This is a discussion on Auto windows done. within the Octavia I forums, part of the Skoda Model Discussion Area category; Did them today using a serial cable from VAG Products. What do you think?...
| Briskodian Join Date: Dec 2004 Location: Kernow
| Auto windows done.
__________________ 2001 Octavia 4X4 turbo Estate 1988 LAND ROVER 110 V8 County - Slow, but got in the way nicely! 1986 ROVER SD1 3500 Vitesse twin plenum - SOLD ![]() 1981 ROVER SD1 V8-S - |
| Briskodian Join Date: Jun 2007 Location: Cornwall
| Re: Auto windows done. Smoooooth. No additional hardware required, was this just a software tweak? ![]()
__________________ Octy vRS mk1; APR Stage 1, Forge 007p DV, THS TIP, Honda s2000 aerial, seat cupra front splitter, MAS alloy center caps, alpine CDE-9871R, infinity 6010cs, Jbl 75.4 and 10" sub. Pug 205 gti; mi16 200bhp/tonne ![]() |
| Re: Auto windows done. Just a software tweak, took less than ten minutes. Got the software (VDC Pro) with the cable although I already had a copy.
| Briskodian Join Date: Jun 2007 Location: cornwall
| Re: Auto windows done. When can you do mine ![]() ![]() |
| Re: Auto windows done. I don't mind doing it for you sometime but please be aware that I have only done it the once to my own car and I'm not a professional! I used the information I found at Passat World Forums to do it. So as long as your CCM unit is one of the ones listed it should be no problem. VDC pro or VAG COM will tell you which CCM you have, mine was 1C0 959 799 B, yours might be the same depends on the year I guess.
| The Following User Says Thank You to SimonJ For This Useful Post: | VRSPhil (31-05-2008) |
| Briskodian Join Date: Oct 2007
| Re: Auto windows done. Hello Simon, I have the same CCM unit as your but im not getting past the login stage using code 19283, i enter it and it takes me straight back to the Central Conv menu. Did you have any probs? Cheers Jason
__________________ PowerFlex Dogbone Bushes - Lower S3 Strut brace - Upper S3 Strut brace - Forge Splitter DV - MIJ Performance custom sports exhaust - V Tune Stage 2 Custom remap installed by Progressive Performance Bristol- Green Cotton Induction - Aero wipers - Cruise Control - Parking Sensors - TO DO: - Forge blue 5 piece silicon hose set-K04 turbo install - Milotec bumper inserts- Koni adjustables - LCR Splitter |
| Re: Auto windows done. Once you have logged in using the 19283 code and have gone back to the CCM menu, type in 27 (write serial eeprom).
| Briskodian Join Date: May 2004
| Re: Auto windows done. Can you only do this the way you did it then? Absolutely no way of doing it with the latest full VagCom? (USB) |
| Re: Auto windows done. The only way I know of doing it is with VDC Pro or with a KVW100 device both from vagproducts or with an Alientech controller.
| auto windows | MICKSVRS | Octavia II | 5 | 15-07-2007 15:19 |
| Auto opening windows? | Parslad | Octavia II | 4 | 12-07-2007 23:33 |
| Auto Windows KVW100 | faboka vrs | General Car Chat | 31 | 26-06-2007 15:31 |
| auto close windows ?? | mcbunny | Fabia I | 12 | 29-06-2005 11:11 |
| Auto Up Windows. | Bigw2069 | Fabia I | 7 | 07-12-2004 11:44 |
