This is a discussion on airbag warning light within the Octavia I forums, part of the Skoda Model Discussion Area category; hi all.I have a prob with my airbag warning light on octavia sdi 02 that I need help with.I had ...
| Briskodian Join Date: Nov 2006 Location: blackburn
| airbag warning light hi all.I have a prob with my airbag warning light on octavia sdi 02 that I need help with.I had to remove the airbag to fix my horn but when I put the bag back the light comes on,goes off for 2 secs the comes back on permanantly.does anybody no wot I have to do to fix or re-set it please? ![]() Last edited by loogi; 15-11-2006 at 18:30. Reason: more info |
| Briskoda Staff Join Date: Dec 2004 Location: Hampshire
| Re: airbag warning light Welcome to Briskoda. You've posted this in the wrong section really but I'll try to help. Did you remove the battery -ve lead before you removed the aribag? It's probably just a case of having the fault code reset.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: airbag warning light Welcome from me too. I have moved your thread to this forum. ![]()
| ECUless Join Date: Mar 2005
| Re: airbag warning light Did you switch on the ignition with it removed? That would cause it hopefully just a light reset then. I know that when we have to replace the spiral links (the contact slip ring) they come wired together, when you fit them you detach the wire. Apparently if you turn them and they are not fitted they are completely messed up. |
| Re: airbag warning light If it is simply a case that the fault code needs resetting, this can be done in a couple of minutes by a Briskoda member with VAG-COM software and lead if one lives nearby. Whereabouts do you live?
| Re: airbag warning light thanks all-first time of using forum so plz bear with me & only been online 3 weeks.DGW I live in blackburn if U no of anybody who can help who lives nearby.thanks again all |
| | #7 | |
| Re: airbag warning light Quote:
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... | |
