Discussing Alternator/Battery Cable..... within the Octavia I forums, part of the Skoda Model Discussion Area category; I've noticed on my Octavia TDi that the alternator cable on top of the battery, and right next to the ...
| Login | ||||||
46,769 Members 9 Posts | Register | FAQ | Members List | Calendar | Mark Forums Read |
| Notices |
Register to reduce ads, enable search and join our community.
| | LinkBack | Thread Tools | Display Modes |
| Briskodian Join Date: Aug 2008 Location: Romsey, Hants
Members Car: Skoda Octavia Elegance TDi Thanks: 3
| Alternator/Battery Cable..... I've noticed on my Octavia TDi that the alternator cable on top of the battery, and right next to the 110A fusible link gets very hot when the headlamps, heated screen and fan blower are all on. The cable has also discoloured due to the heat and resistance, and I've measured a volt drop of 0.8V under load between the cable and the terminal where it crimps. I've seen this before on other VW/Audi models and Ford Galaxy vehicles, so I'd say it's relatively common. I want to renew the cable, but rather than make one does anyone know if the individual cable is available to buy, or is it part of the complete loom? Thanks in advance..... |
| Got wood? Join Date: Sep 2003 Location: Newport Pagnell
Members Car: The best Fabia vRS Estate Images: 7 Thanks: 56
| Re: Alternator/Battery Cable..... Yep you can get the cable on its own.
__________________ |
| Re: Alternator/Battery Cable..... |
| Re: Alternator/Battery Cable..... Direct to the alternator. The starter motor wire goes direct to the battery terminal.
| Briskodian | Re: Alternator/Battery Cable..... Check the fuse box, you may find that the fuse is damaged and the fuse box burnt, do it now as the alternator goes if you leave it. Andy |
| | #7 | |
| Re: Alternator/Battery Cable..... Quote:
I've replaced the cable now and the voltage difference between the alternator and battery positive is now around 155mv with all loads on. Charging voltage is now around 14.2V with no load, and 13.6V under full load. The alternator was loaded at 75A with headlamps, heated screen and heater blower on. It's difficult to see how I could get much better than that..... | |
| Briskodian | Re: Alternator/Battery Cable..... Looks like you got it in time, mine melted the fuse mount then the altenator went, i think i was £300 in total to get it fixed. happy days |
| Briskodian | Re: Alternator/Battery Cable..... YOU SEE "AcW "WE AREN'T THE ONLY ONES!!! Geerrrrrrrrrr!!! ![]() |
| Bookmarks |
| Alternator/battery light query | podge3 | Favorit, Felicia, Fun and Forman | 9 | 29-11-2008 09:05 |
| alternator or battery | bengos152 | Favorit, Felicia, Fun and Forman | 8 | 29-12-2006 13:17 |
| Battery or Alternator? | Wickerman | Favorit, Felicia, Fun and Forman | 11 | 22-11-2006 22:32 |
| Battery or Alternator | Skodainhood | Fabia I | 6 | 26-10-2006 01:21 |
BRISKODA.net is operated by Summit 360 Ltd. Site Design and vBulletin Theme by Alex Pinner (apinner)
Problem viewing this site? Upgrade to the latest version of your web browser of choice:
Opera | Firefox | Safari | Internet Explorer
