This is a discussion on 100 quid ebay remap within the Octavia I forums, part of the Skoda Model Discussion Area category; hi all No doubt there are some threads on this subject but i bit the bullet and sacrificed 100 quid ...
| Briskodian Join Date: Dec 2007
| hi all No doubt there are some threads on this subject but i bit the bullet and sacrificed 100 quid in the name of research. First impression, what a bargin! Graphs below: I would be interested to hear your comments. |
| Powahhhhhh.. Join Date: Apr 2004 Location: Buckinghamshire
| I'm having trouble reading that graph, can you explain it?
__________________ ------------------------------------------------- 4x4 Octavia, now with leaner gerbils ------------------------------------------------- |
| "COLLABORATER" Join Date: Jan 2005 Location: South East
| I would suggest getting that on a proper rolling road and get a full print out of true bhp / lb ft torque/ afr /and boost plot.
__________________ Performance like this, it's "IMPOSSIBLE".. Gerry |
| Briskodian Join Date: Jun 2007 Location: Cornwall
| I think your graph is wrong, as it def doesn't make 350+ lb/ft ![]()
__________________ Octy vRS mk1; APR Stage 1, Forge 007p DV, THS TIP, Honda s2000 aerial, seat cupra front splitter, MAS alloy center caps, alpine CDE-9871R, infinity 6010cs, Jbl 75.4 and 10" sub. Pug 205 gti; 1.6 |
| | #6 | |
| Quote:
Again, get it on a proper RR and see the true amounts. Where did you get the remap from????
__________________ Performance like this, it's "IMPOSSIBLE".. Gerry | |
| Briskodian Join Date: Oct 2007 Location: Cardiff
| is it a graph from a TD engine? then i might.
__________________ Done: PowerFlex Dogbone Bushes, Forge FMIC,CAI,forge DV, N75j, Longlife 200cel Cat 2.5" cat-back, Whiteline 22mm ARB and S3 Front Lower Brace, Remap, LCR Front Splitter, Milotec front grills, 18" R32 Wheels. To Do: TIP, Front Bumper: Milotec Side Vents, Middle Grill Cut-Out?, Milotec Rear Bumper Splitter, Weitec GT coilovers, SuperPRO Bushes, VSport Custom Remap. |
| I think he must mean NM which would put it @ 260lb/ft which is possible.
| The Following User Says Thank You to ethos For This Useful Post: | idontbelieveit (18-04-2008)
| updated graph |
| | #10 | |
| Quote:
This remap was from ecuevolution, newport it was a postal remap £107 quid including p+p For this money i aint gunna complain! RR would give correct values i know, but to be honnest, its very quick and thats all that matters to me! besides there isn't one for miles where i live. Vag com reports these values. | |
| | #11 |
| | #12 |
| Briskodian Join Date: Jul 2006 Location: Newport/Preston
| Newport South Wales? |
| | #13 |
| Did these 'graphs' come from the seller?
| | #14 |
| | #15 |
| that sounds good. please let me know if it starts throwin codes or aut breaks? cheers billy
| | #16 |
| have you got any mods to ur car mate? how do they get that much torque? most ive had was 202 but the map was throwin codes that seemed fast tho. id love to have 260 not sure what the map i got on now has but it is not as much as the old one i had. I am not far from newport. wales.
| | #17 |
| Briskodian Join Date: Jan 2004 Location: North East England
| I had mine remapped recently by a well known tuning company. When they downloaded my current map, they found that it had already been "remapped" but badly. Injection & boost pressure had been modified, but that was it. A lot more parameters have to be modified for it to be done correctly. The guy said it was proberly a cheap map from ebay & I would see a difference when his map is uploaded. Needless to say, he was right & the difference between the two are worlds apart. I'm not saying that all cheap remaps are like this, but I would be very wary of them.
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! |
| | #18 | |
| Quote:
Not sure what map is contained but what i can tell you is they never opend the ECU, it was done on the bench and programmed via its connection port that the wiring harness inserts into. No fault codes and ive been driving in hard and normal conditions for 3 days! I think they only offer a postal service, so even if you live close you would have to send your ecu away. I think its alot more expensive if you take the car to em. | |
| | #19 | |
| Quote:
Facts are im producing alot more torque and hp than i was, and it cost me nawt when compared to some of the prices offered. Boost pressure spikes at roughly 20psi and holds at 14-15psi (roughly) don't forget we're talking a 100quid here, i wouldn't expect it to be better than something 3 times the price... but still, not bad for the dough! | |
| | #20 | |
| Quote:
__________________ Black Magic SEAT Leon 2.0 TDI Sport - Green panel thingy, Upsolute jiggery pokery, Koni FSD/Eibach Pro Kit bouncy stuff, 18" Audi A8 Parabol rims, '08 Cupra black/honeycombe grille. Also driving around in a Mini ONE that thinks it's a Cooper! | |
