This is a discussion on Aero Wipers within the Octavia I forums, part of the Skoda Model Discussion Area category; dont know if this should be in my performance or maintenance as i'm not wanting to change them for a ...
| Briskodian Join Date: Nov 2003 Location: Walsall, West Midlands
| dont know if this should be in my performance or maintenance as i'm not wanting to change them for a mod for mod's sake more that they need changing and i wanted to upgrade/change the wipers for something different/better. So. Where do i get them from, how much and whats the car they are made for or whats the p/n ?? Thanks in advance and mods feel free to move accordingly.
__________________ Sea Grey Mondeo Titanium X |
| | #2 | |
| Ding, dong Join Date: Sep 2003 Location: in the doghouse
Images: 4 Thanks: 4
| Probably been better in the Octavia section, personally, but here you go. To get them, either brand new from a VW dealer as they were not fitted to the MK1 Octavia, or to a VW breakers yard. The car you need would probably be the Mk4 Golf, although the Passat wipers might fit and even the current Polo. SKoda wise check out the Superb ones or even the Octavia Mk2 as they might. Before you do anything though, measure the lengths of your wipers with the blades on from the spindle end of the wiper arm to the far end of the wiper to see how long you need. The Octavia should manage a straight swap for it, unlike the Fabia, which needs to have the arms butchered.
__________________ Jeff: Ambitious, but rubbish Quote:
| so the aero wipers are the whole arm and everything?? i thought it would just be the actual wiper on the end...lol i thought i read on here JHM Butts do them... anyone know?
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| vagparts or PM Stathap.
__________________ Adrian. |
| Briskodian Join Date: Feb 2003
| Areo wiper blades are a complete part (blade end..not including arm), which just pivot on a pin, and just slide on or off depending on how the blade is in relation to the arm...you would therefore need new arms as well. 2 new blades cost me £23 at my dealer a very short while ago.
__________________ Andy Owner of a sense of humour. |
| Briskodian Join Date: Aug 2004 Location: UK-Cambs
| sorry to sound dumb but what is the advantage of these over standard?
__________________ Benald -- www.irritantpaintball.com |
| They have a lower profile, but because they also have a rubber fin the whole length of the blade and no metal assembly they give a much better and complete sweep without any pressure lines as well as pressing better against the glass when at speed.
| cool cool thanks for that
| Briskodian Join Date: Jan 2003 Location: north
| Further to the PM To uprade to Aero's you will need to change the whole arm, blade and cap. * Just the Aero WIPERS are not compatible with our existing wiper ARMS * I got mine from http://www.vagparts.com/ look under Online Shop - Product Overview - VW - Gold mk IV - Exterior - Aero Wipers - Golf mk IV front Aero Wipers Cost is about £62 They used to also list them for the Leon but had to take them off due to the peeps on SeatCupra.net having fitment problems. There may be another way which is to order the parts seperately....(part numbers blatantly nicked from Cupra Net) Pop into VW and get Drivers Arm - 1J2955409D Passenger Arm - 1J2955410D End caps - 1J0955205A 01C Then go to happy Halfrauds and buy a 19 inch and 21 inch Bosch Aero pack (£18.49 ish) part no Bosch 928s * * I haven't tried buying them this way and accept no responsibility for giving out potentially duff information. Here's a fitting write up also nicked of cupranet 1. Undo nuts 2. Skoosh WD-40 down onto splines. 3. From inside car, flick the wipers and stop them when the tips are pointing towards the roof by switching off the ignition. This is ESSENTIAL as it provides the room you need to shoogle them off.... 4. Pull wipers off the screen to the "washing the car" position. 5. rock them on the splines (see below). Come off EASY this way Prior to refitting / fitting new ones..... switch on the ignition for a few seconds to allow the motor to park again. This makes setting the "rest position" of the wipers a smidge easier
__________________ "Classic" Black Magic |
| | #10 |
| Briskodian Join Date: Jun 2004 Location: Netherlands
| Bosch sells a set since a month or two for the octavia. Which fits directly on our standard arms.
__________________ Silver octavia RS 210BHP/326Nm Forge 007P |
| | #11 |
| Briskodian Join Date: Jan 2004 Location: Germany
| FRONT ![]() 1J1 955 425A 1J1 955 426A 1J1 955 409D 1J1 955 410D These numbers are only for cars with steering wheel on the left side! REAR ![]() 1T0 955 707 A 6Q6 955 425 A 1Z9 955 435 Another Pics on my Nickpage... Regards...Kromi
__________________ -=| Skoda Octavia 2.0 Combi Collection stonegrey |=- -=| Details make the Difference. |=- Last edited by Kromi; 08-06-2005 at 21:20. |
| | #12 | |
| Briskodian Join Date: Jun 2004 Location: North East England
| Quote:
__________________ Oh no. Another great Skoda. 2002 '52' (Now even rarer) Octavia vRS WRC 63/99 (see this thread) Fully stickered and ready to play, Saxo boy. Go ahead. Make my day. Within the posted limit, of course. | |
| | #13 |
| Briskodian Join Date: Sep 2004 Location: High Peak
| Thought I had seen a Bosch set in halfords may have been champion tho ![]()
__________________ '04 Silver Octy vRS - Revo 4bar, Miltek SS, Mitek Downpipe, 100cel CAT, RS6 18" Alloys, Forge 007p, ABD lan pipe/green filter, Samco TIP, Autogauge Boost,Oil temp, Oil Pressure gauges, ESP, Xenons, RS3 upper & lower braces |
| | #14 |
| I got the Bosch Aero's from germany. They are a straight swap. Don't need to change the arms or anything!
| | #15 | |
| Quote:
There is an optical difference between the original aerotwins and the aero wipers you can use with the original arms. Regards...Kromi
__________________ -=| Skoda Octavia 2.0 Combi Collection stonegrey |=- -=| Details make the Difference. |=- Last edited by Kromi; 09-06-2005 at 19:00. | |
| | #16 | |
| Briskodian Join Date: Jan 2005 Location: kent
| Quote:
KROMI , some nice bits of kit in the pictures , where did you get the BOONRATH LIFTERS FROM and how much is the price , are they direct from Germany . | |
| | #17 | |
| Quote:
You also can buy the lifters on Bonrath or Milotec. They are the same. Regards...Kromi
__________________ -=| Skoda Octavia 2.0 Combi Collection stonegrey |=- -=| Details make the Difference. |=- | |
| | #18 |
| Re: Aero Wipers Have just acquired some aero wiper blades and arms for my '05 Superb. But can I get the old ones off??? No I can't! Have followed the above instructions as well as I can but they won't budge and I don't want to damage anything by using too much brute force. Any more tips would be appreciated. Might I need some sort of puller? Cheers, Rob |
| | #19 |
| Briskadoodian Join Date: Jul 2007 Location: Sweden
| Re: Aero Wipers I think they do, actually, see WIPERBLADES.CO.UK : The UK's Premier Online Store £ 22.95 the pair for Octy Mk1 Got them for SWMBO's car last winter. Lovely not having to peel off frozen sleet in the morning any more. Plus they are silent, work well and look good. |
| | #20 | |
| Re: Aero Wipers Quote:
| | #21 |
| Re: Aero Wipers Check the date guys, this thread is over two years old and these wippers were not available back then! The threads been given a bump ![]()
__________________ There's nothing like seeing feathers going in the opposite direction to the bird! ....................................... |
| | #22 |
| Re: Aero Wipers ![]() ![]() ![]() |
| | #23 |
| Re: Aero Wipers It's OK guys, it was me who gave the thread a bump cos I can't get the damn things off my car! (Still looking for advice!) Cheers, Rob |
| Will these aero wipers fit? | Phill JK | Fabia I | 7 | 11-11-2004 19:44 |
| Thinking about aero wipers (and a few other bits) | vRSNutter | Styling and Car Care | 9 | 24-10-2004 21:45 |
| Aero Wipers on a Fabia vRS? | DarkForce | Fabia I | 5 | 11-09-2004 12:58 |
| Aero Wipers are go ! | stathap | Styling and Car Care | 25 | 17-07-2004 22:53 |
| Wipers randomly stop | Awed | Maintenance & Performance | 4 | 13-02-2004 18:06 |
