeo Titanium X | |
| | #13 |
| How many of you revmatch all the time? I always do, on everyday driving because i hate the shock of the clutch having to match engine speed with transmission speed. The slow throttle response makes revmatching hard to do propperly, specially because of how long it takes to rev the engine. How do you cope with this, or am i the only freak who doesnt like to use the synchros a lot? |
| | #14 | |
| Quote:
However from a standing start you are not inputting cooler air...more ambient temp air or even hot air from heat soak. On the move the response it deffo better but then that's due to freer flowing cooler air.
| | #15 | |
| Quote:
Having done both at the same time, I can't be totally sure which made the difference can I? ![]()
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close | |
