This is a discussion on air con question within the Octavia I forums, part of the Skoda Model Discussion Area category; turned the air con on, on the way home, it was blowing warm air out:-( listening carefully it sounds like ...
| Briskodian Join Date: Dec 2006
| turned the air con on, on the way home, it was blowing warm air out:-( listening carefully it sounds like a fridge coming from behind the glove box, when it blew out cold it sounded like this. I am hoping it is just a regas. Is there a simple way to find out what the problem is |
| Briskodian Join Date: Aug 2005 Location: All over the place
| Was it a gentle hissing noise? If so then vapour is passing through the TEV. Probably just short of gas. A shot of 134a and you'll be nice and cool again. The (larger) suction pipe onto the compressor should be cold to the touch and be covered in condensation if properly charged. I can't remember if the Mk1 has a sight glass on the drier or not.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| It doesnt have a sight glass no. Does sound like its low on gas, might be due to age or you may have a leak. Get it regassed and a leak dye added so it can be checked.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| thanks, how much should i expect to pay for regas |
| £40-£100 depending on what you want.
| The Following User Says Thank You to Lummox For This Useful Post: | mrmo (23-04-2008)
| when you say what you want? That is a big price range? Main dealer, independent? or is it more complicated than that? |
| regas say £40 regas and leak check may be more VW currently do a £99 offer that regasses your a/c, checks for leaks, uses an ultrasonic cleaner on the evaporator (gets rid of the old socks smell), a new pollen filter and a safety check.
| UberMod™ Join Date: Feb 2003 Location: Manchester
| Kwik-Fit do a check and re-gas for £45.. I had exactly the same symptoms as you, air-con not working, and a gurgling/wooshing sound from behind the glove box. Took car to Kwikfit, who have a machine for aircon.. they took the blower temp with the aircon on, then connected machine which measured pressures... then removed old stuff, vacumn tests it and tnen puts new stuff in. If its happened suddenly it may be a leak, but if its gradual and youve just noticed it, probably just needs re-gassing.. The early Octys are getting to that age now
__________________ ColGod the UberMod ![]() VXR, Gti, ST, Type-R, vRS, Shifty... An MPS fears not these things... ![]() ![]() |
| Briskodian Join Date: Oct 2007 Location: Buckinghamshire
| Cant believe I'm doing it but my car is going into Kwik Fit today for regas Will be keeping a very close eye on them ![]()
__________________ Upper & Lower S3 Strut braces-Forge FMDV006 DV-PiperX panel filter-Whiteline adjustable rear arb-Superpro Dogbone, Control arm & Front ARB bushes-LCR Splitter-Milotec Grilles-Golf MK4 Aero wipers-KVW100-Cruise Control-Parking Sensors-18" RS8 Alloys-N75H-Revo Stage 1 TO DO: Blueflame turbo back-Seat & Door Card Leather trim and a respray. |
| | #10 |
| Briskodian Join Date: Mar 2007 Location: Basingstoke
| I had the works done on mine when it went in for a service at the beginning of this week, I paid £75 all in iirc, my A/C is now icy cold and smells of flowers...
__________________ J'ai douze ans!! |
| | #11 |
| used my air con today and it was cold? not very cold but definitely cooler than it not being on? So i guess it is working just not very effectively. |
| | #12 |
| Had mine regased today and it had less than half the R134A refridgerant than it should have and virtually no oil. Pressure test found no leaks either so its now working as it should. ![]()
| | #13 |
| Briskodian Join Date: May 2006
| My brand new Octy Vrs Tdi (07) is doing this, hope it is just a regas, although thinking leak at this age should be a warranty or garage job anyway as was only delivered yesterday. |
| | #14 |
| Briskodian Join Date: Jun 2008
| Had mine regassed twice, worked for 2 days after first time then stopped as it has now. Is it expensive to diagnose what is wrong if sensor or something? Any suggestions would be most appreciated. (Ocatavia 2000 1.9 TDI) |
| | #15 |
| All, unless it's a warranty claim or you're pretty sure it's just a regas when Kwik-Fit might be cheaper, check Yellow Pages for an automotive aircon specialist near you and take it there. |
